Fuel pump pressure setting #436783
08/13/09 02:33 PM
08/13/09 02:33 PM
Deerfield, Ohio
70dusterjohn Offline OP
Deerfield, Ohio
Ok so I got the new pump on the car with reg. and plumbed it all, which didn't take much. It was pretty much a throw on, only had to change one fitting.. My question is that when I set the pressure I set it running and was at 6.5 lbs. I shut the car off and then had to start it later in the night and the pressure was a hair under 6 lbs .. why the change.. I'm going to re-set it tonight when I do the valves.
Re: Fuel pump pressure setting [Re: 70dusterjohn] #436784
08/13/09 02:38 PM
08/13/09 02:38 PM
Newman, ca
Mopower_333 Offline
Mopower_333  Offline
Newman, ca
I had the same problem and it ended up being my liquid filled gauge. Once the car warmed up the pressure would drop like from 6.5 to 3. I ordered a new non liquid gauge and haven't had a problem since.
Re: Fuel pump pressure setting [Re: 70dusterjohn] #436785
08/13/09 02:39 PM
08/13/09 02:39 PM
MR_P_BODY Offline
MR_P_BODY  Offline
When you say it was 6 was that what the gauge showed
before you turned the pump on or after you turned
it on
Re: Fuel pump pressure setting [Re: Mopower_333] #436786
08/13/09 02:40 PM
08/13/09 02:40 PM
Deerfield, Ohio
Deerfield, Ohio
Mine isn't liquid filled. It was working fine with the holley blue pump, but now it seems to creep on me..
Re: Fuel pump pressure setting [Re: MR_P_BODY] #436787
08/13/09 03:22 PM
08/13/09 03:22 PM
Deerfield, Ohio
Deerfield, Ohio
I was at 6lbs with the pump on and the car running.. but I set it earlier at 6.5 while it was running...
Re: Fuel pump pressure setting [Re: 70dusterjohn] #436788
08/13/09 04:58 PM
08/13/09 04:58 PM
Deerfield, Ohio
Deerfield, Ohio
ANYONE...........
Re: Fuel pump pressure setting [Re: 70dusterjohn] #436789
08/13/09 07:20 PM
08/13/09 07:20 PM
Mo.
racerx Offline
racerx  Offline
Mo.
I've had the problem with my setup,but I'm running the Aeromotive A-1000 into a (y) block.I'v have not had much time 2 mess around with it.Actually i was thinking of getting out there within the next few days 2 flow the system 4 spray(n2o) ? Are u getting ready 2 spray?if so can u post you'r results.Thax Good Luck
