Re: 68 383/727 kickdown adjustment
[Re: JMCFAN]
#431554
08/08/09 05:08 PM
08/08/09 05:08 PM
Posts: 25,881 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Is the carburetor and all of the linkage stock? If so....
With the carb at warm idle and the trans lever full forward, adjust the top rod so that the rear of the slot rests against the back side of the throttle stud. Be sure there is a spring to pull the linkage forward. The linkage should start to move rearward as soon as the throttle is opened, no lost motion.
From the initial setting, the linkage can be adjusted to tune the part throttle upshift points to suit the individual. If the trans will kickdown at WOT from top gear at around 40 mph, the adjustment is OK.
[Re: John_Kunkel]
#431555
08/08/09 05:33 PM
08/08/09 05:33 PM
Posts: 2,094 New Mexico
JMCFAN
New Mexico
Thks! Quick ? "trans lever full forward" ??
68 Charger 383/ AT Green/Green VT 70 Roadrunner 383/4sp Purple/Black VT
[Re: JMCFAN]
#431556
08/08/09 07:00 PM
08/08/09 07:00 PM
John_Kunkel
Rio Linda, CA
The top lever on the transmission should be full forward when the carb is at warm idle.
[Re: John_Kunkel]
#431557
08/21/09 06:33 PM
08/21/09 06:33 PM
JMCFAN
New Mexico
Ok adjusted as above...and still cannot get secondarys or kickdown to engage...
ideas?
