360 plug question #435145
08/11/09 08:19 PM
08/11/09 08:19 PM
Finally a HUSKER again
Moparnut426 Offline OP
Mr P sugestedthe rn12yc champion plug, what plug are you guys running in your iron headed 360 with 9.0-9.5:1 compression??
just curious I have always had great luck with champion plugs.
Kasey
Re: 360 plug question [Re: Moparnut426] #435146
08/11/09 08:33 PM
08/11/09 08:33 PM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
Autolite 3924.
Re: 360 plug question [Re: Moparnut426] #435147
08/11/09 09:01 PM
08/11/09 09:01 PM
Gilbert, AZ
Aspen7695 Offline
Aspen7695  Offline
Gilbert, AZ
My car is a bit quicker with Champion RN9YC. It has 9.7 CR in the 360.
Raul
Re: 360 plug question [Re: Moparnut426] #435148
08/11/09 09:13 PM
08/11/09 09:13 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Kasey
Or its equivalent.... he's running a 9 now and he's
having a issue with his plugs being dark.... but he
is also running 10* timing at idle 36 total, I suggested
a hotter plug and up his idle timing to 18 and
decrease his advance to keep his total timing the same
Re: 360 plug question [Re: MR_P_BODY] #435149
08/11/09 09:48 PM
08/11/09 09:48 PM
I think Im going to buy a set of the 12's, and I already have the jets to tinker with while at the track. I know more is in there, I just want to be able to get to it.
Thanks Mr P body, and everyone else for helping me with all my stupid little questions. I know u guys have the experiance racing so I like going to the source.
Kasey
Re: 360 plug question [Re: Moparnut426] #435150
08/11/09 10:25 PM
08/11/09 10:25 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Kasey
Kasey I believe your biggest issue is the 10* timing
at idle... get that up and the engine will come to life
still maintain the 36 total.... what dist are you using
Re: 360 plug question [Re: MR_P_BODY] #435151
08/11/09 10:58 PM
08/11/09 10:58 PM
I have an MSD distributor, MSD "mopar performance" box, and themp coil
Re: 360 plug question [Re: Moparnut426] #435152
08/11/09 11:36 PM
08/11/09 11:36 PM
Affton MO
Q
qwkmopardan Offline
qwkmopardan  Offline
Q
Affton MO
RN11YC4. They are made to gap at .040
Re: 360 plug question [Re: qwkmopardan] #435153
08/12/09 04:08 AM
08/12/09 04:08 AM
Autolite 3924's...champions are for lawn mowers....
Re: 360 plug question [Re: qwkmopardan] #435154
08/12/09 07:00 AM
08/12/09 07:00 AM
Upper Midwest
MoparforLife Offline
Upper Midwest
Re: 360 plug question [Re: Moparnut426] #435155
08/12/09 07:11 AM
08/12/09 07:11 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Change the bushing for the advance and you should be set,
some of the guys seem yo like the 11 plug so try them
Re: 360 plug question [Re: MR_P_BODY] #435156
08/12/09 07:38 AM
08/12/09 07:38 AM
What bushing should I put in it?
Kasey
Re: 360 plug question [Re: Moparnut426] #435157
08/12/09 07:44 AM
08/12/09 07:44 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Kasey
I dont recall what color you would need... maybe someone
will help... have you checked MSD's website
Re: 360 plug question [Re: MR_P_BODY] #435158
08/12/09 09:47 AM
08/12/09 09:47 AM
Do I want to speed up advance, or slow it down??
Kasey
Re: 360 plug question [Re: Moparnut426] #435159
08/12/09 09:53 AM
08/12/09 09:53 AM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
the black bushing will give 18* initial and 36* total. light silver and blue springs.
Re: 360 plug question [Re: mopar dave] #435160
08/12/09 11:32 PM
08/12/09 11:32 PM
Well guys, I have to say....
I put the 11 plugs in it, adjusted the MSD distributor with the black bushing, 1 light silver spring, and 1 blue spring. Checked my timming which was DEAD NUTS on 18 initial, and 36 at 3K. Holy Crap!!! This is honestly the first time the car has "come to life" I noticed imediatly it sounded crisper, and as I drove it it had better power, and felt great. I took it a few miles down the road, turned aroun, piss pownded it after a mild launch, and it was fun!! I crused into town and slowed to 25ish before getting into town, then nailed it, banged 2nd and the Mickey ET streets tore loose, and she went all sorts of sideways... KASEY LIKEY!!!
Now I just have to set my pinion angle, and get her to cool better, and we are gonna have some fun.
kasey
Re: 360 plug question [Re: Moparnut426] #435161
08/12/09 11:47 PM
08/12/09 11:47 PM
MR_P_BODY Offline
MR_P_BODY  Offline
kasey
... its magic ... glad its running better,
are you still having a heat issue
Re: 360 plug question [Re: MR_P_BODY] #435162
08/13/09 07:38 AM
08/13/09 07:38 AM
Yep, still heating, Im sure my tiny lower crank pulley dosnt help, also I Plan on building a chroud for my 16" Bee cool fan.
KAsey
Re: 360 plug question [Re: Moparnut426] #435163
08/13/09 09:00 AM
08/13/09 09:00 AM
MR_P_BODY Offline
MR_P_BODY  Offline
KAsey
Yeah a street car needs a shroud.... big difference
Re: 360 plug question #435164
08/13/09 10:20 AM
08/13/09 10:20 AM
Affton MO
Q
qwkmopardan Offline
qwkmopardan  Offline
Q
Affton MO
Mopar muscle cars left the factory with Champions. I know Chrysler got there hands in alot of pie but I don't remember them making lawn mowers. My Toro had a champion plug in it when new also. Put autolites in a Ford and AC Delco plugs in a chevy where they belong. Tried and tested Champion allways comes out on top in head to head tests with other brand spark plugs. When I get a minute I will look up a couple old mags that tested spark plugs and post them.
