727 Torque Converters #438657
08/15/09 07:54 AM
08/15/09 07:54 AM
NY
old340dog Offline OP
NY
I just did a rebuild on my 340 motor and am trying to decide if should replace torque converter before we put everything together. If I do would you guys recommend a stall speed converter. My motor has a com cam(XE268H) .477 lift/268duration cam. It will be used as a street car/daily driver.
I have been told you need to run a tranny cooler if you install a stall speed. I figure I just need around a 2,000rpm stall speed if I went this way.
Or should I just stick with a stock converter? Who would you recomend for a stall speed or stock converter?
Thanks guys,
old340dog
Re: 727 Torque Converters [Re: old340dog] #438658
08/15/09 10:41 AM
08/15/09 10:41 AM
northeast ohio
hulmule Offline
hulmule  Offline
northeast ohio
I have a 2200 to 2400 stall no cooler. if you go higher you my need one. it's a different feeling, i have been a stick guy so it feels like your slipping the clutch.
1969 Dodge Coronet R/T Convertible
1979 LiL Red x2
2012 Yellow Jacket
2006 mega cab
1977 Trailduster
1979 Trailduster
Re: 727 Torque Converters [Re: hulmule] #438659
08/15/09 11:11 AM
08/15/09 11:11 AM
Az
Crizila Offline
Crizila  Offline
Az
An external cooler is always a good idea with any higher than stock stall converetor. Anything around 2500rpm will be fine for the street. You could go as high as 2900 rpm without a problem in a stock application. Obvioulsy mileage will suffer a bit, but usually not a primary concern if you want a little more zip.
Fastest 300
Re: 727 Torque Converters [Re: Crizila] #438660
08/16/09 08:32 AM
08/16/09 08:32 AM
NY
NY
Any suggestions for good brand name stock or stall speed converters?
thanks,
old340dog
Re: 727 Torque Converters [Re: old340dog] #438661
08/17/09 05:32 PM
08/17/09 05:32 PM
N. of 8mile, S. of heaven
Spike Offline
Go Blue!!
Spike  Offline
Go Blue!!
There was a post about converters just a week or two ago and a lot of guys lean toward PTC converters. I have no experience with them but they were guys using them.
Re: 727 Torque Converters [Re: old340dog] #438662
08/17/09 11:32 PM
08/17/09 11:32 PM
Missouri
MY340 Offline
MY340  Offline
Missouri
thanks,
My new Duster has a Hughes 2600 convertor. I like it but heck I used to be a 4-spd guy so I wouldn't know the difference between convertors.
I know one thing this new Duster can smoke the tires very easily anytime!
1970 FE5 Duster 360/904/3.91's SOLD 1973 TB3 SpaceDuster 340/4spd/4.10's SOLD Moparless for now but when the opportunity is right I'll have another one.
