70 Air Grabber Q's #439538
08/16/09 08:59 AM
08/16/09 08:59 AM
California
Moneypit6 Offline OP
California
I've got a couple of questions as I try and clean up the air grabber install of a previous owner.
1 - I bought a vaccum can and was wondering where the factory mounted these on a 70 Roadrunner. I've seen pics of them up by the horn and also back by the firewall.
2 - what is the electric solenoid for wired in series with the manual vaccum switch??? What is it's function?
Dennis
70 Roadrunner almost ready to come off the rotisserie smile
Re: 70 Air Grabber Q's [Re: Moneypit6] #439539
08/16/09 10:52 AM
08/16/09 10:52 AM
WOODGRAINWHEELS.COM Indiana
plumbeeper Offline
plumbeeper  Offline
The vacuum canister should be on the firewall near the heater hoses. I'll go take a pic and post it in a few minutes. The solenoid's purpose is to cause the air grabber to close when you turn off the ignition. I unhooked mine so the air grabber will stay open during car shows.
Re: 70 Air Grabber Q's [Re: plumbeeper] #439540
08/16/09 10:57 AM
08/16/09 10:57 AM
cataclysm80 Offline
cataclysm80  Offline
Tav
Re: 70 Air Grabber Q's [Re: cataclysm80] #439541
08/16/09 11:18 AM
08/16/09 11:18 AM
plumbeeper Offline
plumbeeper  Offline
Pardon the dust...I drive it
Re: 70 Air Grabber Q's [Re: plumbeeper] #439542
08/16/09 12:02 PM
08/16/09 12:02 PM
California
California
Okay!! Excellent info and pic. Is the can mounted level across the top or is it tilted down on the driver side?
So the solenoid benefit is only if you have the grabber open when you shut off the car. It swaps the vaccum when keyed off. Hmm, not sure I'll use it.
Where did you get the diagram? Maybe there are other good ones!!
Dennis
Re: 70 Air Grabber Q's [Re: Moneypit6] #439543
08/16/09 12:11 PM
08/16/09 12:11 PM
Cold Spring, NY
1970GTX Offline
1970GTX  Offline
Cold Spring, NY
There should be 2 dimples stamped into the firewall. That is where the holes get drilled. Sheetmetal screws are used to fasten the vacuum canister to the firewall. I think there is also a dimple for the grommet that the hoses go through.
Re: 70 Air Grabber Q's [Re: 1970GTX] #439544
08/16/09 06:41 PM
08/16/09 06:41 PM
okla.
O
okie Offline
okie  Offline
O
okla.
The hoses come thru just above the heater hoses and the vaccumn jug set down to the left of the heater hoses. It should be easy to see where they go if they aren't drilled yet. The hoses have to run from the inside out so the grommet will work. Good Luck! Ronnie in Okla. 70 Purple 340 Swinger 70 Lemon Twist AirGrabber RoadRunner
Re: 70 Air Grabber Q's [Re: okie] #439545
08/16/09 07:33 PM
08/16/09 07:33 PM
St.Louis,Mo.
70RR383 Offline
70RR383  Offline
St.Louis,Mo.
Question,I am just surfing and trying to learn something here,I noticed (plumbeeper)in your picture that your pcv valve in the valve cover on the passenger side??Sorry for highjacking,just curios.Is this for 440 ,my 383 is on the drivers side.Thanks
Re: 70 Air Grabber Q's [Re: 70RR383] #439546
08/16/09 09:39 PM
08/16/09 09:39 PM
Fort Workin Tx
Day2Runner Offline
Day2Runner  Offline
Fort Workin Tx
heres a 383 air grabber car
Re: 70 Air Grabber Q's [Re: 70RR383] #439547
08/16/09 11:13 PM
08/16/09 11:13 PM
plumbeeper Offline
plumbeeper  Offline
I think my breather base is from a '69 because the PCV nipple on the back of it faces the passenger side instead of the driver's side. It was on the car when I got it and since it works, I never changed it.
