MH 727 different ? #434029
08/10/09 04:30 PM
08/10/09 04:30 PM
scratchnfotraction Offline OP
ok,got a 77 or 79 440/727 from a MH
got it sitting on the engine mounts on a 85 truck frame..no cab yet
all the 727s I have seen,the tranny mount is 7" from the where the tail housing bolts to the case
this one is 5" from the case and bolts are wider apart in the housing,and the speedo plug is in front of it instead of behind it like other 727,which looks like its gonna be a PITA to hook up no matter what..
its a short shaft 727 with a bolt on yoke(detroit) u-joint 4" to out side cap to outside cap..caps are 1 1/4" round
its a longer short shaft than my sb short shaft
I will post the #s from the pan rail tonight
is this just cause its from something more than a 1 ton truck? I think it was a 10 lug beast,IIRC
not a semi but its close
will this tranny have the 4 plant gears and 5 disc clutch drum in it?
looks like I am gonna make the mount fit with some flat stock and stock 85 tranny mount to make an extetion to fit..
any better ideas?
thanks
Re: MH 727 different ? [Re: scratchnfotraction] #434030
08/10/09 05:50 PM
08/10/09 05:50 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
As long as they didn't get replaced it should have the 4 gear planets and 5 disc cltch in it.
After this many years there is only way to know for sure.
Re: MH 727 different ? [Re: WILD BILL] #434031
08/10/09 06:04 PM
08/10/09 06:04 PM
Florida STAYcation
dOoC Online penguin-006
The village idiot's idiot
dOoC  Online Penguin-006
Florida STAYcation
From what I have seen ...
4 gear planetary sets ... ferr-sure.
But a 5 disc(are you saying hemi?) front drum ? ... I have pulled-down maybe 5 of these MH-727's(and have another 4 to do) ...and I have yet to see that.
Re: MH 727 different ? [Re: dOoC] #434032
08/10/09 06:24 PM
08/10/09 06:24 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
No 5-disc drum in anything but the Hemi 727.
Re: MH 727 different ? [Re: John_Kunkel] #434033
08/10/09 06:31 PM
08/10/09 06:31 PM
Florida STAYcation
Florida STAYcation
It has been a long, Long, LONG time since I have seen a "hemi" drum in a 727 .. but didn't some of the 6 BBL cars have them ?
Re: MH 727 different ? [Re: dOoC] #434034
08/10/09 07:44 PM
08/10/09 07:44 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The '70-'71 6BBL is a Hemi trans in all but the part number, only one part is different.
Re: MH 727 different ? [Re: John_Kunkel] #434035
08/10/09 09:06 PM
08/10/09 09:06 PM
I didnt know,thats what I am asking
cant figure why the tranz mount moved???
so let me guess..I got to tear the whole thing apart and change out put shaft and tail housing to fit the 85 truck the correct way???
this is the # from the pan rail
pk3898870 5788 7642
what does it tell me???
is it diff on the tail shaft with the large yoke cause its a heavy duty thing and bigger than 1 ton??
now I need to look for another tranz
thats gonna be a set back...looking at completion about 2051 now...
Re: MH 727 different ? [Re: scratchnfotraction] #434036
08/11/09 03:21 PM
08/11/09 03:21 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
pk3898870 5788 7642
It tells you what you already know, it's from a '76-'78 truck, it's listed as used with the 400/440 and has the medium length extension housing and rear timing.
As you noted in your OP, this unit is just different enough to make it a hassle to install in a passenger car unless the tail is changed to passenger car.
