thanks for the replys, the problems I am running into stems from the fact that the car was original a 318 and now it has a 383 in it. I think that I will have to replace the radiator because the upper radiator hose is going to be where the a/c compressor mounts. As runin stated I need a new evaporator, discharge muffler and disharge lines. I've been in touch with classic and they can supply just about everything under the hood, for a price. I'm skeptical about using all old parts but unfortunately money is an object. Thanks again.
