900 + hp and Cal Tracs
#438042
08/14/09 09:19 PM
08/14/09 09:19 PM
Posts: 576 Somewhere Over the Hill
Mr. Dodge
I'm having my 588ci Hemi built and we are expecting around 900hp. I was wondering if I should get rid of my cal-tracs and get a 4-link instead. I don't know if the Cal-Tracs are up to the task......
Ya I know sorry for another Cal-Trac question....
"The advantage of being armed the Americans possess over the people of all other nations,which are carried as far as the public resources will bear, the governments are afraid to trust the people with arms."(James Madison)
69 Hemi Coronet R/T
70 456 Dart Swinger
Re: 900 + hp and Cal Tracs
[Re: Mr. Dodge]
#438045
08/14/09 10:25 PM
08/14/09 10:25 PM
Posts: 8,165 Left Coast
BobR
Left Coast
Absolutely depends on what you plan to do with it. For a serious race effort that does not have rules where you have to run Caltracs you are WAY better off with a 4 link.
[Re: Cab_Burge]
#438048
08/15/09 03:00 AM
08/15/09 03:00 AM
Posts: 3,245 Between a rock & a hard place
cudadoug
Well, I don't know what the HP limit is with Cal Tracs, but I do KNOW of a 3,200 lb twin turbo big block 67 Camaro with Cal Tracs/Springs and 10.5 slicks and I SAW it go 8.48 @ 164 a couple of weeks ago. Then came back and went 8.51 and 8.50...then killed the glide.
Try it....
[Re: cudadoug]
#438049
08/15/09 04:35 AM
08/15/09 04:35 AM
965 HP and was running 9.29 with Cal tracs, no problems at all. 146.67 mph i did go to ladder bars late in the season and now 9.22 @147.04
#438050
08/15/09 12:03 PM
08/15/09 12:03 PM
BobR
Left Coast
You don't consider the missing 7 hundredths a problem? There are also consistency and tunability issues as well. CalTracs are a VERY GOOD product but they aren't 4 links.
[Re: BobR]
#438051
08/15/09 12:19 PM
08/15/09 12:19 PM
Posts: 1,090 north cakalaky
instigator
north cakalaky
small tire stock suspension type car then caltracs
big tire bracket car then 4-link IMO
65 Barracuda All aluminum Indy HEMI with some boost! COMING TO A TRACK NEAR YOU!
[Re: BobR]
#438054
08/15/09 04:51 PM
08/15/09 04:51 PM
I have to take into consideration the day it went 9.22 @147.04 the air was much better but sidewalls were gone, it was also a tad lea, if i went up to a ricner jettting, it still had more, but it was time to dial in so i left it alone. i just set up another set of carbs wit the richer jetting and new slicks so we'll see. the caltracs definitely worked but i feel a difference with stability with the ladder bars.
