Page 7 of 12 1 2 5 6 7 8 9 11 12
Re: SB stroker options for track car [Re: AndyF] #432326
03/08/10 04:47 PM
03/08/10 04:47 PM
AndyF Offline OP
AndyF  Offline OP
Ran into one more issue with the R3 block. There is some extra material on these blocks that gets in the way of the rivet on the Cometic gaskets. So lesson learned the hard way! One new set of Cometic gaskets is on order.
Re: SB stroker options for track car [Re: AndyF] #432327
03/18/10 10:38 PM
03/18/10 10:38 PM
AndyF Offline OP
AndyF  Offline OP
Engine is on the dyno and making pulls. Seems like a nice little motor so far. Sounds really healthy, no leaks and no problems. Looks like she'll make 525/525. Lots of torque down low and carries 500 ft-lbs up to 5000 rpm. Should really make that Valiant jump out of the corners and pull hard down the straights.
Re: SB stroker options for track car [Re: AndyF] #432328
03/18/10 11:42 PM
03/18/10 11:42 PM
elmira ny
hp340nos Offline
hp340nos  Offline
elmira ny
what size carb/jetting are u using?thanks mike
Re: SB stroker options for track car [Re: hp340nos] #432329
03/19/10 01:15 AM
03/19/10 01:15 AM
AndyF Offline OP
AndyF  Offline OP
Carb in the dyno picture is a Braswell 750 high flow. I'll put the BLP 650 on there next to get dialed in. The car will run with the BLP 650 at the track. I'll also try my Holley 1000HP if I get time just to see if there is any difference in power.
Re: SB stroker options for track car [Re: AndyF] #432330
03/19/10 10:31 PM
03/19/10 10:31 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
AndyF,
How are we looking for a April 15th day in So Cal for some track time and media exposure on the car?
Re: SB stroker options for track car [Re: autoxcuda] #432331
03/20/10 01:35 PM
03/20/10 01:35 PM
auto-xr Offline
auto-xr  Offline
Sorry Steve,
I really wanted to attend SFSF4 but its's just not gonna happen this year. I considered attending with car in current form but the 1000 mi (one way) tow, and other constraints prevent it from happening. I will miss it, but hopefully have the car fully dialed in and ready for next year.
Tim W
68 Valiant- was auto-x now track day car
Re: SB stroker options for track car [Re: auto-xr] #432332
03/20/10 02:09 PM
03/20/10 02:09 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Sorry Steve,
Tim W
I figured you'd only come if the new motor was in the car and ready to go. Hopefully next time you can stretch out the new bullet on those long straights at Willow Springs.
Re: SB stroker options for track car [Re: AndyF] #432333
03/21/10 12:18 AM
03/21/10 12:18 AM
AndyF Offline OP
AndyF  Offline OP
Got some new parts from PRW the other day. Polished water pump and sheet metal valve covers. Figured some of you SB guys might be interested.
Re: SB stroker options for track car [Re: AndyF] #432334
03/21/10 12:39 AM
03/21/10 12:39 AM
AndyF Offline OP
AndyF  Offline OP
We ran the new MSD e-curve distributor on the dyno with just a coil and no ignition box. It seemed to work just fine. The e-curve is a fun ignition to play with. It has 100 different ignition curves built in. It has an electronic vacuum advance as well as electronic advance that is rpm sensitive. It also has a built in rev limiter and it can be run locked out with a start retard.
The MSD tech line recommended the 8207 coil so I fabricated a little bracket to hang it on the intake manifold mounts.
Re: SB stroker options for track car [Re: AndyF] #432335
03/21/10 10:45 PM
03/21/10 10:45 PM
Thigh-Gap Junction
@#$%&*! Offline
New user name, Same old jerk!
@#$%&*!  Offline
Thigh-Gap Junction
That GM sized distributor sure looks fat, could be a problem on some A-bodies, and B-bodies. If there is a BB version it might interfere with heads. They need to make the electronics fit into standard mopar diameter dizzy.
Re: SB stroker options for track car [Re: AndyF] #432336
07/12/10 10:40 AM
07/12/10 10:40 AM
AndyF Offline OP
AndyF  Offline OP
Getting ready to drop the new 427 into the Valiant. First step was unloading the Valiant at my shop.
Re: SB stroker options for track car [Re: AndyF] #432337
07/12/10 10:41 AM
07/12/10 10:41 AM
AndyF Offline OP
AndyF  Offline OP
We scaled the car as a first step so we can track the changes. The car should be about 100 lbs lighter with the new parts but we'll have to see how it works out.
Re: SB stroker options for track car [Re: AndyF] #432338
07/12/10 10:42 AM
07/12/10 10:42 AM
AndyF Offline OP
AndyF  Offline OP
Time to thrash.
Re: SB stroker options for track car [Re: AndyF] #432339
07/12/10 10:44 AM
07/12/10 10:44 AM
tboomer Online work
tboomer  Online Work
Car is looking great,Andy!!
Re: SB stroker options for track car [Re: AndyF] #432340
07/12/10 10:45 AM
07/12/10 10:45 AM
AndyF Offline OP
AndyF  Offline OP
Old drivetrain weighed 670 lbs. This is a 360 with iron heads and a cast iron four speed.
Re: SB stroker options for track car [Re: AndyF] #432341
07/12/10 10:48 AM
07/12/10 10:48 AM
AndyF Offline OP
AndyF  Offline OP
The 427 engine weighs 450 lbs. I don't have a drivetrain total yet but I'm thinking it will be about 600 lbs once we bolt on the trans, bellhousing, clutch, etc.
Re: SB stroker options for track car [Re: AndyF] #432342
07/12/10 11:06 AM
07/12/10 11:06 AM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
i know someone with the block ur lookin for 340 rest cheap and new
Re: SB stroker options for track car [Re: fishy340] #432343
07/12/10 01:36 PM
07/12/10 01:36 PM
AndyF Offline OP
AndyF  Offline OP
Thanks, but I'm not looking for a block. I could use a full time mechanic though to put these projects together!
Re: SB stroker options for track car [Re: AndyF] #432344
07/14/10 11:01 AM
07/14/10 11:01 AM
AndyF Offline OP
AndyF  Offline OP
Here is the 427 ready to drop into the car. Custom road race oil pan from Charlie, Quicktime bellhousing, Passon aluminum case tranny, Hughes CNC heads, TTi headers, etc.
Re: SB stroker options for track car [Re: AndyF] #432345
07/14/10 11:02 AM
07/14/10 11:02 AM
AndyF Offline OP
AndyF  Offline OP
In she goes!
