Re: Challenger Stereo Crossover Question
[Re: 71 Six Pack]
#436808
08/15/09 07:21 PM
08/15/09 07:21 PM
Posts: 4,165 Florida
cataclysm80
I have standard dash knob and bezel, but the switch has the wires cut. Will a rallye fader switch work if I change the knob and bezel over to correct standard dash knob and bezel?
I think it would, but I've never tried. The person to ask would be bigmoneylewis. He's a member here on moparts and is the mopar radio guru.
Thanks for the measurements!
Tav
[Re: cataclysm80]
#436818
08/15/09 09:18 PM
08/15/09 09:18 PM
Posts: 7,369 Iowa
burdar
Owen's Dad
Owen's Dad
Iowa
This turned out to be a really good thread. I saw it for a while but never looked at it until now. The speaker fader knob broke on dad's Challenger years ago. He bought an NOS knob kit somewhere but never installed it. I just happened to find it yesterday and took a look at the contense. It came with more components than I thought the car needed. I now see...by reading this thread...that the kit contains both the rallye dash and standard dash pieces.
[Re: cataclysm80]
#436819
08/15/09 11:11 PM
08/15/09 11:11 PM
Posts: 100 Rhode Island
71 Six Pack
Rhode Island
Here's the standard dash speaker fader. This is a 74 challenger, but should be the same for all years 70-74.
I'm looking for measurements for this too if you've got them.
Tav
If no one posts measurements today I will post them Sunday. I have two Standard dash bezels with the fader hole on them, one is the rare '70 only model than I am using for my car.
Joe
[Re: burdar]
#436821
08/15/09 11:25 PM
08/15/09 11:25 PM
cataclysm80
So what pieces are different? Is it just as simple as swapping the knob & bezel?
Tav
[Re: 340SIX]
#436829
08/16/09 11:29 PM
08/16/09 11:29 PM
Posts: 4,247 Alabama
BigMoneyLewis
Alabama
What did a car with 3 speaker dash and no rears come with?
All AM FM and AM 8-track stereo E body cars used a crossover box , and it's the same box weather you had 3 or 5 speakers ,if that's what you are asking. The big difference is the wiring harness , where a 5 speaker car will have a plug for the rear speaker harness as well as a plug for the fader . Those plugs are not found on a 3 speaker harness. The crossover box takes the left / right stereo channels and creates the 3rd ,center channel . The crossover also sends the lower bass sound to the center dash speaker, and the higher sounds to the outboard dash speakers.
Also , 1 last tidbit , if you are looking for a 3 speaker stereo underdash harness , and all you find is a 5 speaker, You can still use it for your 3 speaker application, however, you MUST have a fader plugged in for it to work, You can even use a C body fader (and harness for that matter) Just fade it all the way to the front speakers and leave the fader out of sight behind the dash . If you don't plug in a fader, you will get no sound at all out of your radio .
Greg
Wards Classic Car Radio Repair Specializing in restoration and sales of Mopar A B E body radios We can restore YOUR radio usually in less than 14 days Visit our NEW website.. http://www.wardsclassiccarradiorepair.com gregward@mchsi.com phone 256-852-0955
[Re: 71 Six Pack]
#436838
08/18/09 09:52 AM
08/18/09 09:52 AM
cataclysm80
I am redoing the dash in my '70 Challenger with AM/8-Track.
Hopefully you've already got these pieces? all 3 unique 70 challenger dash speaker grills
the ribbed radio surround plate to match your standard cluster bezel.
the 70 challenger dash trim with 8 track notch. That will be the toughest find I think.
If you end up needing a package tray with speaker slots, Dave Walden at ECS has the most correct ones, textured with the right # of slots. The REM ones everyone else sells are smooth and use a GM slot style. (few people would ever notice the difference, so it's up to you)
Tav
[Re: cataclysm80]
#436839
08/18/09 10:34 AM
08/18/09 10:34 AM
71 Six Pack
Rhode Island
I have almost all the pieces. I am just waiting on a rallye fader switch I purchased to come in the mail. The AM/8-Track bezel was pricey to say the least. The rear package tray in the car is original and in good shape. I am missing the correct rear defogger set up with the rear speakers though. When I bought the car the rear defogger was mounted on the support beam behind the rear seat.
The hardest thing to find is the correct labeling for the switch panel. This car has a 2-spd Wiper, and therefore a footpump washer. Finding the correct label for standard dash was difficult because I also need the rear defogger on it. I was able to use the one from my '71 Cuda for now which is also a 2spd Wiper with rear defog car. The repop labels I have seen pics of always have he Wipe/Wash when the rear defogger is there instead of just Wiper.
Joe
[Re: 71 Six Pack]
#436844
08/19/09 11:48 PM
08/19/09 11:48 PM
cataclysm80
Sounds like my kind of car. I agree, it probably came with a standard dash. Rear defog didn't require any sheetmetal changes, so it probably wouldn't be coded on the fender tag. No way to know for sure without the broadcast sheet. I'm curious about your molding group...A63 right? What other M codes appear on the fender tag? Tav
[Re: Mopar_Mudder]
#436850
09/07/12 03:23 PM
09/07/12 03:23 PM
BigMoneyLewis
Alabama
I know it is an old thread but very informative and worth bringing back.
Does anyone know what the difference it between the fader that has the 6 prong plug on the back, vrs the fade that has wires attached to it?
The fader with dual pots , 6 wires ,is for stereo radios. Fader with 3 wires, single pot, is for a mono radio.
Greg
[Re: BigMoneyLewis]
#436853
09/07/12 06:41 PM
09/07/12 06:41 PM
Posts: 374 Wisconsin
Mopar_Mudder
Wisconsin
That's a mono fader .Notice It only has 3 wires going into it. It is used on AM cars with a single front and single rear speaker. On the 1970 E body ,a stereo fader would be used with a 5 speaker system , 3 in the dash and 2 in the rear. It would require a diffrent harness as well which would include a crossover box. Greg
Thanks for the help, won't be buying that one then
[Re: 340challconvert]
#2773088
05/10/20 09:04 AM
05/10/20 09:04 AM
Posts: 10,731 North Dakota
6PakBee
North Dakota
I know this is an old, old post but does anyone have a wiring schematic of the crossover box internals? I haven't been able to find a complete box and am probably going to try to make one. Thanks.
Edit: Just bought one off Ebay, I'll find out what's in it!
