How much et loss with mufflers ?
#431412
08/08/09 01:16 PM
08/08/09 01:16 PM
Posts: 1,927 Seaford, Va
Kindafast
Seaford, Va
Just wondering how much do your cars pick up or drop off with full exhaust. I have never run mine with exhaust until yesterday and it slowed up bad. I only have 2.5" exhaust and I know that hurts it some but I didn't expect it to lose .4 in the quarter. What are some of your experences?
6.50 @105.26
Re: How much et loss with mufflers ?
[Re: Kindafast]
#431413
08/08/09 01:18 PM
08/08/09 01:18 PM
Posts: 1,413 Newark,Ohio
kissmyaspen
Newark,Ohio
thats about what mine was...
79 Dodge Aspen 12.265 at 109.75 MPH
67 Satellite NSS/E 11.83 @ 110
1968 Plymouth Road Runner 472 Hemi
3 time MOPAR NATIONALS CHAMP '03 FWD and '06 & '09 Street. '07, '10, '12 Mopar Nats runner-up Street.
[Re: kissmyaspen]
#431414
08/08/09 01:41 PM
08/08/09 01:41 PM
Posts: 17,918 Akron, Ohio
ProSport
Akron, Ohio
My last car ran 9.90 through a 3.5" X-pipe with 3.5" Magnaflows and turnouts. Very quiet and ran 9.90 the same day with open headers. The 69 Dart Has about 18" of 3.5" pipe, then 3.5" PYPES Race Pro mufflers, and soon to have turnouts. I thought it would slow the car down without a crossover pipe but in the 1/8 mile it only slowed a hundredth or less. Here's a vid with the Race Pro mufflers and bad traction. http://www.youtube.com/watch?v=bcKV5j1pG-0
[Re: Kindafast]
#431417
08/08/09 07:15 PM
08/08/09 07:15 PM
Posts: 43,157 Bend,OR USA
Cab_Burge
1969 Dart 440,727 12.23 at 109.6 with a set of 2.5 turbo mufflers feeding directly out of a set of Hooker A body (2 inch x 3.5 collectors) fenderwell headers with a short side pipe coming out in front of the rear tires. I removed the exhaust from the headers back and the car ran 11:39 ET at 117.75 MPH on the next run in a 1/4 mile My Duster had the same headers with a three inch pipes feeding to a set of Magnaflow 3.0x14 long oval muffs mounted at the rear bumper and the car only pick up .04 ET and about a 1/4 MPH increase in the 1/8 mile, probally due to the weight removal I haven't tried removing the exhaust at a 1/4 mie track yet on the Duster
[Re: G_bob]
#431420
08/09/09 03:15 AM
08/09/09 03:15 AM
Posts: 8,165 Left Coast
BobR
Left Coast
Last saturday picked up almost two tenths. 10.32-34 to 10.14. Also picked up 1.75 mph.
IMO this is about right for a full street exhaust of ANY BRAND. Anyone who does not pick up significantly is probably in need of collector extensions and/or jetting/timing changes or just isn't moving a lot of exhaust-aka not making a lot of power.
[Re: BobR]
#431422
08/09/09 09:01 AM
08/09/09 09:01 AM
Posts: 3,635 Oakland, MI
dizuster
Oakland, MI
Not necesarilly. If it's got the proper sized exhaust on it, it might not pick up anything.
My Dad's supercharged 340 car has 3.5" mufflers and tail pipes, with flowmasters, and no crossover/x-pipe. The car picks up about .04~.05 which is only due to the weight of the system...
[Re: Kindafast]
#431424
08/09/09 10:03 AM
08/09/09 10:03 AM
Posts: 5,894 Florida
Locomotion
After running open exhaust and tuning the carb for it for many years, I installed a 3" TTI X-pipe with Dynomax Ultra Flo mufflers terminating at the rear end housing. After removing 60 lbs from elsewhere in the car that the extra exhaust system weighed and tuned on the carb a bit more - going leaner actually, the car picked up at least several hundredths! (Not same day back-to-back, but using detailed record keeping.) So, despite the inconvenience when having to swap transmissions or center sections, the system has remained on the car. Just like swapping intake manifolds, cams, headers, etc., it depends on the overall package and carb tune-up. A single different part can alter jetting requirements, so only re-tuning & testing to know the best tune-up for each will provide the best comparison between the part changes. A 2.5" exhaust system would tend to be a choke-point. Going to open headers or a larger exhaust system will likely change the optimum jet sizes as well as squirters. Just different mufflers can have a similar affect because of backpressure changes. (i.e.: A current set-up is a little on the rich side, so it's not "optimized" or as fast as it could be. A change is made that would require a richer tune-up, but it's already richer than the previous set-up needed. So the results appear better than the should be.-----If the previous set-up was too lean and a change was made that needs richer jetting, then the results of the change would be worse than they should be.) Carb tuning for each change is not easy and is time consuming. But each combo, as well as tune-up, is different and that explains the wide variety of ET changes when adding, changing or removing an exhaust system - as well as other parts.
[Re: Kindafast]
#431428
08/09/09 01:17 PM
08/09/09 01:17 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Thanks for all the info. I guess with what im reading is my car is about average for exhaust vs no exhaust. Plus a real slippery track. No more exhaust for me at the track
Its all about the back pressure in the exhaust, every bend and which muffs. Some that are saying they picked up is more than likely the front pipe is helping the collector being a extension... a off the shelf header MOST times has a collector thats way too short so the pipe helps that(of course with a little to no back pressure muff)
[Re: MR_P_BODY]
#431429
08/09/09 02:11 PM
08/09/09 02:11 PM
Posts: 302 Casa Grande,Arizona
DennisJ
super street
super street
Casa Grande,Arizona
My Scamp with a 360,slowed down almost two tenths without the muffs. I installed extensions, but I didn't jet up the carb.
How much more jet do you need with open exhaust?
Dennis Jokela
I started out with nothing,and I still have most of it.
[Re: DennisJ]
#431430
08/09/09 02:18 PM
08/09/09 02:18 PM
MR_P_BODY
Dennis Jokela
Every car will vary but I normally see 2 jet sizes
[Re: MR_P_BODY]
#431431
08/09/09 08:04 PM
08/09/09 08:04 PM
BobR
Left Coast
Exactly, Mike. Kind of what I said. Some exhaust systems may bandaid a poorly designed/tuned exhaust(primary pipe too big/short-collector too big/short ect). Locomotion, I know you know what's what so I don't have an answer for you. I do know that for classes(non bracket) that don't require an exhaust very seldom is one ever used.
