Whats the trick to bending steel fuel/trans lines? #426993
08/03/09 01:46 AM
08/03/09 01:46 AM
65Valiant Offline OP
super street
super street
Needed to make bend some 5/16" steel line purchased from the hardware store for my trans cooler and my carb-to-pump line as well, yet whats the trick?
I have a handheld bender but when trying to do a 90 degree bend the line kinked real bad!...this cannot be good for flow...it seems to bend by hand but im looking for some nice 90 degree bends to match my brake lines, etc
any help would be much appreciated,
Re: Whats the trick to bending steel fuel/trans lines? [Re: 65Valiant] #426994
08/03/09 02:33 AM
08/03/09 02:33 AM
Western Michigan
68Fastback Offline
68Fastback  Offline
Western Michigan
Try rolling it over a inch or bigger socket, put one end of the tube in a vise and slowly roll over the socket.
Re: Whats the trick to bending steel fuel/trans lines? [Re: 68Fastback] #426995
08/03/09 03:28 AM
08/03/09 03:28 AM
super street
super street
Ill try that on another test piece, yet I need to make some tight bends
anyone wanna let me borrow a high end bender?
Re: Whats the trick to bending steel fuel/trans lines? [Re: 65Valiant] #426996
08/03/09 08:26 AM
08/03/09 08:26 AM
scratchnfotraction Offline
a "ridged" (brand name) cast alum tubing bender
1/2"-3/8-5/16 tubes in one bender
works best
PVC pipes and pullys will work
but the bender will make nice tight bends with no kinks
Re: Whats the trick to bending steel fuel/trans lines? [Re: scratchnfotraction] #426997
08/03/09 08:45 AM
08/03/09 08:45 AM
Az
Crizila Offline
Crizila  Offline
Az
works best
but the bender will make nice tight bends with no kinks That's what I use too. No kinks, even with stainless tubing.
Fastest 300
Re: Whats the trick to bending steel fuel/trans lines? [Re: 65Valiant] #426998
08/03/09 10:40 AM
08/03/09 10:40 AM
Delaware
crazy4carz Offline
crazy4carz  Offline
Delaware
Where are you? I have several benders as well as nice double flare equipment.
Re: Whats the trick to bending steel fuel/trans lines? [Re: crazy4carz] #426999
08/03/09 10:56 AM
08/03/09 10:56 AM
Urbana, MD
bordin34 Offline
bordin34  Offline
Urbana, MD
You could try filling the line with salt while bending it if you can get it all out afterwards.
Re: Whats the trick to bending steel fuel/trans lines? [Re: bordin34] #427000
08/03/09 11:25 AM
08/03/09 11:25 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
I've used all sorts of tube benders, from external springs to hydraulic powered units with changable dies.. For brake, fuel & trans lines I usually prefer this cheap style unit...
Re: Whats the trick to bending steel fuel/trans lines? [Re: 1_WILD_RT] #427001
08/03/09 11:43 AM
08/03/09 11:43 AM
New Mexico
74Scamp Offline
74Scamp  Offline
New Mexico
I have, in the past, held the line over my gas stove to heat it up a bit - don't know if that was the right thing to do, but it worked.
Re: Whats the trick to bending steel fuel/trans lines? [Re: 65Valiant] #427002
08/03/09 11:57 AM
08/03/09 11:57 AM
So Cal
HealthServices Offline
Why would you even post that?
So Cal
One of these cheapies should be more than enough for 5/16 inless you have some type rigid hard line not made to be bent
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
Re: Whats the trick to bending steel fuel/trans lines? [Re: HealthServices] #427003
08/03/09 03:11 PM
08/03/09 03:11 PM
super street
super street
Im in california,
thanks for all the feedback everyone,
I kept kinking the line (or making little indentations) with the line i bought from the local hardware store when i was practicing some 75 degree bends...maybe it needs to be double wall tubing
round bends are ok but anything at a harsh angle and i get a kink...sounds like the tubing to me
Re: Whats the trick to bending steel fuel/trans lines? [Re: 65Valiant] #427004
08/03/09 03:21 PM
08/03/09 03:21 PM
If the radius you are after is making it kink I'd (as said) fill it w something & (carefully) heat it as you bend it w the bender that supports it on 3 sides. grab a helper.
Re: Whats the trick to bending steel fuel/trans lines? [Re: RapidRobert] #427005
08/03/09 03:46 PM
08/03/09 03:46 PM
IMO the ridged alum bender is best
there are cheaper ones that are the same also,the in the pic is a good one also
never kinked any I did with the bender,just bend it slow and steady,it will bend a 90* bend thats about 1.5" in the middle,thats a tight bend and used it on my fuel pump
I use the ready steel line that has 2 flare nuts and cut one end off
Re: Whats the trick to bending steel fuel/trans lines? [Re: 65Valiant] #427006
08/03/09 04:28 PM
08/03/09 04:28 PM
Western Michigan
68Fastback Offline
68Fastback  Offline
Western Michigan
Where in California are you.
Re: Whats the trick to bending steel fuel/trans lines? [Re: 68Fastback] #427007
08/03/09 04:40 PM
08/03/09 04:40 PM
michigan woods
imfixinmopars426 Offline
michigan woods
get one of these,i think imperial makes them,and snap-on sells them too. i like it ,works good,imho.
Re: Whats the trick to bending steel fuel/trans lines? [Re: imfixinmopars426] #427008
08/03/09 04:57 PM
08/03/09 04:57 PM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
I had a 90 coming off the fuel pump on my pickup and even with the bending tool it still wanted to kink on me. I ended up bending it in stages. I would move it with the tool a little and then set it on the floor and very gently tap on the side of the radius with a rubber mallet. Using the hammer kept it from flattening out and developing the dreaded kink. It took way longer than it should have, but it came out nice and round like it's supposed to.
On the larger bends I just bend the tubing over my knee.
Re: Whats the trick to bending steel fuel/trans lines? [Re: Neil] #427009
08/03/09 06:07 PM
08/03/09 06:07 PM
super street
super street
thanks all,
los angeles (redondo beach)
ive got a 3 piece metal one from advance auto and that multiple sized hand grippy one in the image up at the top of this post as well,
Re: Whats the trick to bending steel fuel/trans lines? [Re: 65Valiant] #427010
08/03/09 06:41 PM
08/03/09 06:41 PM
Western Michigan
68Fastback Offline
68Fastback  Offline
Western Michigan
I have those same benders too and if you were closer and did not have I could let you try them. Kinda wondering about the lines you have, they should not kink easily but good tips here to try.
Re: Whats the trick to bending steel fuel/trans lines? [Re: 68Fastback] #427011
08/03/09 07:03 PM
08/03/09 07:03 PM
Virginia
MACDiesel Offline
MACDiesel  Offline
Virginia
Slow and smooth is key! I was trying to bend up some 3/8" aluminum and kept kinking it. I asked one of our hydraulics guys at work what the trick is. He said go as slow as you can and as smooth as you can. Sure enough he was right. I have the black imperial bender pictured above and now I bend tube like a pro. One of my own personal tricks is to put one leg of the bender in a vise. Its much easier to stop the jerking that way... clean kink free bend every time.
-1967 Belvedere II 440/4speed
Re: Whats the trick to bending steel fuel/trans lines? [Re: MACDiesel] #427012
08/12/09 10:24 PM
08/12/09 10:24 PM
super street
super street
Update:
I am using that imperial bender pictured above and got some double wall steel line,
Filled with sand/salt and could get 45 degree bends going super slow
anything more than that and it started kinking/compressing
thanks all for the help, almost just easier to bend over my knee!
