ok,got a 77 or 79 440/727 from a MH
got it sitting on the engine mounts on a 85 truck frame..no cab yet
all the 727s I have seen,the tranny mount is 7" from the where the tail housing bolts to the case
this one is 5" from the case and bolts are wider apart in the housing,and the speedo plug is in front of it instead of behind it like other 727,which looks like its gonna be a PITA to hook up no matter what..
its a short shaft 727 with a bolt on yoke(detroit) u-joint 4" to out side cap to outside cap..caps are 1 1/4" round
its a longer short shaft than my sb short shaft
I will post the #s from the pan rail tonight
is this just cause its from something more than a 1 ton truck? I think it was a 10 lug beast,IIRC
not a semi but its close
will this tranny have the 4 plant gears and 5 disc clutch drum in it?
looks like I am gonna make the mount fit with some flat stock and stock 85 tranny mount to make an extetion to fit..
any better ideas?
thanks
