Sealing carb to my scoop. #435416
08/12/09 02:25 AM
08/12/09 02:25 AM
Balt. Md
3
383man Offline OP
383man  Offline OP
Balt. Md
I decided to try and seal my carb to the scoop next time I go racing. I have an 8" hole in the hood under the scoop right at the carb. I bought this nice kit that Moroso makes that you adjust to size and then rivet it together and add the foam. It turned out nice. Just curious if any racers have done this with the factory style Max Wedge scoop ?? Since it is not very tall I wonder how much air it will actually get and about how much some of you jetted up ?? Here is a pic of it on the car. Thanks , Ron
Re: Sealing carb to my scoop. [Re: 383man] #435417
08/12/09 02:27 AM
08/12/09 02:27 AM
Balt. Md
3
383man Offline OP
383man  Offline OP
Balt. Md
I pic of how tall the scoop is. Ron
Re: Sealing carb to my scoop. [Re: 383man] #435418
08/12/09 03:01 AM
08/12/09 03:01 AM
Balt. Md
3
383man Offline OP
383man  Offline OP
Balt. Md
One more pic. Ron
Re: Sealing carb to my scoop. [Re: 383man] #435419
08/12/09 04:51 AM
08/12/09 04:51 AM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
Some folks will tell you that factory scoops arent high enough. I plumbed my scoops to the carb and went 2 tenths faster (cant remember mph gained). Race it and let the car tell you.
Re: Sealing carb to my scoop. [Re: 383man] #435420
08/12/09 05:32 AM
08/12/09 05:32 AM
Florida STAYcation
dOoC Offline
The village idiot's idiot
dOoC  Offline
Florida STAYcation
THIS can be all-over-the-map. I have seen and heard of many ET and speed improvements but also some cases where it can actually hurt the car.
DEPENDS on if the scoop is in the "good-air" or not. If it is in "bad-air" .. it can actually siphon the fuel-air mixture OUT of the carb .. if the scoop is in a negative-pressure area.
Re: Sealing carb to my scoop. [Re: 383man] #435421
08/12/09 08:06 AM
08/12/09 08:06 AM
ELYRIA,OH
blownzoom440 Offline
ELYRIA,OH
the kit turned out nice.think about putting a screen in the opening to catchy the bugs.
Re: Sealing carb to my scoop. [Re: 383man] #435422
08/12/09 08:45 AM
08/12/09 08:45 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Jetting will depend on your car but I would think
2 sizes up(pri/sec) jet for MPH
Re: Sealing carb to my scoop. [Re: MR_P_BODY] #435423
08/12/09 10:15 AM
08/12/09 10:15 AM
new jersey usa
11secdart Offline
11secdart  Offline
new jersey usa
I have the same Moroso pan/kit to seal my carb to my 6 Pak scoop it works very well.
68 Dart 410 / 904
92 D150 original owner
21 Ram 1500 Quad Cab, Big Horn , Hemi ,4x4
23 Audi Q5
16 Honda HRV
Re: Sealing carb to my scoop. [Re: 11secdart] #435424
08/12/09 11:22 AM
08/12/09 11:22 AM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
Several eons ago I gained .02 and 2 mph with a sealed 6-bbl scoop vs. no seal. Same day, stepping up the jets 2 sizes. The .02/2/2 package!
Re: Sealing carb to my scoop. [Re: cudadoug] #435425
08/12/09 05:33 PM
08/12/09 05:33 PM
Balt. Md
3
383man Offline OP
383man  Offline OP
Balt. Md
Thanks for the replies. I plan to take larger jets when I try it as I plan to race as is first without it and then try it and go from there. Thanks , Ron
Re: Sealing carb to my scoop. [Re: 383man] #435426
08/12/09 06:05 PM
08/12/09 06:05 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
Ron,
i sealed my carb to the six pac hood and picked up nearly a 1/10 plus @.5-1mph.
funnily enough over the last 2 months after taking a little weight out and improving suspension i decided to play with the jetting.
up 1 jet front down 1 jet rear.
went from 11.52 to 11.41 and picked up just over 1/2 mph(118.56)
i went this way jetting as i had a light stumble@light throttle on the street and i knew it picked up in the cool air.car had been jetted to 12.2/4AFR on the dyno
will be racing the Nostalgia Nationals here in Australia this weekend.650mile drive each way - none of this girly towing stuff.
Hoping to run real fine
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: Sealing carb to my scoop. [Re: tex013] #435427
08/12/09 10:50 PM
08/12/09 10:50 PM
Balt. Md
3
383man Offline OP
383man  Offline OP
Balt. Md
Thanks for the info Tex. Sounds like our cars are real close. Whats your combo if you dont mind me asking ? Ron
