Tips for using a tow bar #436765
08/13/09 02:10 PM
08/13/09 02:10 PM
Canada
Mofopar Offline OP
Mofopar  Offline OP
Canada
Does anyone even use these anymore? I can't afford a trailer setup right now but want to get out to the track. I plan to use a minivan with a tow package to pull my Duster - any issues with weight differential? (tow vehicle too close in weight to trailing vehicle)
Aside from disconnecting the driveshaft, what else should I do to prepare for a tow? I assume the differential is OK as long as its disconnected?
Re: Tips for using a tow bar [Re: Mofopar] #436766
08/13/09 04:03 PM
08/13/09 04:03 PM
SO. CAL.
70blackfish Offline
70blackfish  Offline
SO. CAL.
dont break in corners, the car being towed will push the rear tires of the car towing. it is better to have the tow vehicle weigh more.
Re: Tips for using a tow bar [Re: 70blackfish] #436767
08/13/09 04:25 PM
08/13/09 04:25 PM
Canada
Mofopar Offline OP
Mofopar  Offline OP
Canada
It does, I just read on an RV sit that the towed vehicle shouldn't weigh more than 40% of the towing vehicle. I'm at 62%.
Thanks for the tip.
Re: Tips for using a tow bar [Re: Mofopar] #436768
08/13/09 06:07 PM
08/13/09 06:07 PM
Lehigh Acres, Florida
rickstershemi Offline
I've towed my Jeep Wrangler all over hell and back with my 1/2 ton pickup....never had a problem....forget it's there half the time
Rickster
Re: Tips for using a tow bar [Re: rickstershemi] #436769
08/13/09 07:18 PM
08/13/09 07:18 PM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
Gravel is downright not possible.....unless you lock the steering wheel.
Back in the day, I used to let the wheel float, it will follow and you can take corners.With the wheel locked, corners are a problem.
Also,
Tie into the turn signal wiring harness up front and the taillights and brake lights will work with the tow vehicle.
Add lots of stopping distance..
Re: Tips for using a tow bar [Re: Mofopar] #436770
08/13/09 09:18 PM
08/13/09 09:18 PM
City of Champions
P
Prostock Offline
Prostock  Offline
P
City of Champions
Prepare for putting a new transmission in the minivan, and prepare for a ticket if you get stopped. No way is a minivan rated to tow that kind of weight even with a tow package, and I seriously doubt you can find a class three hitch for one anyway.
Re: Tips for using a tow bar [Re: Prostock] #436771
08/14/09 08:27 AM
08/14/09 08:27 AM
Canada
Mofopar Offline OP
Mofopar  Offline OP
Canada
Huh, its rated for 3500 trailer weight and has a class II hitch installed. Its on the second tranny already (but not due to towing).
And what would I get a ticket for? I checked the local regs and I can't see a problem with it.
When I was a kid my Dad would tow his buddy's 69 Cuda to the track behind a Dodge Aspen
Re: Tips for using a tow bar [Re: Mofopar] #436772
08/14/09 02:47 PM
08/14/09 02:47 PM
Casa Grande,Arizona
DennisJ Offline
super street
DennisJ  Offline
super street
Casa Grande,Arizona
If you buy or build your own,make sure it is the longest one you can get. The longer it is the better it handles.
Dennia Jokela
I started out with nothing,and I still have most of it.
Re: Tips for using a tow bar [Re: DennisJ] #436773
08/14/09 02:56 PM
08/14/09 02:56 PM
P
Paul_Fancsali Offline
P
Leave the steering wheel unlocked but in a sharp bend make sure the front wheels on the Duster still are not at full lock with you dragging it that way. the 460 Ford that towed my Demon 340 used to do that on occasion. would not even know it till it would buck a little. Flat towing is not fun but can be done with a good bar slower speeds and common sense. I also towed cars behind my truck 318 1/2 ton and my Chrysler newport with heavy trailer tow pkg. so I know it can be done with out accidents
Re: Tips for using a tow bar [Re: Paul_Fancsali] #436774
08/14/09 09:45 PM
08/14/09 09:45 PM
Alexandria, LA
Blucuda413 Offline
Blucuda413  Offline
Alexandria, LA
Guys, back in the day most of us flat towed our race cars. Only the people with money had a trailer. Flat towed a 32 3-window altered all over Louisiana and east texas in the early days (50s & early 60s). When in hi-school I also was a driver for a large used car company. They would go on buying sprees and I would go get them with my trusty tow bar. I could tell some stories about some of those trips. Seriously, just make sure it's a good hookup and drive sensibly. You won't have any problem.
