Re: Whats the trick to bending steel fuel/trans lines?
[Re: 65Valiant]
#426996
08/03/09 08:26 AM
08/03/09 08:26 AM
Posts: 15,487 Florida
scratchnfotraction
a "ridged" (brand name) cast alum tubing bender 1/2"-3/8-5/16 tubes in one bender works best PVC pipes and pullys will work but the bender will make nice tight bends with no kinks
[Re: 65Valiant]
#426998
08/03/09 10:40 AM
08/03/09 10:40 AM
Posts: 25 Delaware
crazy4carz
Delaware
Ill try that on another test piece, yet I need to make some tight bends
anyone wanna let me borrow a high end bender?
Where are you? I have several benders as well as nice double flare equipment.
[Re: 65Valiant]
#427004
08/03/09 03:21 PM
08/03/09 03:21 PM
RapidRobert
If the radius you are after is making it kink I'd (as said) fill it w something & (carefully) heat it as you bend it w the bender that supports it on 3 sides. grab a helper.
[Re: 65Valiant]
#427014
08/13/09 09:50 AM
08/13/09 09:50 AM
Posts: 199 douglasville,ga
ramrod
douglasville,ga
Maybe the tubing you are using is the problem? 5/16 is pretty easy to bend, and that Imperial bender should bend 5/16 to 180* with no problem. I've never used "double wall" steel line in an automotive application, and hardware store tubing might not be the same temper as "automotive" tubing. Buy some tubing from a car parts store and try that. Also, if you have to flare the tube, use a double-flare and ALWAYS REMEMBER TO PUT THE NUT ON THE TUBE BEFORE YOU FLARE IT! It sucks to make a perfectly bent line only to realize that you forgot to put the nuts on before you flared it!
"That Plymouth had a Hemi with a Torqueflite."
-Driver
