Re: My 40 dodge tudor sedan
[Re: plmczy]
#423408
07/30/09 07:06 PM
07/30/09 07:06 PM
Posts: 12,481 Chino Valley
RodStRace
Chino Valley
Thanks for the pics! My other frame had a GM clip too, that's why I went with the frame I did. It was also narrowed, making it useless! Looks like a good start, and the steering wheel looks nice, even though it came from the dark side. I see that you haven't mounted the master cylinder yet. Are you going up on the firewall or under the floor? Are you going to change the wheel bolt pattern on one end or the other to match?
[Re: plmczy]
#423413
07/31/09 06:57 PM
07/31/09 06:57 PM
RodStRace
Chino Valley
Did they narrow yours so the wheels didn't stick out? later shawn
I guess so. The track is okay, but when you do that, the center of the frame cuts into oil pan room and the center link of the steering needs to be narrowed too. It's a mess, which is why it's under the parts body.
