I tried Pennzoil Synchromesh #429657
08/06/09 12:47 AM
08/06/09 12:47 AM
Overland Park, KS.
Joshs68 Offline OP
Joshs68  Offline OP
Overland Park, KS.
And now I am enjoying a very smooth shifting transmission. I drained my trans today and filled it with Pennzoil Synchromesh. After a 15 mile cruise around town , zero to 6500 rpm (nebraska's not very crowded) I am happy to report it shifted alot smoother, upshift and downshift.
Re: I tried Pennzoil Synchromesh [Re: Joshs68] #429658
08/06/09 01:01 AM
08/06/09 01:01 AM
S. Il. U.S.A.
5spdcuda Offline
5spdcuda  Offline
S. Il. U.S.A.
I run it in the Cuda's TKO and it works as well as anything could. I use ATF in my Mustang's T-5 since that's what Ford and Tremec both advise for T-5's. These transmissions are similar in design, but T-5's use a different synchro material.
Re: I tried Pennzoil Synchromesh [Re: Joshs68] #429659
08/06/09 12:33 PM
08/06/09 12:33 PM
Martinsville, VA
440child Offline
440child  Offline
Martinsville, VA
Hey Josh, what type of trans do you have in your car?
Re: I tried Pennzoil Synchromesh [Re: 440child] #429660
08/06/09 02:47 PM
08/06/09 02:47 PM
Motor City
73Convertriple Offline
Motor City
Is there any different "grade" ie. 80/90 to the synchromesh. I would like to drain my 73 a-body trans and try the synchromesh. How many quarts will I need?
Re: I tried Pennzoil Synchromesh [Re: 440child] #429661
08/08/09 02:35 PM
08/08/09 02:35 PM
Overland Park, KS.
Joshs68 Offline OP
Joshs68  Offline OP
Overland Park, KS.
stock 833
Re: I tried Pennzoil Synchromesh [Re: 73Convertriple] #429662
08/08/09 02:39 PM
08/08/09 02:39 PM
Conway, SC
T2R9 Offline
T2R9  Offline
Conway, SC
I changed to synchromesh from atf when I did my engine swap. I am very happy with how it shifts . Mine took 3 1/2 quarts.
Re: I tried Pennzoil Synchromesh [Re: Joshs68] #429663
08/08/09 02:39 PM
08/08/09 02:39 PM
Overland Park, KS.
Joshs68 Offline OP
Joshs68  Offline OP
Overland Park, KS.
no, it only comes in one flavor. It was recomended by some much smarter people than me so I tried it. mine also took 3.5 qurts/8.5 pints
Re: I tried Pennzoil Synchromesh [Re: Joshs68] #429664
08/09/09 06:07 PM
08/09/09 06:07 PM
At a gas station near you
badblack68 Offline
badblack68  Offline
stock 833
23 spline or 18 spline? Also, where did you find the Pennzoil synchromesh?
Re: I tried Pennzoil Synchromesh [Re: badblack68] #429665
08/09/09 07:39 PM
08/09/09 07:39 PM
Motor City
Motor City
Thanks for the headsup on the " 1 grade" info.
My dart sport has regular gear lube and sometimes when driving it like it was designed for (HARD ) I get a little noise in the 1-2 shift. I'll switch over and see what happens.
Re: I tried Pennzoil Synchromesh [Re: Joshs68] #429666
08/09/09 09:22 PM
08/09/09 09:22 PM
N
NITROUSN Offline
NITROUSN  Offline
N
8.5 pints
8.5 pints equals 4.25 quarts.
Re: I tried Pennzoil Synchromesh [Re: NITROUSN] #429667
08/09/09 10:53 PM
08/09/09 10:53 PM
Not2farfromNashville, TN
Rug_Trucker Offline
Rug_Trucker  Offline
I was told to use Castrol synthetic. Didn't find it. I put Mobil1 in. Now if I could finish the swap.
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
Re: I tried Pennzoil Synchromesh [Re: Rug_Trucker] #429668
08/10/09 10:42 AM
08/10/09 10:42 AM
Penguin Country
moepwr Offline
moepwr  Offline
Penguin Country
My manual says 7.5 pints which equals about 3.75 quarts
1969 Road Runner Bench seat, four speed 1999 Dodge Ram 1500 http://picasaweb.google.com/moeville
Re: I tried Pennzoil Synchromesh [Re: moepwr] #429669
08/10/09 12:06 PM
08/10/09 12:06 PM
Overland Park, KS.
Joshs68 Offline OP
Joshs68  Offline OP
Overland Park, KS.
yes I was incorrect about the conversion, it is not 3.5 quarts
this is from the 68 dodge service manual, it has two columns one for U.S. measure and one for imperial measure.
I got it at autozone its not a hard to find item.
Re: I tried Pennzoil Synchromesh [Re: Joshs68] #429670
08/10/09 12:43 PM
08/10/09 12:43 PM
Eugene, Oregon
minivan Offline
minivan  Offline
Eugene, Oregon
Not to OT this topic but back in 72/73 I changed my 18 splines fluid and the service manual said to use 140 wt gear oil.. Man was that a slow shifting, gear missing tranny....
Re: I tried Pennzoil Synchromesh [Re: minivan] #429671
08/10/09 01:08 PM
08/10/09 01:08 PM
Overland Park, KS.
Joshs68 Offline OP
Joshs68  Offline OP
Overland Park, KS.
same manual,
