overheating #433015
08/09/09 09:27 PM
08/09/09 09:27 PM
tennessee
cole63b Offline OP
cole63b  Offline OP
tennessee
just checking for some input here. i have a 360 in a dart that i drag race. it has electric fans and electric water pump. my first 2 passes of the night went good never went above 180 degrees but the 3rd pass it started out at 180 then by the end of the track only a 1/8 mile i was over 230 i shut the car down immediately but kinda confused on what happened any possibilities what could cause this. thank you
Re: overheating [Re: cole63b] #433016
08/09/09 09:37 PM
08/09/09 09:37 PM
Sherman Texas
The Shocker Offline
The Shocker  Offline
Sherman Texas
Do you have a thermostat on it? If it does i would look at it first .Did the car go lean on fuel through the run maybe ?How did it run on the last pass?
http://www.youtube.com/watch?v=ykcsXMV3vfg My Dart ,and im just getting started...
Re: overheating [Re: cole63b] #433017
08/09/09 09:38 PM
08/09/09 09:38 PM
tennessee
cole63b Offline OP
cole63b  Offline OP
tennessee
no thermostat and it ran great was the best run of the night just overheated right at the end i first thought it was i lost the belt of the electric water pump motor but it was there
Re: overheating [Re: cole63b] #433018
08/09/09 09:42 PM
08/09/09 09:42 PM
Sherman Texas
The Shocker Offline
The Shocker  Offline
Sherman Texas
This is gunna sound dumb ,but are you sure the gauge is working properly ?Did it try to boil over or did it just read hot by the gauge?
Re: overheating [Re: cole63b] #433019
08/09/09 09:50 PM
08/09/09 09:50 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Are you sure there wasnt any air in the system
Re: overheating [Re: The Shocker] #433020
08/09/09 09:54 PM
08/09/09 09:54 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
What temp did you start at on the first 2 passes? We run only 200ft stage @ 140 to 150 trap @ 180 when we shut down @ 190 we run the pump and fan for a few min till we are back at 130 to 140 and do it again I think 180 is too high to stage with
Re: overheating [Re: cole63b] #433021
08/10/09 07:38 PM
08/10/09 07:38 PM
tennessee
cole63b Offline OP
cole63b  Offline OP
tennessee
i know it isnt the gauge due to it did boil over and the car was at about 180 leaving and i had the fan and pump on could my radiator be to small and not keeping it cool enough the lowest my fan and pump will drop the car is 160 that i have seen i havent had the car long so trying to work everything out i appreciate all your guys help with this and how would i know if there was air in the system or not thanks
Re: overheating [Re: cole63b] #433022
08/10/09 08:27 PM
08/10/09 08:27 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I put a piece of clear tubing in the upper rad hose
just to see if coolant is moving.... the first time
of the year(after I drain the anti-freeze and fill
it with water and water wetter) it doesnt circulate
the coolant... once I get it up to temp and shut down
the engine I play around with it till it starts to
circulate then I can fill it up all the way.... it
does this every year.... the clear tube is one of
the best things I did for the cooling system
Re: overheating [Re: cole63b] #433023
08/12/09 09:33 PM
08/12/09 09:33 PM
tennessee
cole63b Offline OP
cole63b  Offline OP
tennessee
thanks that sounds like a great plan i think ill do that thanks everyone for there input even though it wasnt some of the things it always helps to know for the future
Re: overheating [Re: cole63b] #433024
08/13/09 12:20 AM
08/13/09 12:20 AM
If the car went faster on the last run that tells me it was making more power(or better traction) and HP makes heat You staged it hotter so it got hotter during that run, no harm no foul, IMO
