Where to buy vacuum pump #440674
08/17/09 09:42 AM
08/17/09 09:42 AM
Temple, Texas
scoutsr2 Offline OP
scoutsr2  Offline OP
Temple, Texas
It gets a little scary when you are cruising around and then one time you hit the brakes and nothing...the 499 stroker in my Charger is just not creating enough vacuum to keep up with the booster. Anybody know where to buy nice electric vacuum pump?
Re: Where to buy vacuum pump [Re: scoutsr2] #440675
08/17/09 10:31 AM
08/17/09 10:31 AM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
I put this one on the 72.
Re: Where to buy vacuum pump [Re: WILD BILL] #440676
08/17/09 04:09 PM
08/17/09 04:09 PM
Temple, Texas
scoutsr2 Offline OP
scoutsr2  Offline OP
Temple, Texas
SMACKDOWN!! Ignorance is bliss...I was not expecting to be quite so pricy. Oh well...another couple of hunskies go in to the money pit.
Re: Where to buy vacuum pump [Re: scoutsr2] #440677
08/17/09 04:22 PM
08/17/09 04:22 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
Yeah, neither was I when I went looking
Re: Where to buy vacuum pump [Re: WILD BILL] #440678
08/17/09 04:39 PM
08/17/09 04:39 PM
So Cal
HealthServices Offline
Why would you even post that?
So Cal
If you are willing to go thru the yards, you can get one off of a car like a Cadillac.
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
Re: Where to buy vacuum pump [Re: HealthServices] #440679
08/17/09 04:51 PM
08/17/09 04:51 PM
Vancouver, WA
MoparMarq Offline
MoparMarq  Offline
Vancouver, WA
Toyota Turbo Supras have them also. For the same purpose (brake booster and cruise control actuator). I have one sitting on my bench right now (the pump, not the car).
Re: Where to buy vacuum pump [Re: scoutsr2] #440680
08/17/09 07:22 PM
08/17/09 07:22 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
Do you have a vacuum reserve canister installed ???
Re: Where to buy vacuum pump [Re: HealthServices] #440681
08/17/09 10:01 PM
08/17/09 10:01 PM
Wichita,KS
Blakcharger440 Offline
Wichita,KS
Anybody know what year Cadillac or Supra had the electric vacuum pumps? I have the same issue as the thread starter.
Re: Where to buy vacuum pump [Re: Blakcharger440] #440682
08/17/09 10:19 PM
08/17/09 10:19 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
Also '90s & up Camaros, Firebirds, Corvettes...my '97 Mustang GT has one. That's what I did for my drag car, pulls 5".
Re: Where to buy vacuum pump [Re: Blakcharger440] #440683
08/18/09 12:09 AM
08/18/09 12:09 AM
Vancouver, WA
MoparMarq Offline
MoparMarq  Offline
Vancouver, WA
Turbos on the Supras didn't start 'til '87. Look for an '87 to '92 Turbo Supra. Look for a VIN with xxxMA71xxx in it, not MA70. Later generation Supras ('93-'98) probably had them, also, but the cars are rare and junkers even rarer. On the '87 to '92s, the vacuum pump is attached to the cruise control bracket. Make sure you get the harness pigtail also, it's a goofy Toyota thing that I couldn't find at a parts store.
Re: Where to buy vacuum pump [Re: scoutsr2] #440684
08/18/09 12:17 PM
08/18/09 12:17 PM
michigan
black64 Offline
black64  Offline
michigan
What kind of vac are you seeing at idle? I bought a pump from master power brakes, pricey also, but found out that a reservoir worked for me. I have a pump if you need one since I'm not using it. I ran the car with it a couple times before adding the reservoir. The pump needs to be mounted close to the booster so they run less. (pm me if you want the pump I'll give you a deal))
