rocker arm stud torque w/ aluminum heads? #428706
08/04/09 05:51 PM
08/04/09 05:51 PM
NC
rickmoore69 Offline OP
NC
Just about finished putting a 440 together with aluminum heads. Got studs for the rockers/shaft. What should I torque the studs to? nuts on the studs to?
Re: rocker arm stud torque w/ aluminum heads? [Re: rickmoore69] #428707
08/04/09 07:04 PM
08/04/09 07:04 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I have mine at 25 ft lbs.Rocky
Chrysler Firepower
Re: rocker arm stud torque w/ aluminum heads? [Re: rickmoore69] #428708
08/04/09 07:53 PM
08/04/09 07:53 PM
AndyF Offline
AndyF  Offline
Do not torque the studs, finger tight only.
Re: rocker arm stud torque w/ aluminum heads? [Re: rickmoore69] #428709
08/05/09 09:56 AM
08/05/09 09:56 AM
Washington, IL
Hughes Offline
Hughes  Offline
Washington, IL
Teh studs should not even been ran in tight. We usually leave them backed off from the bootom just a little. If you want to you can put just a little mild thread locker on the stud but I would not use much. I would also use the thread lock primer first. Then torque the nut down on the stud to about 28 ft-lb.
Kevin @ Hughes
