Front Trans seal #431265
08/08/09 09:48 AM
08/08/09 09:48 AM
K
Kiddart Offline OP
Kiddart  Offline OP
K
Brand new trans just out of the box. front seal for converter is leaking!! what did I do wrong or is this just bad luck??? its a 904 from a very repitable shop will it go away???
Drowning in trans fluid
Kiddart
Thank you
Kiddart
Re: Front Trans seal [Re: Kiddart] #431266
08/08/09 10:07 AM
08/08/09 10:07 AM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
if its the front seal it wont go away are you sure it not venting fluid from the vent for some reason maybe overfilled
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: Front Trans seal [Re: dusturbd340W5] #431267
08/08/09 10:13 AM
08/08/09 10:13 AM
K
Kiddart Offline OP
Kiddart  Offline OP
K
no its not overfilled i an about 1/2 pint short because I thought the same thing. I just hate pulling it all apart for this. this is the only leak on the car and I am afraid to take it to the strip and drop anything on the track.
Thank you
Kiddart
Re: Front Trans seal [Re: Kiddart] #431268
08/08/09 10:14 AM
08/08/09 10:14 AM
NC
440Jim Offline
440Jim  Offline
NC
It won't get better, only worse with time.
Common causes:
1) seal to converter snout not lubricated during install
2) bad bushing in trans pump (converter rides in it, yours should be new)
3) Damaged seal during converter install (caught lip, spring popped out, etc)
4) flexplate issue
5) converter snout excessive run-out (bent, etc)
Re: Front Trans seal [Re: 440Jim] #431269
08/08/09 10:22 AM
08/08/09 10:22 AM
K
Kiddart Offline OP
Kiddart  Offline OP
K
Converter is new
What would be wrong with flex plate??
The spring could have come off thats true.
I put lube on the shaft of the converter as i always do also on the pilot to the crank.
This is all good stuff. Thanks
Thank you
Kiddart
Re: Front Trans seal [Re: Kiddart] #431270
08/08/09 10:28 PM
08/08/09 10:28 PM
Ohio
Lil Wedge Offline
Lil Wedge  Offline
Ohio
I have just been through this had the trans out 4 times, replaced pump bushing and seal, replace bushing and seal again, replaced pump, installed tracer dye, pulled apart, and found it leaking from pump seal again , pressure test converter, found my leak! weld at snout to converter, so it always looked like front seal. Optimistic thinking would be if you filled your converter and some drained as you installed it in the transmission and dripped out as you ran it. Clean it with brake clean and blow it dry and see it leaks again.
Re: Front Trans seal [Re: Lil Wedge] #431271
08/09/09 12:34 AM
08/09/09 12:34 AM
Florida STAYcation
dOoC Offline
The village idiot's idiot
dOoC  Offline
Florida STAYcation
Never actually seen a leaking hub but have heard of it several times ....
The plan ? .. is to pressure-check the converter you have. You can probably have a machine-shop do-it ... but if you have a full-coverage tight-fitting hub-cap(like the one I sell) .. you can use that with a simple tire valve.
Re: Front Trans seal [Re: dOoC] #431272
08/09/09 02:14 AM
08/09/09 02:14 AM
I had a unknown brand "Hi Po" swap meet conveter that had the hub welded in about .003 out of center, it only leaked when it was running
