Page 4 of 12 1 2 3 4 5 6 11 12
Re: SB stroker options for track car [Re: kick_the_reverb] #432266
01/20/10 05:13 PM
01/20/10 05:13 PM
AndyF Offline OP
AndyF  Offline OP
The problem is the fact that the lifter bores are too tall so the dogbones don't work. The lifter bores would need to be shortened by about 0.200 and then this approach would work. The spider will work just fine once the dogbones were in place.
Re: SB stroker options for track car [Re: AndyF] #432267
01/21/10 12:07 AM
01/21/10 12:07 AM
Escondido, CA
kick_the_reverb Offline
Escondido, CA
Gotcha, thanks!
Ran
"Hey mister, something's wrong with your car, it idles roughly" - number one comment I got in Israel when daily driving a 70 Barracuda with a lopey cam.
Currently working on - 1966 Dodge A100 van 318/auto
Finally - disc brakes on the front.
In the plans - rear disc brakes, B&M 250 blower
Re: SB stroker options for track car [Re: AndyF] #432268
01/24/10 01:28 PM
01/24/10 01:28 PM
AndyF Offline OP
AndyF  Offline OP
Shortblock is together. Just need to sort out what cam we're going to run in this thing and then the rest of it should come together fairly quickly.
Re: SB stroker options for track car [Re: AndyF] #432269
01/27/10 03:01 PM
01/27/10 03:01 PM
Manitoba, Canada
O
Overdrive440 Offline
O
Manitoba, Canada
Will this block accept some type of roller lifter? I'm curious as I'm considering one of these blocks for my project.
Re: SB stroker options for track car [Re: Overdrive440] #432270
01/27/10 04:19 PM
01/27/10 04:19 PM
AndyF Offline OP
AndyF  Offline OP
Short story is no, you cannot use any type of roller lifter in a 340 resto block.
Long answer is yes you can after you've made all of the necessary modifications and purchased the correct parts.
Re: SB stroker options for track car [Re: AndyF] #432271
01/27/10 04:50 PM
01/27/10 04:50 PM
USA
Ron Silva Offline
Ron Silva  Offline
USA
Won't Brian's Solid Roller lifters drop in?? Or are the lifter bores too tall to clear the link bars? Maybe he has a tall version or perhaps they are made tall to begin with??
SRT DEMON ONE SEAT
Re: SB stroker options for track car [Re: Ron Silva] #432272
01/27/10 07:41 PM
01/27/10 07:41 PM
AndyF Offline OP
AndyF  Offline OP
They'll drop in once you machine away the extra head bolt bosses in the valley. If you don't own a multi-axis machining center then it isn't really a drop-in operation.
That is the tough thing about answering a question like this. To a guy like Ryan these things just bolt together! To the average guy with a Craftsman tool box and a double car garage it just isn't possible.
Re: SB stroker options for track car [Re: AndyF] #432273
01/30/10 11:40 AM
01/30/10 11:40 AM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
Nice work Andy
What did you use for the oil filter fitting? Matt
Re: SB stroker options for track car [Re: MattW] #432274
01/30/10 12:43 PM
01/30/10 12:43 PM
AndyF Offline OP
AndyF  Offline OP
I used steel fittings that are 3/8 NPT to #8 AN. I couldn't find any that went to #10 AN and I didn't want to spend the time making fittings.
Re: SB stroker options for track car [Re: AndyF] #432275
01/31/10 01:55 AM
01/31/10 01:55 AM
AndyF Offline OP
AndyF  Offline OP
This Progear timing chain setup is pretty nice stuff. First time I've used it. Got it from the guys at Hughes Engines.
I dialed in the cam even though I'm not sure I'll be able to use it. Comp is sending me some new lifters that haven't been announced yet that are supposed to work in this 340 resto block. If they don't work then the roller stuff is all going back on the shelf and I'll run a solid flat tappet cam.
Re: SB stroker options for track car [Re: AndyF] #432276
01/31/10 05:01 AM
01/31/10 05:01 AM
Rancho Cucamonga, Calif.
P
PUNK Offline
PUNK  Offline
P
Andy, from the looks of your lifter valley, the new roller lifters that are on there way will fit like a glove. The link bar is attached to the front side of the link bar support on the body which is far away from the side of the valley sides. I have the lifters and I have a resto block and they work great. Brian at IMM helped out on the design of those lifters before Comp even had a part number. Nice stuff.
10.53 @ 125mph. 1.37 60 foot. Caltracs and Monoleafs, AFCO shocks.
Heads by INDIO MOTOR MACHINE; IMM.
CP Pistons, PC Carbs.
Re: SB stroker options for track car [Re: AndyF] #432277
01/31/10 10:34 AM
01/31/10 10:34 AM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
Thanks. Where would one find these fitting? Matt
Re: SB stroker options for track car [Re: PUNK] #432278
02/03/10 06:30 PM
02/03/10 06:30 PM
Manitoba, Canada
O
O
Manitoba, Canada
Do these lifters have a Comp part number now?
Re: SB stroker options for track car [Re: MattW] #432279
02/03/10 07:25 PM
02/03/10 07:25 PM
AndyF Offline OP
AndyF  Offline OP
Standard fitting off the shelf. I use steel fittings for an application like this but some people might use aluminum. Anyplace that handles hydraulic hoses should be able to get you the fittings.
Re: SB stroker options for track car [Re: Overdrive440] #432280
02/03/10 07:25 PM
02/03/10 07:25 PM
AndyF Offline OP
AndyF  Offline OP
Not yet. I'm still waiting for them to send me a set. I'll post pictures once they arrive.
Re: SB stroker options for track car [Re: AndyF] #432281
02/03/10 08:21 PM
02/03/10 08:21 PM
Manitoba, Canada
O
O
Manitoba, Canada
Awesome. If they work nice, it might sway me to get a Magnum race block for my w5 heads.
Re: SB stroker options for track car [Re: Overdrive440] #432282
02/07/10 12:43 PM
02/07/10 12:43 PM
AndyF Offline OP
AndyF  Offline OP
Here is a picture of the new 8043-16 solid roller lifters from Comp in my 340 replacement block. The inner head bolt bosses have been machined off and the valley has gotten some work with a sanding roll to smooth it out. According to the sonic checker the valley wall is still about 0.200 thick.
Re: SB stroker options for track car [Re: AndyF] #432283
02/07/10 12:45 PM
02/07/10 12:45 PM
AndyF Offline OP
AndyF  Offline OP
The tie bar on these lifters is barely tall enough to clear the lifter bosses in the 340 replacment block. I had already cleaned up the top of the lifter bosses when I had the block in the fixture. I'm glad I did that or else these might not have cleared.
Re: SB stroker options for track car [Re: AndyF] #432284
02/07/10 12:49 PM
02/07/10 12:49 PM
AndyF Offline OP
AndyF  Offline OP
Picture of the lifters shows the feed hole for the pushrod oiling is drilled in from the side which is correct. Many of the lifter mfgs drill from the bottom which doesn't work. Not sure why some folks continue to build parts for 30 years that don't work but they do.
There is also a small EDM hole that feeds the roller. It is too small to see but it comes in off of the relief area so it should get full oil pressure all the time.
I haven't measured yet to see how much lift these can handle before exposing the oil gallery but I think it is probably a bunch.
Re: SB stroker options for track car [Re: AndyF] #432285
02/07/10 06:54 PM
02/07/10 06:54 PM
State College, PA
RyanJ Offline
moparts member
RyanJ  Offline
moparts member
State College, PA
BLP (Bo Laws) makes steel AN 3/8" to -10 & -12 like you were looking for.... About 4.4" long.
I've never been comfortable going down to -8's.
