caltracs & monoleaf users #436686
08/13/09 01:22 PM
08/13/09 01:22 PM
sweden
sshemi Offline OP
sshemi  Offline OP
sweden
Is it a must to use a bolt trough the ears on the leafs to clamp them or is it optional?
I have no idea of what spring rate i have.
Any guidelines of how to adjust the caltracs?
Car hooks without transbrake but not with.
Shocks are Koni spa that are set on the stiffest setting.
Had them looser and when on stiffest car started bouncing a couple of times from the start.
I have about 5" of front susp travel lifts really nice.
Any help would be appriciated.
Have videos but cant post them. (45 mb)
If someone could help with the videos i guess it would be easier for you guys to help me out.
Re: caltracs & monoleaf users [Re: sshemi] #436687
08/13/09 03:02 PM
08/13/09 03:02 PM
sweden
sshemi Offline OP
sshemi  Offline OP
sweden
Re: caltracs & monoleaf users [Re: sshemi] #436688
08/13/09 03:27 PM
08/13/09 03:27 PM
Deerfield, Ohio
70dusterjohn Offline
Deerfield, Ohio
I'm not understanding what bolt your talking about. As far a setting both bars left and right level with the ground, the drivers side has no slack, the passenger side is pre loaded two flats, now with footbraking the shocks are set on 7, with the brake I set it at 4.. You may have to play around with tire pressure also.
Re: caltracs & monoleaf users [Re: 70dusterjohn] #436689
08/13/09 03:55 PM
08/13/09 03:55 PM
sweden
sshemi Offline OP
sshemi  Offline OP
sweden
these ones
Re: caltracs & monoleaf users [Re: 70dusterjohn] #436690
08/13/09 04:41 PM
08/13/09 04:41 PM
Joplin, Mo
rt66jim Offline
rt66jim  Offline
Joplin, Mo
Call me a coward but there is no way I would take those clamps off mine. Jim
Re: caltracs & monoleaf users [Re: rt66jim] #436691
08/13/09 05:29 PM
08/13/09 05:29 PM
sweden
sshemi Offline OP
sshemi  Offline OP
sweden
been running without them ever since i got her running.
Re: caltracs & monoleaf users [Re: rt66jim] #436692
08/13/09 05:30 PM
08/13/09 05:30 PM
sweden
sshemi Offline OP
sshemi  Offline OP
sweden
guess no one runs without them then.
Re: caltracs & monoleaf users [Re: sshemi] #436693
08/13/09 05:55 PM
08/13/09 05:55 PM
USA
Ron Silva Offline
Ron Silva  Offline
USA
I have never heard of anyone taking those bolts out and I doubt they are intended to be removed. I would call calvert or I would put them back in.
Please tell us if they hook better or worse without the bolts and what calvert says.
SRT DEMON ONE SEAT
Re: caltracs & monoleaf users [Re: Ron Silva] #436694
08/13/09 06:02 PM
08/13/09 06:02 PM
Deerfield, Ohio
Deerfield, Ohio
From what I understand about the split monos is that those clamps are what gives them their sping rate.. Without them I'd think that it would drop that rate way down as they new the support of the other half to have a set rate.. I'd would put them back in.. Or call calvert and see what they say.. To be it defeats the idea..
