? trimming Duster Qtr panels for tire clearance #427518
08/03/09 04:28 PM
08/03/09 04:28 PM
On the parachute mount
N
n20mstr Offline OP
n20mstr  Offline OP
N
I have trimmed many Darts, i usually go right up to the rocker panel end. On a dart you dont need any clearance on the back since the wheel opening tapers back...
Now i am building my sons duster and im thinking about trimming the qtrs. We are expecting to run 295 drag radials or 29.5 Ws (basically a 30") tire.
Is is common to trim the front and the REAR of the opening??
....BAD A$$ STREET CAR.....
Re: ? trimming Duster Qtr panels for tire clearance [Re: n20mstr] #427519
08/03/09 05:35 PM
08/03/09 05:35 PM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
yes
you need to trim the front lowwer quarter panel about 1 inch , mine is flush with the wheel well
also need to roll the wheel well lip in
1.39 9.85 - 137 mph
Re: ? trimming Duster Qtr panels for tire clearance [Re: Ari440] #427520
08/03/09 05:37 PM
08/03/09 05:37 PM
N
n20mstr Offline OP
n20mstr  Offline OP
N
Ari...i see you trimmed the front, BUT what about the rear part?? Is the rear trimmed on your car or just the front part?? WHat size tire on there?
Re: ? trimming Duster Qtr panels for tire clearance [Re: n20mstr] #427521
08/03/09 05:40 PM
08/03/09 05:40 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
It all depends how high you want the car to sit. If you want it to sit low, you need to cut the front and the rear.
If you're ok with it sitting up a little, you actually don't need to trim either. You can just move the axle back about 3/4" and it will fit...
Re: ? trimming Duster Qtr panels for tire clearance [Re: n20mstr] #427522
08/03/09 05:43 PM
08/03/09 05:43 PM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
didnt trim the back
the tires are mt,s sportmans 28 12.5 in the first pic
mt,s slicks 29.5 10.5 15 on a 15 -10 5inch backspace in this pic
1.39 9.85 - 137 mph
Re: ? trimming Duster Qtr panels for tire clearance [Re: Ari440] #427523
08/03/09 05:45 PM
08/03/09 05:45 PM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
this is stock spring location , caltrac setup
1.39 9.85 - 137 mph
Re: ? trimming Duster Qtr panels for tire clearance [Re: n20mstr] #427524
08/03/09 05:56 PM
08/03/09 05:56 PM
Phoenix, Arizona
HerboldRacing Offline
Phoenix, Arizona
I have a 73 duster running 29.5 x 10.5's. The 1/4 panel front of the tire has been cut when I bought the car. Raced it for about a year that way. Now I am in the process of making the wheel well bigger and still retain the stock look. I am thinking of putting in the same tire or going with 30 x 9's. If I go with the 10.5's I'm going to have to narrow the axle about 1 inch each side. I've got lots of pictures and details on my blog.
No you don't have to do anything to the 1/4 panel behind the tire - theres plenty of room there. Its only the front that has problems because Ma Mopar decided to make the 1/4 panels curve inwards towards the tire there... :-(
Marvin Herbold 1973 Plymouth Duster 340 Drag Car Blog - http://www.HerboldRacing.com Videos - http://www.YouTube.com/mherbold Pictures - http://gallery.herbold-family.com/main.php?g2_itemId=10331
