Re: what cam to use,318?
[Re: T2R9]
#439904
08/16/09 03:30 PM
08/16/09 03:30 PM
Posts: 21,050 Niles , Ohio
therocks
Niles , Ohio
I agree for a slight build the Summit cam will swap right in.Springs should even be good with it.Ive ran all their cams and for the price they cant be beat.90 bucks for cam and lifters was what I paid for the last one.Rocky
Chrysler Firepower
[Re: Dr-Dave2]
#439906
08/16/09 06:24 PM
08/16/09 06:24 PM
Posts: 4,368 Michigan
MarkZ
Worthy
Worthy
Do you still have the stock 7.25" rear? If so, I think the J bodies had 2.24:1 gears them just like the M bodies. I'd swap out gears then before doing anything cam related.
2.94:1 geared 8.25" rear from a police package Diplomat or Gran Fury would be my next upgrade.
[Re: MarkZ]
#439907
08/17/09 06:33 AM
08/17/09 06:33 AM
Posts: 16,122 Grand Haven, MI
patrick
Grand Haven, MI
if you have 2.45:1 or 2.24:1 rear and want to keep it, stay conservative. I'd probably spend the extra coin and go for a lunati voodoo 60400, and comp 901 springs.
[Re: prorunner1]
#439909
08/17/09 10:10 AM
08/17/09 10:10 AM
Posts: 15,487 Florida
scratchnfotraction
pull the cover and look on the ring gear for ratio.. 2x on the voodoo cams with comp 901 springs I run the 60710 roller 258/264 207/213 .485/.485 lift works great in my 85 stepside truck
[Re: T2R9]
#439910
08/17/09 10:17 AM
08/17/09 10:17 AM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
The small Summit SUM-6900 cam is a bargain at $98 and will wake that 318 right up. I am running a stock 318 with the summit cam, performer intake, and a TQ and it is impressive. This is the second 318 I have run this cam in and have not been disappointed in either of them.
What he said...and go ahead and get a Timing chain set as well.
[Re: T2R9]
#439911
08/17/09 12:43 PM
08/17/09 12:43 PM
Posts: 2,179 S.E. Conn
Hoof Hearted
S.E. Conn
T2R9 Quote: "The small Summit SUM-6900 cam is a bargain at $98 and will wake that 318 right up. I am running a stock 318 with the summit cam, performer intake, and a TQ and it is impressive. This is the second 318 I have run this cam in and have not been disappointed in either of them." What kind of power range are you getting with that cam T2R9? What's your peak rpm and did you change springs? Anyone know just Who makes these "summit" brand cams? I am leaning towards this one, with a power range from 1000 to 5000rpm, worth the extra bucks and comes with a timing chain as well as a reputable brand : http://www.summitracing.com/parts/CCA-SK20-221-3/?image=largeThis one has a power range limited from only 1000 to 4000rpm : http://www.summitracing.com/parts/SUM-K6900/
2005 300C Hemi 2014 Ram ProMaster 2500
I Rekey, Repin old Chrysler locks and cut keys by code
[Re: T2R9]
#439914
08/17/09 03:31 PM
08/17/09 03:31 PM
scratchnfotraction
on my VooDoo roller cam, its power band is idle to 5500rpm I been 6200 rpms with it and no valve float with the comp 901-16 springs pulled right up to the 5500 mark,then nosed over the rest the way to 6200rpms I wanted to see if it would float the valves and I shift at 4800-5000 rpms now my 85 stepside merges in traffic with attude and is a great daily driver 600 eddy carb LD4B eddy intake 60710 VooDoo roller cam headers and 2.5 duel glass packs A999 stock high stall lock up tranny A-body 8 3/4 with 3.23sg 29x15x15 M/Ts 18-19 mpgs with it 80-90 miles daily
[Re: prorunner1]
#439917
08/18/09 01:29 PM
08/18/09 01:29 PM
Posts: 316 Coolville, Ohio
Lew
Coolville, Ohio
we have been running the whiplash in our low comp. 340,manly sound and great for just good ol drivne around fun, by the way this little cuda will do 13.26 1/4 at 103.9 with 3.91 rear, totaly street dress nothing over done about it.auto trans no stall.
