Re: holley 3310 tuning/ adjustments? [Re: jensenguy] #438949
08/15/09 06:04 PM
08/15/09 06:04 PM
Virginia
JimG Offline
JimG  Offline
Virginia
Another thing,
...But the thing that got me, when I loosen the adjusting screw on either the front or the back, I get fuel running (almost spraying) out from under the adjusting screw. Should it do that?
Yes. It's under pressure when the engine is running (assuming a mechanical fuel pump).
ETA it will also have residual pressure after you shut the engine off.
Re: holley 3310 tuning/ adjustments? [Re: jensenguy] #438950
08/15/09 06:19 PM
08/15/09 06:19 PM
Rancho Cucamonga, CA
D_C Offline
D_C  Offline
Another thing,
I was trying to check my float levels, when I open the sights the back one is dry, but the front one has fuel running out. That means the float level on that one is too high correct?
Yes. You need to lower the float so it shuts the needle-valve off sooner.
Yes, that is normal but can be minimized by keeping the screw, screwed down, as you adjust the nut (so it's a two-hand operation,) wide-screwdriver and 5/8-inch wrench.
Of course, the needle-seat screw and nut gaskets do wear out too, eventually.
Re: holley 3310 tuning/ adjustments? [Re: D_C] #438951
08/16/09 01:03 PM
08/16/09 01:03 PM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
I just had the same problem with my 3310, two hands one with the big screwdriver and the other with an open end wrench..
work slowly and keep the screw a bit snug to keep gas from going all over..
It took a couple of minutes for the engine to clean up after I had the float set properly.
Re: holley 3310 tuning/ adjustments? [Re: sthemi] #438952
08/17/09 08:08 PM
08/17/09 08:08 PM
Ohio
jensenguy Offline OP
Ohio
OK, im back with some more numbers.
First off I did manage to get my floats adjusted, I had to turn the front adjuster about 3/4 of a turn in to get fuel to stop running out of the sight. It doesnt seem like that really changed anything yet though.
Im now at 15 degrees of initial timing, pulling about 11 inches of vacuum at 850rpm. Is that what I should be seeing with the bigger cam?
So whats my next step?
Re: holley 3310 tuning/ adjustments? [Re: jensenguy] #438953
08/18/09 07:49 AM
08/18/09 07:49 AM
Virginia
JimG Offline
JimG  Offline
Virginia
IIRC, you went from 10 degrees to 15 degrees initial timing and stopped there? To truly know where the "sweet spot" is, you must go too far, then back off (approach "dead nuts" from both directions so you'll know you're there). Bump the timing up some more until it quits producing more idle vacuum/smoother idle/better throttle response or until the hot engine kicks back against the starter when you try to restart it. Then and only then will you know the initial timing is optimized. My guess is 18 - 20 degrees will be about right, but there's no way to know without trying it.
After that you'll have to disassemble the distributor and (not JB ) weld up the advance slots and file them to the correct length to get the total advance back down to 36-38 degrees. If you haven't already done so, you might want to think anout recurving the distributor with a lighter spring at that point. The engine is in a Jensen, and they're fairly light cars, yes?
If you're interested in using the vacuum advance, you'll work on that next. Tuning it consists of adjusting the level of vacuum required to actuate the vacuum advance mechanism (easy) and possibly limiting the degrees of vacuum advance, based on what your engine will tolerate (not quite as easy). You'll find that the opinions of Moparts members regarding vacuum advance varies widely, with some swearing by it and some swearing at it.
Assuming the rest of the ignition system passes muster, then it's back to the carb.
Post back with your results.
