Rancho shock settings? #435032
08/11/09 07:03 PM
08/11/09 07:03 PM
Newfoundland
codfish Offline OP
codfish  Offline OP
Newfoundland
I have the 9 way adjustables. #99116
Nothing on their site, and the only thing in the box, other than the shocks, were decals.
What do the settings, 1 thru 9, represent? Is setting #1 the easiest to compress, or extend?
I understand 70/30, 60/40, etc., but not these.
thanks
codfish
Re: Rancho shock settings? [Re: codfish] #435033
08/11/09 07:17 PM
08/11/09 07:17 PM
MR_P_BODY Offline
MR_P_BODY  Offline
thanks
codfish
On most shocks you will be adjusting the extension
BUT it might be tightening the compression some also,
the higher the number the harder it is to pull apart.
Maybe someone that runs those will verify this
Re: Rancho shock settings? [Re: MR_P_BODY] #435034
08/11/09 07:33 PM
08/11/09 07:33 PM
Deerfield, Ohio
70dusterjohn Offline
Deerfield, Ohio
your right mr p body it extended.. You want it as stiff ( extended ) as you can before the car spins and then back it down one. I assume this is on the cal-tracs..
Re: Rancho shock settings? [Re: 70dusterjohn] #435035
08/11/09 08:48 PM
08/11/09 08:48 PM
Newfoundland
codfish Offline OP
codfish  Offline OP
Newfoundland
Yes caltracs.
codfish
Re: Rancho shock settings? [Re: 70dusterjohn] #435036
08/11/09 09:04 PM
08/11/09 09:04 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Most of the guys that I know that run the Ranchos
have them set about 8... with some even at 9, to me
they arent that good because your AT or just short of
max and that doesnt leave any more to play with BUT
I guess they are alright for a cheaper shock... JMO
Re: Rancho shock settings? [Re: MR_P_BODY] #435037
08/11/09 09:40 PM
08/11/09 09:40 PM
They work a LOT better than the Mopar long drag shocks,which I replaced with the RS 9000's. I get best results with the #9 setting. 3200# SS springs,and 16# in the Goodyear radial slicks. RandyB
Re: Rancho shock settings? #435038
08/11/09 09:57 PM
08/11/09 09:57 PM
Deerfield, Ohio
Deerfield, Ohio
I've played with the setting over time and found that #7 is better for my car.. I did try #8 on a crappy track and went back to #7.. You'll have to play with it to find what works better for your car..
Re: Rancho shock settings? [Re: 70dusterjohn] #435039
08/11/09 10:14 PM
08/11/09 10:14 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
cal-tracs here with them shocks set on 9..every time I change them. it don't like it
Re: Rancho shock settings? [Re: VernMotor] #435040
08/11/09 10:32 PM
08/11/09 10:32 PM
MD
Kevins493 Offline
Kevins493  Offline
MD
I have mine at 4 3200lb with driver (but fairly light in the rear) 10.5 lb in the hoosier bias ply 29.5x10.5. As I understand it, they are always 50/50, but the valving changes the force applied.
Re: Rancho shock settings? [Re: Kevins493] #435041
08/12/09 05:08 PM
08/12/09 05:08 PM
PORT ALBERNI , BC., CANADA
superwrench Offline
superwrench  Offline
We've played with the settings on our car and I never really know what the car wants. The track around here is short and not prepped all that great. I was under the impression that on a loose track the shocks should be set higher (#8 or 9) and on a good track they could be set lower. Am I BASS ACKWARDS on that or what. I did turn them downto 3 and 4 one day and they seemed to work good, next weekend with nothing changed we had NO hook at all. I currently have them set on 9 for Pinks in Seattle.
Re: Rancho shock settings? [Re: superwrench] #435042
08/12/09 10:25 PM
08/12/09 10:25 PM
Newfoundland
codfish Offline OP
codfish  Offline OP
Newfoundland
Yeah, which setting gives the least resistance?
BTW, good luck in Seattle.
codfish
Re: Rancho shock settings? #435043
08/13/09 01:53 AM
08/13/09 01:53 AM
wisconSIN
Blown61 Offline
Blown61  Offline
wisconSIN
Is that the part number for the shocks??
Re: Rancho shock settings? [Re: Blown61] #435044
08/13/09 11:54 AM
08/13/09 11:54 AM
Locomotion Offline
Locomotion  Offline
That's the "series".
RS 9114 (old 5-way) and RS 99114 (new 9-way) are a direct bolt-in for A-bodies. It has the correct sized bushings top & bottom. It's best to confirm if the compressed and expanded lengths will be compatible with the ride height on your specific vehicle.
Not sure on the E & B body applications but they have different top bushings. Rancho has, or had, a detailed listing of their shock part #'s and specs to refer to. But I lost the direct link earler this year when my computer crashed.
Re: Rancho shock settings? [Re: codfish] #435045
08/13/09 12:36 PM
08/13/09 12:36 PM
organ
maximum entropy Offline
organ
i, too, have the 9 ways. they completely changed the way my car launches- much better! the ss shocks alowed WAY too much extension. as far as i can tell, the settings change compression and rebound damping. 9 on the street is uncomfortably hard, but just right on the track. i've experimented with lower settings at the track, but mine likes nine.
Re: Rancho shock settings? [Re: maximum entropy] #435046
08/13/09 12:43 PM
08/13/09 12:43 PM
an8sec70cuda Offline
Mine are set at 9 too. I probably need a better shock, but they work for now. CHIP
CHIP
'06 GMC 2500HD LBZ Duramax
