Re: Whats the trick to bending steel fuel/trans lines? [Re: 65Valiant] #427013
08/12/09 11:20 PM
08/12/09 11:20 PM
ILL
mark7171 Offline
mark7171  Offline
ILL
The trick? A torch. Use the correct bender.
The inner integrity can be hydrualicly maintained by a liquid trapped in the line.
Re: Whats the trick to bending steel fuel/trans lines? [Re: 65Valiant] #427014
08/13/09 09:50 AM
08/13/09 09:50 AM
douglasville,ga
ramrod Offline
ramrod  Offline
douglasville,ga
Maybe the tubing you are using is the problem? 5/16 is pretty easy to bend, and that Imperial bender should bend 5/16 to 180* with no problem. I've never used "double wall" steel line in an automotive application, and hardware store tubing might not be the same temper as "automotive" tubing. Buy some tubing from a car parts store and try that. Also, if you have to flare the tube, use a double-flare and ALWAYS REMEMBER TO PUT THE NUT ON THE TUBE BEFORE YOU FLARE IT! It sucks to make a perfectly bent line only to realize that you forgot to put the nuts on before you flared it!
"That Plymouth had a Hemi with a Torqueflite." -Driver
Re: Whats the trick to bending steel fuel/trans lines? [Re: ramrod] #427015
08/13/09 10:03 AM
08/13/09 10:03 AM
Bradenton, Fl 34203
Kilroy was here Offline
Bradenton, Fl 34203
Filled with sand/salt and could get 45 degree
I tried that before, seemed to help.
Re: Whats the trick to bending steel fuel/trans lines? [Re: Kilroy was here] #427016
08/13/09 01:49 PM
08/13/09 01:49 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Like above,these will bend anything without collapsing if you use good tubing,stainless or steel makes no difference.The small one will bend 1/8,3/16 and 1/4 inch with no problems.Also,it will bend a shorter radius than any others I have or tried.If you can't find them (Imperial Eastman) at an auto parts store,most all commercial refrigeration suppliers stock Imperial.
Re: Whats the trick to bending steel fuel/trans lines? [Re: 62maxwgn] #427017
08/13/09 08:07 PM
08/13/09 08:07 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Mine is like the Imperial in a earlier post, never kinked a line. One of the things I do is to put a little oil on the handle portion of the bender, the part that bends the tube around the radius.
Re: Whats the trick to bending steel fuel/trans lines? [Re: justinp61] #427018
08/13/09 08:42 PM
08/13/09 08:42 PM
Richmond Va, KeislerTKO 60...
V
VanishPt Offline
VanishPt  Offline
V
the "Ridgid' line works well.
Re: Whats the trick to bending steel fuel/trans lines? [Re: VanishPt] #427019
08/13/09 10:44 PM
08/13/09 10:44 PM
scratchnfotraction Offline
ridgid brand
