Page 2 of 12 1 2 3 4 11 12
Re: SB stroker options for track car [Re: BPE] #432226
08/28/09 03:11 PM
08/28/09 03:11 PM
AndyF Offline OP
AndyF  Offline OP
Interesting! I just heard about a 4.125 crankshaft from K1 with the SJ Chevy pin. They do not show it in their catalog but evidently it is now a standard item.
I'm going to have to put all of this info in my next book. Jim Szilagyi's book is only a few years old but it is already out of date on these various crankshaft options. His book didn't show anything from K1 or SCAT for instance nor did he show the special crank that Hughes has.
Re: SB stroker options for track car [Re: AndyF] #432227
08/28/09 03:29 PM
08/28/09 03:29 PM
IL. Jerseyville
jg309 Offline
jg309  Offline
IL. Jerseyville
guys I've got just what you need,I've got a king billet with a set of carolla 6.00" rods with a 1.85 pin end, stroke is 3.625, crank wt. is app. 49lbs.& iut comes with rod brg.,all for $3000 if inter. pm me or call 618-806-1564 thanks jg309
Re: SB stroker options for track car [Re: AndyF] #432228
08/28/09 03:53 PM
08/28/09 03:53 PM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
Personally I don't see any reason for anyone to ever build another engine with Mopar rods in it, SB or BB. Just use the BBC or SBC rods for everything.
amen to that, puzzles me to no end
Re: SB stroker options for track car [Re: BPE] #432229
08/28/09 04:26 PM
08/28/09 04:26 PM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
How about a 4.125" stroke with a 6.200" sj chevy rod aroud 1.310 CH. With that piston it will still use a standrd ring pack, and I just happen to have the last of the prototypes in a 360 main.
Thanks to BPE,I had the opportunity to test the first one for him.Vic(sst/3040) did spend a lot of time on the assembly for me.
It is performing pretty well,and has a lot more in it,Eddy heads,flat tappet cam and 3070 pounds.
And the chassis just plain has not been up to par yet.
If I can ever get back to the track,I am confident these numbers will be improved upon.
Just wanted to give my thanks to both of them.
Re: SB stroker options for track car [Re: AndyF] #432230
09/02/09 01:05 PM
09/02/09 01:05 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
A Small Block for an A body track car (road race) IS in my future. I just have the original ring-jobbed OE bore 340 in my car. It definitely needs motor attention before But I still beat it mercilessly
I don't have a budget for $3000 cranks. I like the idea of using Chevy circle track parts to keep the costs down and the weight down and have something quick to rev. I don't/won't have a chassis to fully take advantage of 500+ HP, so I don't need the weight and costs of 500+ hp parts.
I like the idea of keeping the revs down to save the valvetrain and avoiding the oiling issues with smallblocks.
I good SB Oil pan is an issue too. When I had an acomplished road racer (12hrs Sebring) drive my car at Willow Springs, the pan just sucked dry or foamed and I had to wait 30 minutes to get the valve ticking to go away. It has just a stock unbaffled oil pan. I haven't sucked the pan dry, but I'm more a novice driver and I'm a little easier on it than he was.
I need reliability to drive 1 hour to the track at 3800 rpm, race it on the track from 8am to 5pm, then drive it home at 3800 rpm. There's enough other chassis and driving things to worry about at the track, so I don't want be fiddling with the motor.
Re: SB stroker options for track car [Re: autoxcuda] #432231
09/20/09 01:58 PM
09/20/09 01:58 PM
AndyF Offline OP
AndyF  Offline OP
Looks like I'll be getting a 340 resto block for the project so that narrows the choices down to the 340 main size.
K1 has the 4.125 and Callies has a 4.250 Dragoslayer so those seem like a couple of good candidates to use. Probably go with 4.040 or 4.060 bore size but I'll wait until I sonic the block before I make a decision there. I'll want to stick with a bore size that has a lot of ring choices.
Anyone have any other crankshaft options that I should look at?
Re: SB stroker options for track car [Re: autoxcuda] #432232
10/16/09 12:42 AM
10/16/09 12:42 AM
AndyF Offline OP
AndyF  Offline OP
I'm going with the 4.125 stroke and 6.200 SJ rods. Going to build a 427 inch small block. Heads are at Hughes getting their Stage 3 porting with the big 2.08 intake valves. The Victor 340 intake is headed off to Ryan to get some port work. I still need to make a decision on the camshaft.
The carb showed up today. It is from Bo Laws (BLP) and it is a very nice looking carb. It came with a full setup sheet and it has been carefully gone over. 1.250 venturi size for plenty of throttle response coming off the corners.
Re: SB stroker options for track car [Re: AndyF] #432233
10/30/09 12:44 AM
10/30/09 12:44 AM
AndyF Offline OP
AndyF  Offline OP
Crankshaft showed up today. 4.125 stroke. Weighs 55 lbs.
Re: SB stroker options for track car [Re: AndyF] #432234
10/30/09 12:46 AM
10/30/09 12:46 AM
AndyF Offline OP
AndyF  Offline OP
Con rods are here. 6.200 long Chevy rods with the small journal on the big end. 441/187 gram split weights. Nice ARP bolts.
Re: SB stroker options for track car [Re: AndyF] #432235
10/30/09 12:49 AM
10/30/09 12:49 AM
AndyF Offline OP
AndyF  Offline OP
Block is here also. Mancini Racing had 3 in stock so I grabbed one. P5007552AB comes finish bored to 4.040 size and has the cam bearings and freeze plugs installed. I could run it right out of the box but I think I'm going to bore it to 4.060 and build a 427 inch motor.
Re: SB stroker options for track car [Re: AndyF] #432236
10/30/09 02:01 AM
10/30/09 02:01 AM
Las Vegas, NV
dodgeboy11 Offline
dodgeboy11  Offline
Las Vegas, NV
Interesting topic here. I'm building something similiar. I have a scat 4" crank with the stage 1 lightening. Weighs in at about 53 lbs. Bobweight with the HEAVY scat H beam rods comes in at 1903 grams. Wiseco protru pistons. Heads are Edelbrock LA style with 5/16" stemmed 2.080/1.600 valves. Intake's flowing about 315 so far. Might see more but not at a lift that's worthwhile. Super victor intake, heads will be ported to a W5 port window. Compression'll be about 11.5:1. Planning on a solid roller cam with the LS1 firing order but money is an issue if I want to see this thing run in the next 5 years. T&D rockers will be a must for the RPM I expect this thing to turn. Engine should be set back so I can run the Canton rear sump road race pan and a T56 will back it up.
As to the reason why the crank companies won't change to chevy journals, it costs money to change things. The pencil pushing pansies that be don't like to spend money if they can't see the returns immediately.
As a side note, I ran a 408 with Eagle I beam rods that the bobweight came in at about 1840. Same pistons.
Re: SB stroker options for track car [Re: AndyF] #432237
10/30/09 07:37 AM
10/30/09 07:37 AM
BPE Offline
BPE  Offline
Looks good. And I liked your big block book. Thanks
Re: SB stroker options for track car [Re: dodgeboy11] #432238
10/30/09 10:18 AM
10/30/09 10:18 AM
Bitopia
jcc Offline
jcc  Offline
Bitopia
315 sounds really good, correct?
Re: SB stroker options for track car [Re: BPE] #432239
10/30/09 11:35 AM
10/30/09 11:35 AM
AndyF Offline OP
AndyF  Offline OP
Glad to hear you liked the book. Be sure to send me some pictures of your project when you have time.
Re: SB stroker options for track car [Re: AndyF] #432240
11/03/09 11:53 PM
11/03/09 11:53 PM
AndyF Offline OP
AndyF  Offline OP
ARP doesn't show a main stud kit for these 4 bolt main blocks so I called and talked to them about the project. They sent some extra studs, washers and nuts that fit perfect. Hopefully they'll go ahead and set up a kit with these parts in it so people can just order it off the shelf.
Re: SB stroker options for track car [Re: jcc] #432241
11/04/09 12:17 AM
11/04/09 12:17 AM
Las Vegas, NV
dodgeboy11 Offline
dodgeboy11  Offline
Las Vegas, NV
And totally not worth the effort when I easily hit 325 with some oval Indy heads. If I hadn't already had the heads and more time than money...
Don't have the holes milled for pushrods yet...
Chamber's shined up a bit to see if I can make a bit more power on a bit less timing.
Re: SB stroker options for track car [Re: AndyF] #432242
11/15/09 01:35 AM
11/15/09 01:35 AM
AndyF Offline OP
AndyF  Offline OP
The new bellhousing from QuickTime showed up a few days ago. Nice looking piece and it is about 12 lbs lighter than the Lakewood housing that was there.
This bellhousing has a dual bolt pattern so the stock transmission bolts on and so does a Doug Nash 5 speed. QuickTime has bellhousings for other transmissions including Richmond, Jerico, Muncie, TKO, T56, etc.
Re: SB stroker options for track car [Re: AndyF] #432243
11/16/09 04:51 AM
11/16/09 04:51 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
It Tim going to run a Richmond in his Valiant? I thought he had a 833 before? What road racing clutches are you looking at?
Re: SB stroker options for track car [Re: AndyF] #432244
11/16/09 08:16 AM
11/16/09 08:16 AM
Answering the call of the wild
ThermoQuad Online content
ThermoQuad  Online Content
Andy I am very interested in what is needed to make the quicktime b-h work without compromise as I have another [new] stroker engine to put in my pos and that b-h would be the hot ticket.
Any idea what this engine would cost?
Re: SB stroker options for track car [Re: autoxcuda] #432245
11/16/09 11:13 AM
11/16/09 11:13 AM
AndyF Offline OP
AndyF  Offline OP
No, Tim is going to run a Mopar 4 speed with the full aluminum treatment from Passon Performance. I was just doing a little mockup work with my Doug Nash while I had the parts available.
When I installed the Nash into my B body car I had to custom modify the bellhousing because nothing existed off the shelf. So I was happy to see that a person can now get a turn key solution from QuickTime.
