Too much oil to the top end? #438774
08/15/09 12:14 PM
08/15/09 12:14 PM
AndyF Offline OP
AndyF  Offline OP
I putting a hyd roller cam in my 505 motor with the Comp 8921 lifters. These lifters have the capability of oiling the pushrod so I went ahead and ordered pushrods with oiling ends. I have a conventional rocker arm system on there which oils internally so now I'll be sending oil up both places.
Anyone try this before? It might be too much oil to the top end but then again, because the hyd roller lifters don't have any lash there really shouldn't be much oil going up the pushrods. Guess we'll see how it works. I've been increasing the oil to the top end on my dyno motors the last several years in an attempt to limit pushrod heat but I haven't tried this combination yet.
Re: Too much oil to the top end? [Re: AndyF] #438775
08/15/09 12:18 PM
08/15/09 12:18 PM
AndyF Offline OP
AndyF  Offline OP
With it all together on the stand the rocker arms oil flow oil to the roller ends and very little oil escapes the pushrod cups. So I bet it is going to work okay.
Re: Too much oil to the top end? [Re: AndyF] #438776
08/15/09 12:48 PM
08/15/09 12:48 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Andy, whats the spring pressure at seat... i"m guesssing
here BUT if you run light enough pressure the oil
pressure MIGHT try to open the valve just a touch
or it MIGHT just push the plunger down farther till
it has a bleed point to match each other
Re: Too much oil to the top end? [Re: AndyF] #438777
08/15/09 01:09 PM
08/15/09 01:09 PM
Boise
Moparteacher Online content
Moparteacher  Online Content
Boise
I wouldn't give it a second thought.
Re: Too much oil to the top end? [Re: Moparteacher] #438778
08/15/09 01:41 PM
08/15/09 01:41 PM
Winnipeg ,Mb. CA.
chryco Offline
chryco  Offline
Winnipeg ,Mb. CA.
Oiling is good for the top end also will remove heat from the valve train . Don`t see any detriment .How`s you oil return though ?
Chryco
Gas is fer washin' parts ....Alky`s fer drinkin' ...Nitro`s fer Racin'!
Re: Too much oil to the top end? [Re: chryco] #438779
08/15/09 02:42 PM
08/15/09 02:42 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
Man I thought my W5 stuff had a lot of intake off set
Re: Too much oil to the top end? [Re: AndyF] #438780
08/15/09 03:30 PM
08/15/09 03:30 PM
SoCal
Brian Hafliger Offline
SoCal
You won't have any problems!!
Brian Hafliger
Re: Too much oil to the top end? [Re: Brian Hafliger] #438781
08/15/09 03:55 PM
08/15/09 03:55 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
I'm going to run the Howards Direct lube lifters that are AMC style which will also provide oiling through the push rods, I plan to also run stock oiling setup too. I figured this would be too much oil up top also. I talked to Manton, they will add a .030 restrictor free of charge when I order my push rods, this might be a option to consider
Re: Too much oil to the top end? [Re: Bob_Coomer] #438782
08/15/09 05:21 PM
08/15/09 05:21 PM
AndyF Offline OP
AndyF  Offline OP
Yes, for a solid flat tappet that has lash open most of the time I'd probably use a restrictor in the pushrod also.
