900 + hp and Cal Tracs #438042
08/14/09 09:19 PM
08/14/09 09:19 PM
Somewhere Over the Hill
Mr. Dodge Offline OP
I'm having my 588ci Hemi built and we are expecting around 900hp. I was wondering if I should get rid of my cal-tracs and get a 4-link instead. I don't know if the Cal-Tracs are up to the task......
Ya I know sorry for another Cal-Trac question....
"The advantage of being armed the Americans possess over the people of all other nations,which are carried as far as the public resources will bear, the governments are afraid to trust the people with arms."(James Madison) 69 Hemi Coronet R/T 70 456 Dart Swinger
Re: 900 + hp and Cal Tracs [Re: Mr. Dodge] #438043
08/14/09 10:13 PM
08/14/09 10:13 PM
Finally a HUSKER again
Moparnut426 Offline
Moparnut426  Offline
The charger we bought had 1450 with the bottle, and it was a cal track car, went straight as an arrow, and hauled the mail. Here it is...
http://www.youtube.com/watch?v=y4vjllW0rjY
I think this is with stock front suspention, after he put the coil overs up front it stopped skying like that, and got faster.
KAsey
Re: 900 + hp and Cal Tracs [Re: Moparnut426] #438044
08/14/09 10:15 PM
08/14/09 10:15 PM
Colorado
506RR Offline
506RR  Offline
Colorado
4404Dart here on the board makes more than 900 HP and his Cal-Tracs seem to be working great!
Re: 900 + hp and Cal Tracs [Re: Mr. Dodge] #438045
08/14/09 10:25 PM
08/14/09 10:25 PM
Left Coast
BobR Offline
BobR  Offline
Left Coast
Absolutely depends on what you plan to do with it. For a serious race effort that does not have rules where you have to run Caltracs you are WAY better off with a 4 link.
Re: 900 + hp and Cal Tracs [Re: Mr. Dodge] #438046
08/14/09 10:47 PM
08/14/09 10:47 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Lets hear your Hemi build specs.
I plan to run My Home made caltracks with my Hemi. If your car is going to see an street time, the cal tracks would be better and much more safe IMO.
Re: 900 + hp and Cal Tracs [Re: BobR] #438047
08/15/09 02:31 AM
08/15/09 02:31 AM
why take a knife to a gun fight when you can bring a machine gun
Re: 900 + hp and Cal Tracs [Re: Cab_Burge] #438048
08/15/09 03:00 AM
08/15/09 03:00 AM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
Well, I don't know what the HP limit is with Cal Tracs, but I do KNOW of a 3,200 lb twin turbo big block 67 Camaro with Cal Tracs/Springs and 10.5 slicks and I SAW it go 8.48 @ 164 a couple of weeks ago. Then came back and went 8.51 and 8.50...then killed the glide.
Try it....
Re: 900 + hp and Cal Tracs [Re: cudadoug] #438049
08/15/09 04:35 AM
08/15/09 04:35 AM
965 HP and was running 9.29 with Cal tracs, no problems at all. 146.67 mph
i did go to ladder bars late in the season and now 9.22 @147.04
Re: 900 + hp and Cal Tracs #438050
08/15/09 12:03 PM
08/15/09 12:03 PM
Left Coast
BobR Offline
BobR  Offline
Left Coast
You don't consider the missing 7 hundredths a problem? There are also consistency and tunability issues as well. CalTracs are a VERY GOOD product but they aren't 4 links.
Re: 900 + hp and Cal Tracs [Re: BobR] #438051
08/15/09 12:19 PM
08/15/09 12:19 PM
north cakalaky
I
instigator Offline
instigator  Offline
I
north cakalaky
small tire stock suspension type car then caltracs
big tire bracket car then 4-link IMO
65 Barracuda
All aluminum Indy HEMI with some boost!
COMING TO A TRACK NEAR YOU!
Re: 900 + hp and Cal Tracs [Re: instigator] #438052
08/15/09 01:23 PM
08/15/09 01:23 PM
Deerfield, Ohio
70dusterjohn Offline
Deerfield, Ohio
Re: 900 + hp and Cal Tracs [Re: 70dusterjohn] #438053
08/15/09 04:43 PM
08/15/09 04:43 PM
Wellington, FL
cudabunch Offline
cudabunch  Offline
Wellington, FL
Stock floor small tire Cal Tracs
Tube chassis big tire 4-link
Re: 900 + hp and Cal Tracs [Re: BobR] #438054
08/15/09 04:51 PM
08/15/09 04:51 PM
I have to take into consideration the day it went 9.22 @147.04 the air was much better but sidewalls were gone, it was also a tad lea, if i went up to a ricner jettting, it still had more, but it was time to dial in so i left it alone.
i just set up another set of carbs wit the richer jetting and new slicks so we'll see.
the caltracs definitely worked but i feel a difference with stability with the ladder bars.
Re: 900 + hp and Cal Tracs #438055
08/15/09 04:55 PM
08/15/09 04:55 PM
Wisconsin
Garceau Offline
Garceau  Offline
Wisconsin
Well - all know my stance.
If class rules arent an issue if the fabrication isnt an issue.
You would be silly not to run a 4 link. I personally am not a fan of ladder bar cars. They at times run out of adjustability. The daytona I ran for years was LB car and it drove me crazy at times when I needed to change things.
LB cars can work, they just dont have the tuning and adjustability of a 4 link.
Re: 900 + hp and Cal Tracs [Re: Garceau] #438056
08/15/09 08:49 PM
08/15/09 08:49 PM
There ain't nothing wrong with Cal Tracs that a good four link can't fix In all truthfulness Cal Tracs are a excellent product and do a good job where you can't run a laddar bar or a four link or three link due to rules or space or budget constraints. I have owned and raced several different Dusters with ladder bars and I like them a lot I have freinds who have lighter weight cars with four link that work excellent, you can hook them up in a mud bog in the middle of a rain storm And I know there is at least one Cal Trac racer on here that can do that also on a nine inch tire The decision is yours
