Need help with 60ft #437518
08/14/09 08:14 AM
08/14/09 08:14 AM
Northwest Chicago Suburb
DaDart Offline OP
DaDart  Offline OP
60’s are 1.50’s to high 1.40’s
with a best 1.46. Car appears to hook and pull the front wheels a few inches
Running 10.16 @ 132 Car is a 71 dart all steel, glass, full interior, ladder bar
backhalf full cage. Bars have three holes and have it set in the middle with about 3 degrees pinion
down. Currently 110 coilovers with dual adj QA1’s in the rear with single adj QA1’s up front. . The ladder bars have three holes and have it set in the middle
with about 3 degrees pinion down.
499 bb 727 5500 stall dana with 456
Tires 32X17.50 ET Streets - Couple years old but not many passes
Thanks in advance
3 Darts and a Ram
Re: Need help with 60ft [Re: DaDart] #437519
08/14/09 08:18 AM
08/14/09 08:18 AM
The Swamp
MegaDart Offline
MegaDart  Offline
The Swamp
try another convertor
Re: Need help with 60ft [Re: MegaDart] #437520
08/14/09 08:20 AM
08/14/09 08:20 AM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
What size tire and how old?
Sounds like a lot of gear for 500" engine, even for 32-33" tire??
Re: Need help with 60ft [Re: MegaDart] #437521
08/14/09 10:16 AM
08/14/09 10:16 AM
Mansfield, Tx
Jacob Pitt Offline
Jacob Pitt  Offline
Mansfield, Tx
What converter are you currently running? You will be amazed at how much e.t. the wrong converter can eat up. The motor is making good power running 132 so something is slowing you down the first half of the track. What are your 1/8th mile times and speeds?
2013 NHRA D4 Stock Champ
#4 in the World IHRA Stock
2x IHRA Div.4 Stock Champ
14x Track Champ
All using a Ultimate Converter Concepts converter. Call Lenny today 704-892-6837
Re: Need help with 60ft [Re: DaDart] #437522
08/14/09 11:06 AM
08/14/09 11:06 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Before I changed verts, my car was inconsistent in the 60`s and now w/my 8" continental 5000+ vert, it works quite well in my lowly 470 streeter.
Re: Need help with 60ft [Re: DaDart] #437523
08/14/09 12:00 PM
08/14/09 12:00 PM
MR_P_BODY Offline
MR_P_BODY  Offline
What seems to be the problem.... have you taken any
video of your launch
Re: Need help with 60ft [Re: DaDart] #437524
08/14/09 12:46 PM
08/14/09 12:46 PM
Chicago,Illinois
N
nosboy Offline
nosboy  Offline
N
Chicago,Illinois
I have a 73 challenger with a 440 with indy heads.. The car is backhalf'd and a 4 link with coil overs and wheelie bars.. The car weighs 3280 WITHOUT the driver and I WISH I could get my 60' in the high fourties... I also have a 5000 stall and a 4.56 gear...33.5X 14X 15 goodyears that DO NOT like to be warmed up too much and the car runs 10.30's at 132 mph.. I think your 60's are where they supposed to be....UNLESS your car weighs 2800lbs!!!
Re: Need help with 60ft [Re: nosboy] #437525
08/14/09 12:54 PM
08/14/09 12:54 PM
Q
Quicktree Offline
Quicktree  Offline
Q
his 60's are not that bad. but if you can't get in the 40s with your combo something is bad wrong. for one you don't have near enough gear with a 33.5" tire. and probably could use a lot more converter. heck we had 1.53 60's with a small block, stock leafs, running on 2bbls of the carb.
Re: Need help with 60ft [Re: nosboy] #437526
08/14/09 12:59 PM
08/14/09 12:59 PM
Chicago, IL
TonyS451 Offline
TonyS451  Offline
Chicago, IL
What seems strange is that the et and mph look good for one another, but the 60 doesn't match. I would think at that et and mph, the 60 would be in the low 1.4's. I can tell you first hand, this Dart is not even close to 2800 lbs. I wouldn't be suprised if its at least 3400 without driver. All steel, full stock interior, full cage, extra rubber on the rear quarters, etc.
2 kids and a dog
Re: Need help with 60ft [Re: TonyS451] #437527
08/14/09 01:08 PM
08/14/09 01:08 PM
Q
Quicktree Offline
Quicktree  Offline
Q
he could possibly be a little better, I would be looking at the tire and converter. put a real slick on it and see what it does.
Re: Need help with 60ft [Re: Quicktree] #437528
08/14/09 01:44 PM
08/14/09 01:44 PM
Chicago,Illinois
N
nosboy Offline
nosboy  Offline
N
Chicago,Illinois
I think a 5000 convertor and a 5000 launch chip and a 3500lb car (with driver) could be MOST of the problem.. I also degree'd my cam to wake up around 3000-3200 (102 centerline) so MAYBE the motor isn't making the right torque at 5000 rpm launch...???????? WHADDAYA THINK????
Re: Need help with 60ft [Re: nosboy] #437529
08/14/09 01:49 PM
08/14/09 01:49 PM
Q
Quicktree Offline
Quicktree  Offline
Q
could be, but I would have 5600-5800 converter in that thing. 5000 is no where near enough.
Re: Need help with 60ft [Re: Quicktree] #437530
08/14/09 02:10 PM
08/14/09 02:10 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
As others have said, the 60 foot is WAY off for what the car runs. I dont think 5500 flash could be WAY off for your motor but without the rest of the combo its impossible to say...heads, compression, cam, carb, etc???
As an example i have a WAY cheezier suspension on my 3350 pound car than you, stock 002/003 leafs and 39 dollar 3 way shocks on all 4 corners,and i go 1.34 best and no worse than 1.38 generally regardless of air, with a tiny tire.
So you are giving up 12-15 hundreds somewhere in the first 60 foot. That could equate to double than on an ET slip if you get it sorted out..
You almost need to video the launch to see what is going on, and tweek from there. Rome wasnt built in a day, and getting a car to 60 foot is an incremental process.
Before throwing a convertor at it, a video to see what the car is doing would likely be more helpfull. Maybe something in the combo is adversely affecting the car getting out of the gate.
post everything about the car, if you would
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Need help with 60ft [Re: B3422W5] #437531
08/14/09 02:19 PM
08/14/09 02:19 PM
Mansfield, Tx
Jacob Pitt Offline
Jacob Pitt  Offline
Mansfield, Tx
When my Challenger was running 10.60's it was 60' in the 1.40's and would hit 1.50's on bad days. Now it goes 1.35 everywhere. I have a converter that flashes to 5000 and I footbrake my car.
14x Track Champ
Re: Need help with 60ft [Re: B3422W5] #437532
08/14/09 03:06 PM
08/14/09 03:06 PM
Chicago,Illinois
N
nosboy Offline
nosboy  Offline
N
Chicago,Illinois
A few others have said that MY 60' is way off.... The front wheels don't lift up AT ALL!!! The compression is 11.9 to 1 (11 to 1 pistons and indy 440-1 cnc 325cc heads).. The cam lifts 420 at the lobe and the centerline is 102 degrees... 5000 conveertor and a transbrake...
