Page 3 of 3 1 2 3
Re: Challenger Stereo Crossover Question [Re: cataclysm80] #436839
08/18/09 10:34 AM
08/18/09 10:34 AM
Rhode Island
71 Six Pack Offline OP
Rhode Island
Hopefully you've already got these pieces?
all 3 unique 70 challenger dash speaker grills
the ribbed radio surround plate to match your standard cluster bezel.
the 70 challenger dash trim with 8 track notch. That will be the toughest find I think.
I have almost all the pieces. I am just waiting on a rallye fader switch I purchased to come in the mail. The AM/8-Track bezel was pricey to say the least. The rear package tray in the car is original and in good shape. I am missing the correct rear defogger set up with the rear speakers though. When I bought the car the rear defogger was mounted on the support beam behind the rear seat.
The hardest thing to find is the correct labeling for the switch panel. This car has a 2-spd Wiper, and therefore a footpump washer. Finding the correct label for standard dash was difficult because I also need the rear defogger on it. I was able to use the one from my '71 Cuda for now which is also a 2spd Wiper with rear defog car. The repop labels I have seen pics of always have he Wipe/Wash when the rear defogger is there instead of just Wiper.
Joe
Re: Challenger Stereo Crossover Question [Re: 71 Six Pack] #436840
08/18/09 01:33 PM
08/18/09 01:33 PM
cataclysm80 Offline
cataclysm80  Offline
Sounds like you have a really nice car with lots of options!
The housings for rear speaker with rear defog are available reproduction from Mike at BE&A restoration parts. I haven't seen the reproduction piece in person because I have an original, but usually his stuff is top notch.
The clips that hold the wiring to the bracing behind the seat can be tough to find also. If you can't find them, you might try using dome light wiring clips that clip on the sail panel behind the headliner, or trim down some cuda roadlamp wiring clips which are also available from Mike at BE&A.
Tav
Re: Challenger Stereo Crossover Question [Re: cataclysm80] #436841
08/18/09 01:37 PM
08/18/09 01:37 PM
cataclysm80 Offline
cataclysm80  Offline
Oh, I almost forgot, you mentioned putting the optional clock in your 70 Challenger standard cluster.
This is the correct 70 Challenger standard cluster only clock. (either style would fit & function, only lettering/needles are different.)
Tav
Re: Challenger Stereo Crossover Question [Re: cataclysm80] #436842
08/18/09 01:39 PM
08/18/09 01:39 PM
cataclysm80 Offline
cataclysm80  Offline
for comparison, here is the 71-74 Challenger & 70-74 Barracuda standard cluster clock.
I've heard the clock set knob itself and tube nut are the same as used on a rallye dash and are also available reproduction from Mike at BE&A if you need them.
Tav
Re: Challenger Stereo Crossover Question [Re: cataclysm80] #436843
08/19/09 09:09 PM
08/19/09 09:09 PM
Rhode Island
Rhode Island
I'm pretty sure the clock I have is a '71 style. I don't know if the car came with one from the factory or not as there was a Rallye dash in the car when I bought it. There is no indication for tach on the fender tag so I figured the car came with a standard cluster. I never liked the blank plate on the standard dash where the clock should be so I pulled the clock from my Cuda's standard cluster as I plan on putting the Rallye cluster in the Cuda (too much Black otherwise, needs some woodgrain to dress it up).
As far as options go it is definitely an odd ball car. EB7 with the V1G top. 383 2bbl motor. Power Windows, AC, Molding Group, and AM/8-Track for the main options. I don't remember seeing the Rear Defogger on the Fender Tag, but the car had it when I bought it so I'm keeping it. The car is an LA plant car and also has California emissions.
Joe
Re: Challenger Stereo Crossover Question [Re: 71 Six Pack] #436844
08/19/09 11:48 PM
08/19/09 11:48 PM
cataclysm80 Offline
cataclysm80  Offline
Sounds like my kind of car.
I agree, it probably came with a standard dash.
Rear defog didn't require any sheetmetal changes, so it probably wouldn't be coded on the fender tag. No way to know for sure without the broadcast sheet.
I'm curious about your molding group...A63 right? What other M codes appear on the fender tag?
Tav
Re: Challenger Stereo Crossover Question [Re: cataclysm80] #436845
08/20/09 05:36 AM
08/20/09 05:36 AM
Rhode Island
Rhode Island
There is no A63, only the M21 Drip Rail Moldings code on the tag. The car has the stainless trim around the grill opening on the front valence, as well as the back of the hood and fenders, and top of the doors (belt molding).
Joe
Re: Challenger Stereo Crossover Question [Re: 71 Six Pack] #436846
08/20/09 09:22 AM
08/20/09 09:22 AM
cataclysm80 Offline
cataclysm80  Offline
That's interesting. Since those molding require alterations to the sheetmetal of the car (holes in doors & quarters), they should be on the fender tag. An SE car would have M31 on the tag, and a non-SE with that trim would have both A63 & M31 I think. I'd have to suspect they're not factory on your car, but since you've got them, might as well enjoy them. I know I would.
Does your car have the astrotone tailpanel molding (like the SE's) that also came with the A63 molding package? Does your car have rear seat ash trays?
Tav
Re: Challenger Stereo Crossover Question [Re: cataclysm80] #436847
08/20/09 04:42 PM
08/20/09 04:42 PM
Rhode Island
Rhode Island
Car was repainted so I don't know about the astrotone. No rear seat ashtrays.
Joe
Re: Challenger Stereo Crossover Question [Re: 71 Six Pack] #436848
08/20/09 05:14 PM
08/20/09 05:14 PM
cataclysm80 Offline
cataclysm80  Offline
The astrotone tail panel molding is a very large aluminum trim piece that covers all of the tail panel above the tail lights and both ends of the tail panel trim on the quarters are grafted into it. It requires extra holes all along the top edge of the tail lights for clips to hold it in place. Doesn't sound like you have it on your car. If your car ever had it, and doesn't now, then the sheetmetal holes for the trim clips would have had to be filled to keep the trunk from leaking.
Tav
Re: Challenger Stereo Crossover Question [Re: cataclysm80] #436849
09/07/12 03:12 PM
09/07/12 03:12 PM
Wisconsin
Mopar_Mudder Offline
Wisconsin
I know it is an old thread but very informative and worth bringing back.
Does anyone know what the difference it between the fader that has the 6 prong plug on the back, vrs the fade that has wires attached to it?
1971 Hemi Cuda 2005 SRT-10 Regular Cab Flame Red. 12.771 @ 109.67<---TIME SLIP--Video
Re: Challenger Stereo Crossover Question [Re: Mopar_Mudder] #436850
09/07/12 03:23 PM
09/07/12 03:23 PM
Alabama
BigMoneyLewis Offline
Alabama
The fader with dual pots , 6 wires ,is for stereo radios.
Fader with 3 wires, single pot, is for a mono radio.
Greg
gregward@mchsi.com phone 256-852-0955
Re: Challenger Stereo Crossover Question [Re: BigMoneyLewis] #436851
09/07/12 03:32 PM
09/07/12 03:32 PM
Wisconsin
Wisconsin
So any chance you can tell me which one this is?
Re: Challenger Stereo Crossover Question [Re: Mopar_Mudder] #436852
09/07/12 05:55 PM
09/07/12 05:55 PM
Alabama
Alabama
That's a mono fader .Notice It only has 3 wires going into it. It is used on AM cars with a single front and single rear speaker.
On the 1970 E body ,a stereo fader would be used with a 5 speaker system , 3 in the dash and 2 in the rear. It would require a diffrent harness as well which would include a crossover box.
Greg
Re: Challenger Stereo Crossover Question [Re: BigMoneyLewis] #436853
09/07/12 06:41 PM
09/07/12 06:41 PM
Wisconsin
Wisconsin
Greg
Thanks for the help, won't be buying that one then
Re: Challenger Stereo Crossover Question [Re: Mopar_Mudder] #436854
05/30/14 03:06 PM
05/30/14 03:06 PM
Parsippany, New Jersey
340challconvert Offline
Great old post on the wiring of challenger cuda stereos including the use of the crossover box.
thank you
340challconvert
1970 A-66 340 Challenger convertible
Re: Challenger Stereo Crossover Question [Re: 340challconvert] #2773088
05/10/20 09:04 AM
05/10/20 09:04 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
I know this is an old, old post but does anyone have a wiring schematic of the crossover box internals? I haven't been able to find a complete box and am probably going to try to make one. Thanks.
Edit: Just bought one off Ebay, I'll find out what's in it!
Page 3 of 3 1 2 3
