Painted racing mirrors on '71 b body #438903
08/15/09 02:06 PM
08/15/09 02:06 PM
Hunt Valley, Maryland
1fastrunner Offline OP
Well, I can't get the exact shade of paint, but I still want to install these mirrors on my '71 RR. Can anyone please give me some measurements as to where the holes should be for mounting? Also, any tips would be greatly appreciated.
Thanks,
Re: Painted racing mirrors on '71 b body [Re: 1fastrunner] #438904
08/15/09 02:19 PM
08/15/09 02:19 PM
Rancho Cucamonga, CA
D_C Offline
D_C  Offline
On my '71 Charger SE, it came with a Rally mirror on the driver's side only.
I added the right-side mirror that I purchased through a Dodge dealership at that time.
My Original and added mirrors were Chrome Plated.
I mounted the new mirror at the same position as the existing mirror on the opposite door (driver's side) using that as my template.
Couldn't you do something similar?
Re: Painted racing mirrors on '71 b body [Re: D_C] #438905
08/15/09 03:03 PM
08/15/09 03:03 PM
That was going to be my last resort, the drivers side mirror is different and I'm waiting for the others to dry to measure. Was there a plate underneath? or do I just screw into the door?
Re: Painted racing mirrors on '71 b body [Re: 1fastrunner] #438906
08/15/09 03:16 PM
08/15/09 03:16 PM
D_C Offline
D_C  Offline
It was a longggg.... time ago when I did mine. As best I recall, there was a black rubber gasket that is placed between mirror base and outer door skin.
On the inner door, there was a sheet-metal backing/reinforcing plate. Studs in the mirror base penetrate the door skin (through holes you drill) and nuts secure the backing-plate against the door skin from the inside.
I have another couple of chrome rally mirrors I salvaged off a B-Body several years back at a Pick-a-Part. Just got one out to look at it.
Re: Painted racing mirrors on '71 b body [Re: D_C] #438907
08/17/09 06:51 PM
08/17/09 06:51 PM
I just took off the drivers side mirror, and there is not a plate, but 2 bushings through the door skin. There was also a gasket. I was able to locate some of the mirror mounting plates, but they won't work on the other side because the mounting holes will be different. Any ideas what this bushing is? or can I just use any bushing? i don't want my mirror to get loose.
Thanks,
Re: Painted racing mirrors on '71 b body [Re: 1fastrunner] #438908
08/17/09 07:34 PM
08/17/09 07:34 PM
Ont, Canada
gygeneral Offline
gygeneral  Offline
Ont, Canada
What you need is on this page. Have a look
http://www.restorick.com/products.asp?cat=1&pg=2
Re: Painted racing mirrors on '71 b body [Re: gygeneral] #438909
08/17/09 07:37 PM
08/17/09 07:37 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
You may find the article at the link below useful as well.
http://www.hamtramck-historical.com/mirrors.shtml
Re: Painted racing mirrors on '71 b body [Re: gygeneral] #438910
08/17/09 09:49 PM
08/17/09 09:49 PM
Thanks, any idea where I can get a tool?
Re: Painted racing mirrors on '71 b body [Re: Alaskan_TA] #438911
08/17/09 09:50 PM
08/17/09 09:50 PM
Thanks to you also,
Napa sells the kit for $128, I only need to use it for 2, anything less expensive out there?
Re: Painted racing mirrors on '71 b body [Re: 1fastrunner] #438912
08/17/09 10:02 PM
08/17/09 10:02 PM
connecticut
pnypwr Offline
pnypwr  Offline
connecticut
buy the riv nuts...and use a bolt a nut and some washers and use that to compress or squeeze the riv nut...I have the tool now but ive seen it done that way before! or go to a body shop and see if they can just put the inserts in for you!
"Are you gonna bark all day lil doggy? Or are you gonna bite?"
05 ram 2500 ctd
74 gremlin x 360
65 mustang 347
70 coronet R/T 440
03 Mach 1
Re: Painted racing mirrors on '71 b body [Re: pnypwr] #438913
08/17/09 10:09 PM
08/17/09 10:09 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
I could bring mine to Carlisle next year?
I have loaned it out on occassion too, you would have to pay postage both ways though.
I see you are in York, do you know Jackie?
Re: Painted racing mirrors on '71 b body [Re: Alaskan_TA] #438914
08/17/09 10:20 PM
08/17/09 10:20 PM
No, I don't think I do. Who's Jackie?
Re: Painted racing mirrors on '71 b body [Re: 1fastrunner] #438915
08/17/09 10:23 PM
08/17/09 10:23 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
She has a green '71 Challenger, great lady. She helps with the local shows there quite a bit.
Re: Painted racing mirrors on '71 b body [Re: Alaskan_TA] #438916
08/17/09 10:34 PM
08/17/09 10:34 PM
I haven't met her yet, but I'll be on the lookout.
I don't get to go to too many local shows as they are always on weekends, and i work most weekends.
Re: Painted racing mirrors on '71 b body [Re: 1fastrunner] #438917
08/17/09 11:42 PM
08/17/09 11:42 PM
D_C Offline
D_C  Offline
Here is a Photo of one of my Factory chrome Rally Mirrors and the Factory-Type Gasket and Backing-Plate I mentioned:
Re: Painted racing mirrors on '71 b body [Re: D_C] #438918
08/17/09 11:46 PM
08/17/09 11:46 PM
Thanks for the photo, I have 2 of the backing plates, but can't use them because the passenger side won't line up with the drivers side.
Re: Painted racing mirrors on '71 b body [Re: 1fastrunner] #438919
08/17/09 11:55 PM
08/17/09 11:55 PM
D_C Offline
D_C  Offline
Could you reverse one backing-plate and hammer it flat to make it work on the other side?
Could you fabricate a plate from flat sheet metal? It is unseen as it is inside the door, so it doesn't need to be pretty.
I like the backing plate, as mirrors do get leaned on from time to time, and the door skin might bend or the mirror may come loose without some form of reinforcement from the back side.
Re: Painted racing mirrors on '71 b body [Re: D_C] #438920
08/18/09 12:28 AM
08/18/09 12:28 AM
My driver's side mirror is held on with rivet nuts. The plate will move the other mirror too far down the side of the door. I'm planning on using the rivet nuts on the other side like the factory did. The driver's side has held up well.
Re: Painted racing mirrors on '71 b body [Re: D_C] #438921
08/18/09 01:01 AM
08/18/09 01:01 AM
Conyers, Georgia
72chargerz Offline
72chargerz  Offline
Conyers, Georgia
That is not a 71-72 B body mirror. That is a 75-? mirror used on a variety of Mopars. A correct 71-72 mirror does not have mounting studs.
Re: Painted racing mirrors on '71 b body [Re: 1fastrunner] #438922
08/18/09 01:01 AM
08/18/09 01:01 AM
S.E. Conn
Hoof Hearted Offline
S.E. Conn
I don't mean to Hijack Runner's thread, but I figured one of you gents might know if Colored mirrors were available on 71 Charger SE's?
2005 300C Hemi
2014 Ram ProMaster 2500
I Rekey, Repin old Chrysler locks and cut keys by code
