Engine popping in the crankcase/High oil pressure #436012
08/12/09 06:05 PM
08/12/09 06:05 PM
Cochise County Arizona
SPWC Offline OP
SPWC  Offline OP
My 73 Dodge truck has issues of no power,and when accelerating it sounds like theres popping(backfiring) in the crankcase. The truck also runs 100psi of oil pressure.
None of this sounds normal.Ive checked the plugs,they all look ok. Ive replaced the cap,rotor and wires,and it still does it. Where else should I look? What could be causing all this?
Re: Engine popping in the crankcase/High oil pressure [Re: SPWC] #436013
08/12/09 06:47 PM
08/12/09 06:47 PM
BRawls Offline
super gas
BRawls  Offline
super gas
Sounds like maybe the cam is out of sync with the crank. If it's high miles, I'd be looking at the timing chain and make sure it did not jump a tooth or have to much slack, broken teeth etc.
Re: Engine popping in the crankcase/High oil pressure [Re: SPWC] #436014
08/12/09 06:50 PM
08/12/09 06:50 PM
Is it missing when you get on it? What eng, how long doing it, any new mods? I would suggest R&R ing the plugs even though they look OK they CAN be deceptive. 100 psi is too high, I'm assuming cold on startup, how long has it been that high, how much when hot at idle and at cruise. Pressure reg might be sticky/stuck. I'd put a racing filter on there just to make sure it didn't burst which 100 psi is capable of doing just that(not a for certain that it would) but for the price of one of those filters I'd want the peace of mind & if it's a BB 1st take out the reg/spring out of the pump & see what you see.
Re: Engine popping in the crankcase/High oil pressure [Re: RapidRobert] #436015
08/12/09 06:56 PM
08/12/09 06:56 PM
SPWC Offline OP
SPWC  Offline OP
Its a 400 BB in my truck. It runs 100 psi regardless of anything,(according to the gauge in the dash)
When I got the truck last week it ran like crap and I decided to tune it up. The plug wires were off 1 tower to the right(counterclockwise) it runs better,but still runs like crap,no power and stalls at stoplights. I timed it and its right about where it needs to be.
Re: Engine popping in the crankcase/High oil pressure [Re: RapidRobert] #436016
08/12/09 09:08 PM
08/12/09 09:08 PM
SPWC Offline OP
SPWC  Offline OP
It pops under load,not all the time but pretty regularly. Just flat out runs like poo and also (at times) makes a noise like if you were to tap a hammer on the driveshaft,sort of a hollow metallic sound. Could that be the chain slapping around?
Re: Engine popping in the crankcase/High oil pressure [Re: SPWC] #436017
08/12/09 10:10 PM
08/12/09 10:10 PM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
Like a rod knocking?
Re: Engine popping in the crankcase/High oil pressure [Re: SPWC] #436018
08/12/09 10:18 PM
08/12/09 10:18 PM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
Firing order right? If so...my money is on...rocker arm/pushrod issue,valve spring or....flat cam lobe!Pull the covers and have a look.
Re: Engine popping in the crankcase/High oil pressure [Re: SPWC] #436019
08/13/09 01:29 AM
08/13/09 01:29 AM
is it pinging
Re: Engine popping in the crankcase/High oil pressure [Re: RapidRobert] #436020
08/13/09 09:29 AM
08/13/09 09:29 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Did you change the oil? Timing chain may be toast!
Re: Engine popping in the crankcase/High oil pressure [Re: RapidRobert] #436021
08/13/09 10:33 AM
08/13/09 10:33 AM
SPWC Offline OP
SPWC  Offline OP
is it pinging
Now that you mention it,it may be pinging I hear.
I havent changed the oil yet. Im very frustrated with this thing,and am wondering if I want to even put anymore work into it.Im gonna set it in storage for a few days and let my frustration settle down,then try to go back and tackle it in a fresh state of mind.
Re: Engine popping in the crankcase/High oil pressure [Re: SPWC] #436022
08/13/09 10:52 AM
08/13/09 10:52 AM
Now that you mention it,it may be pinging I hear. Im gonna set it in storage for a few days and let my frustration settle down,then try to go back and tackle it in a fresh state of mind.
(1) pull/plug the vac adv or retard the initial 5-7.5 degrees & see if it stops rattling. (2) excellent plan, sometimes you just gotta step away for a bit. good luck.
Re: Engine popping in the crankcase/High oil pressure [Re: SPWC] #436023
08/13/09 12:59 PM
08/13/09 12:59 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
You should confirm the dash guage reading with a good mechanical guage connected to the engine , is the oil pump new ? also check the sender , does it like someone , or have you , replaced it ?
Re: Engine popping in the crankcase/High oil pressure [Re: JohnRR] #436024
08/13/09 04:14 PM
08/13/09 04:14 PM
SPWC Offline OP
SPWC  Offline OP
As far as replacement goes,I havent touched it. The friend I got the truck from says he never did ANYTHING to the truck in the 3 years he owned it. He got it for a good price and maybe only drove it 2X in the entire time he owned it.
Re: Engine popping in the crankcase/High oil pressure [Re: SPWC] #436025
08/14/09 08:00 PM
08/14/09 08:00 PM
Montana
P
Posest Offline
Posest  Offline
P
Montana
Sounds like a wiped lobe or broken spring?
