Hooking up aftermarket guages on a 68 roadrunner #437132
08/13/09 07:26 PM
08/13/09 07:26 PM
NJ
440challenger Offline OP
NJ
Going to hook up some gauges in my 68. The fuse block is always hot on this car unlike the 72+ cars i have owned in the past where there is an acc terminal. How do you guys go about finding a switched 12 volt source for gauge power. I Guess i could find a wire off the ignition switch and splice into it but id rather not if there is a better way.
Re: Hooking up aftermarket guages on a 68 roadrunner [Re: 440challenger] #437133
08/13/09 07:48 PM
08/13/09 07:48 PM
gtx69 Offline
super gas
gtx69  Offline
super gas
Wipers radio fuse
Re: Hooking up aftermarket guages on a 68 roadrunner [Re: gtx69] #437134
08/13/09 10:57 PM
08/13/09 10:57 PM
Clintwood VA
johnedod Offline
johnedod  Offline
Clintwood VA
Take the fuse box off of the dash and look in the back of it. I think there's some piggy back terminals on the back of the fuse box.
Johnedod
68 Road Runner
71 Road Runner
78 Power Wagon
Re: Hooking up aftermarket guages on a 68 roadrunner [Re: johnedod] #437135
08/14/09 12:52 AM
08/14/09 12:52 AM
East TN.
Moparsky Offline
Moparsky  Offline
East TN.
If you have the spare $, you might want to think about updating your wiring & put in a modern fuse box & wiring kit. Just a thought. The OEM fuse panels are very small & limiting.
Re: Hooking up aftermarket guages on a 68 roadrunner [Re: Moparsky] #437136
08/14/09 10:24 PM
08/14/09 10:24 PM
NJ
NJ
ok i will ck the backside of fuse blcok but i thought they were all hot
Re: Hooking up aftermarket guages on a 68 roadrunner [Re: 440challenger] #437137
08/15/09 12:46 AM
08/15/09 12:46 AM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
I know I found switched power at the fuse box in my 69 RR
I want my fair share
Re: Hooking up aftermarket guages on a 68 roadrunner [Re: SomeCarGuy] #437138
08/15/09 07:57 PM
08/15/09 07:57 PM
So Cal
HealthServices Offline
Why would you even post that?
So Cal
I just double checked (5 mins ago) with a test light only two fuses on my 69 is hot with the key out and it is the dome light circuit and the tail lamp (brake light?).
Looking at the 68 RR wire schmactic I would pull power off one of the solid black wires (hot key on) leading to the fuse box and run a small fuse.
Is it possible you have something wired wrong?
I believe the black wire coming out of the ignition switch is switched power and feeds several fuses in the the fuse box.
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
