68 383/727 kickdown adjustment #431553
08/08/09 04:59 PM
08/08/09 04:59 PM
New Mexico
JMCFAN Offline OP
JMCFAN  Offline OP
New Mexico
Can someone point me to easy to folllow directions to adjust kickdown? 68 Charger 4bbl 727 auto. Goes thrrough the gears very fast...will not engage 4bbl etc...
68 Charger 383/ AT Green/Green VT
70 Roadrunner 383/4sp Purple/Black VT
Re: 68 383/727 kickdown adjustment [Re: JMCFAN] #431554
08/08/09 05:08 PM
08/08/09 05:08 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Is the carburetor and all of the linkage stock? If so....
With the carb at warm idle and the trans lever full forward, adjust the top rod so that the rear of the slot rests against the back side of the throttle stud. Be sure there is a spring to pull the linkage forward. The linkage should start to move rearward as soon as the throttle is opened, no lost motion.
From the initial setting, the linkage can be adjusted to tune the part throttle upshift points to suit the individual. If the trans will kickdown at WOT from top gear at around 40 mph, the adjustment is OK.
Re: 68 383/727 kickdown adjustment [Re: John_Kunkel] #431555
08/08/09 05:33 PM
08/08/09 05:33 PM
New Mexico
JMCFAN Offline OP
JMCFAN  Offline OP
New Mexico
Thks! Quick ? "trans lever full forward" ??
Re: 68 383/727 kickdown adjustment [Re: JMCFAN] #431556
08/08/09 07:00 PM
08/08/09 07:00 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The top lever on the transmission should be full forward when the carb is at warm idle.
Re: 68 383/727 kickdown adjustment [Re: John_Kunkel] #431557
08/21/09 06:33 PM
08/21/09 06:33 PM
New Mexico
JMCFAN Offline OP
JMCFAN  Offline OP
New Mexico
Ok adjusted as above...and still cannot get secondarys or kickdown to engage...
ideas?
Re: 68 383/727 kickdown adjustment [Re: JMCFAN] #431558
08/21/09 08:47 PM
08/21/09 08:47 PM
Andrewh Offline
Andrewh  Offline
the other part of that is it should be all the way back at wot.
Re: 68 383/727 kickdown adjustment [Re: Andrewh] #431559
08/21/09 10:23 PM
08/21/09 10:23 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Have someone floor the gas and check to see if throttle cable pulls the carb open all the way.
Re: 68 383/727 kickdown adjustment [Re: stumpy] #431560
08/21/09 10:29 PM
08/21/09 10:29 PM
and take off the AP link so you are not dumping raw gas in there while you are sorting this out
