Rancho shock settings?
#435032
08/11/09 07:03 PM
08/11/09 07:03 PM
Posts: 4,247 Newfoundland
codfish
Newfoundland
I have the 9 way adjustables. #99116
Nothing on their site, and the only thing in the box, other than the shocks, were decals.
What do the settings, 1 thru 9, represent? Is setting #1 the easiest to compress, or extend?
I understand 70/30, 60/40, etc., but not these.
thanks codfish
Re: Rancho shock settings?
[Re: codfish]
#435033
08/11/09 07:17 PM
08/11/09 07:17 PM
Posts: 52,972 Romeo MI
MR_P_BODY
thanks codfish
On most shocks you will be adjusting the extension BUT it might be tightening the compression some also, the higher the number the harder it is to pull apart. Maybe someone that runs those will verify this
[Re: 70dusterjohn]
#435036
08/11/09 09:04 PM
08/11/09 09:04 PM
MR_P_BODY
Most of the guys that I know that run the Ranchos have them set about 8... with some even at 9, to me they arent that good because your AT or just short of max and that doesnt leave any more to play with BUT I guess they are alright for a cheaper shock... JMO
[Re: MR_P_BODY]
#435037
08/11/09 09:40 PM
08/11/09 09:40 PM
They work a LOT better than the Mopar long drag shocks,which I replaced with the RS 9000's. I get best results with the #9 setting. 3200# SS springs,and 16# in the Goodyear radial slicks. RandyB
[Re: VernMotor]
#435040
08/11/09 10:32 PM
08/11/09 10:32 PM
Posts: 2,379 MD
Kevins493
MD
I have mine at 4 3200lb with driver (but fairly light in the rear) 10.5 lb in the hoosier bias ply 29.5x10.5. As I understand it, they are always 50/50, but the valving changes the force applied.
[Re: superwrench]
#435042
08/12/09 10:25 PM
08/12/09 10:25 PM
codfish
Newfoundland
Yeah, which setting gives the least resistance? BTW, good luck in Seattle. codfish
#435043
08/13/09 01:53 AM
08/13/09 01:53 AM
Posts: 1,572 wisconSIN
Blown61
wisconSIN
Is that the part number for the shocks??
[Re: Blown61]
#435044
08/13/09 11:54 AM
08/13/09 11:54 AM
Posts: 5,894 Florida
Locomotion
That's the "series". RS 9114 (old 5-way) and RS 99114 (new 9-way) are a direct bolt-in for A-bodies. It has the correct sized bushings top & bottom. It's best to confirm if the compressed and expanded lengths will be compatible with the ride height on your specific vehicle.
Not sure on the E & B body applications but they have different top bushings. Rancho has, or had, a detailed listing of their shock part #'s and specs to refer to. But I lost the direct link earler this year when my computer crashed.
[Re: codfish]
#435045
08/13/09 12:36 PM
08/13/09 12:36 PM
Posts: 5,080 organ
maximum entropy
organ
i, too, have the 9 ways. they completely changed the way my car launches- much better! the ss shocks alowed WAY too much extension. as far as i can tell, the settings change compression and rebound damping. 9 on the street is uncomfortably hard, but just right on the track. i've experimented with lower settings at the track, but mine likes nine.
[Re: maximum entropy]
#435046
08/13/09 12:43 PM
08/13/09 12:43 PM
Posts: 13,375 Marion, South Carolina [><]
an8sec70cuda
Mine are set at 9 too. I probably need a better shock, but they work for now. CHIP
