what cam to use,318? #439901
08/16/09 01:12 PM
08/16/09 01:12 PM
columbus,ohio
P
prorunner1 Offline OP
super street
super street
P
columbus,ohio
I am not expecting to much from this,what I have is a 83 imperial that has the Mp electronic conversion,600 holley and a performer intake,everything else is stock,this is my daily driver.
I do not want to add anything else to it but the cam if it would even help.my questions,
can I get better performance from a cam change over stock?
recommendations?
I was thinking about edelbrock performer cam,would this be a good choice?
any advice?thanks
Re: what cam to use,318? [Re: prorunner1] #439902
08/16/09 01:30 PM
08/16/09 01:30 PM
wilmington,ohio
O
ohiodemon Offline
ohiodemon  Offline
O
wilmington,ohio
use the 340 resto cam.
Re: what cam to use,318? [Re: ohiodemon] #439903
08/16/09 01:47 PM
08/16/09 01:47 PM
Conway, SC
T2R9 Offline
T2R9  Offline
Conway, SC
The small Summit SUM-6900 cam is a bargain at $98 and will wake that 318 right up. I am running a stock 318 with the summit cam, performer intake, and a TQ and it is impressive. This is the second 318 I have run this cam in and have not been disappointed in either of them.
Re: what cam to use,318? [Re: T2R9] #439904
08/16/09 03:30 PM
08/16/09 03:30 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I agree for a slight build the Summit cam will swap right in.Springs should even be good with it.Ive ran all their cams and for the price they cant be beat.90 bucks for cam and lifters was what I paid for the last one.Rocky
Chrysler Firepower
Re: what cam to use,318? [Re: therocks] #439905
08/16/09 04:47 PM
08/16/09 04:47 PM
Ohio, USA
Dr-Dave2 Offline
Dr-Dave2  Offline
Ohio, USA
That little summit cam works great in a mild 318
I had a 72 dart Swinger with a 318, 3.55 gears, stock 360 exhaust manifolds & stock thermo-quad intake. the summit cam really woke it up! even had a nice slight rumble at idle. http://www.summitracing.com/parts/SUM-K6900/
Re: what cam to use,318? [Re: Dr-Dave2] #439906
08/16/09 06:24 PM
08/16/09 06:24 PM
MarkZ Offline
Worthy
MarkZ  Offline
Worthy
Do you still have the stock 7.25" rear? If so, I think the J bodies had 2.24:1 gears them just like the M bodies. I'd swap out gears then before doing anything cam related.
2.94:1 geared 8.25" rear from a police package Diplomat or Gran Fury would be my next upgrade.
Re: what cam to use,318? [Re: MarkZ] #439907
08/17/09 06:33 AM
08/17/09 06:33 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
if you have 2.45:1 or 2.24:1 rear and want to keep it, stay conservative. I'd probably spend the extra coin and go for a lunati voodoo 60400, and comp 901 springs.
2017 Grand Cherokee Overland
Re: what cam to use,318? [Re: patrick] #439908
08/17/09 09:34 AM
08/17/09 09:34 AM
columbus,ohio
P
super street
super street
P
columbus,ohio
still has factory gears,which one i am not sure.
Re: what cam to use,318? [Re: prorunner1] #439909
08/17/09 10:10 AM
08/17/09 10:10 AM
scratchnfotraction Offline
pull the cover and look on the ring gear for ratio..
2x on the voodoo cams with comp 901 springs
I run the 60710 roller
258/264
207/213
.485/.485 lift
works great in my 85 stepside truck
Re: what cam to use,318? [Re: T2R9] #439910
08/17/09 10:17 AM
08/17/09 10:17 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
What he said...and go ahead and get a Timing chain set as well.
Coming soon!!!!
Re: what cam to use,318? [Re: T2R9] #439911
08/17/09 12:43 PM
08/17/09 12:43 PM
S.E. Conn
Hoof Hearted Offline
S.E. Conn
T2R9 Quote: "The small Summit SUM-6900 cam is a bargain at $98 and will wake that 318 right up. I am running a stock 318 with the summit cam, performer intake, and a TQ and it is impressive. This is the second 318 I have run this cam in and have not been disappointed in either of them."
What kind of power range are you getting with that cam T2R9?
What's your peak rpm and did you change springs?
Anyone know just Who makes these "summit" brand cams?
I am leaning towards this one, with a power range from 1000 to 5000rpm, worth the extra bucks and comes with a timing chain as well as a reputable brand :
http://www.summitracing.com/parts/CCA-SK20-221-3/?image=large
This one has a power range limited from only 1000 to 4000rpm : http://www.summitracing.com/parts/SUM-K6900/
2005 300C Hemi
2014 Ram ProMaster 2500
I Rekey, Repin old Chrysler locks and cut keys by code
Re: what cam to use,318? [Re: Hoof Hearted] #439912
08/17/09 01:03 PM
08/17/09 01:03 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
"Anyone know just Who makes these "summit" brand cams?"
Crane makes those cams, and while it does say 4k it will probably pull up to 4500-4600.
The larger one would probably like a little stall and 3.55's.
Coming soon!!!!
Re: what cam to use,318? [Re: Mr.Yuck] #439913
08/17/09 01:37 PM
08/17/09 01:37 PM
Conway, SC
T2R9 Offline
T2R9  Offline
Conway, SC
My car pulls hard right up to 4500. I did not change my springs.
Re: what cam to use,318? [Re: T2R9] #439914
08/17/09 03:31 PM
08/17/09 03:31 PM
on my VooDoo roller cam, its power band is idle to 5500rpm
I been 6200 rpms with it and no valve float with the comp 901-16 springs
pulled right up to the 5500 mark,then nosed over the rest the way to 6200rpms
I wanted to see if it would float the valves and I shift at 4800-5000 rpms now
my 85 stepside merges in traffic with attude and is a great daily driver
600 eddy carb
LD4B eddy intake
60710 VooDoo roller cam
headers and 2.5 duel glass packs
A999 stock high stall lock up tranny
A-body 8 3/4 with 3.23sg
29x15x15 M/Ts
18-19 mpgs with it 80-90 miles daily
Re: what cam to use,318? [Re: scratchnfotraction] #439915
08/17/09 04:31 PM
08/17/09 04:31 PM
columbus,ohio
P
super street
super street
P
columbus,ohio
thanks for the info,my next question would be would it be worth while to degree the cam or just install as is.
Re: what cam to use,318? [Re: prorunner1] #439916
08/18/09 12:51 PM
08/18/09 12:51 PM
MassHole Central
rtman Offline
rtman  Offline
MassHole Central
You may want to think about a Hughes Whiplash cams. They are designed to work in basically stock engines. Per Hughes, "They will increase your cylinder pressure, make a lot of torque and sound really wicked at an idle. Get on it a little and they will smooth right out and be very streetable."
http://www.hughesengines.com/Index/produ...mp;partid=25113
Re: what cam to use,318? [Re: prorunner1] #439917
08/18/09 01:29 PM
08/18/09 01:29 PM
Coolville, Ohio
Lew Offline
Lew  Offline
Coolville, Ohio
we have been running the whiplash in our low comp. 340,manly sound and great for just good ol drivne around fun, by the way this little cuda will do 13.26 1/4 at 103.9 with 3.91 rear, totaly street dress nothing over done about it.auto trans no stall.
