LOKAR again. #423112
07/29/09 05:13 PM
07/29/09 05:13 PM
duals Offline OP
duals  Offline OP
I sort of have the carb hook up figured out, not as pretty as it could be but I think it will work, the directions say to bolt the other end to tail housing mounting bolt, now I am doing rhis laying under the car that is on front ramps, I think this bolt they are talking about has been torqued good. Most of my sockets are the ones with many indents, really need one with the fewer number, any way any ideas how to get this dang bolt out so I can mount the rear part of the cable.
Re: LOKAR again. [Re: duals] #423113
07/29/09 05:51 PM
07/29/09 05:51 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Righty tighty,lefty loosey. Never needed more than a socket and ratchet or a boxend wrench.
Re: LOKAR again. [Re: stumpy] #423114
07/29/09 06:03 PM
07/29/09 06:03 PM
duals Offline OP
duals  Offline OP
Probably alot younger than me !! Almost 62 and a kidney transplant receipient a year ago. I know just do it. Thanks
Did you use the multi grooved socket or not.
Re: LOKAR again. [Re: duals] #423115
07/29/09 06:07 PM
07/29/09 06:07 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
"Again" being the operative word.
Re: LOKAR again. [Re: duals] #423116
07/29/09 06:24 PM
07/29/09 06:24 PM
Piqua, Ohio
dodgeram440 Offline
dodgeram440  Offline
Piqua, Ohio
This is killing me... The correct term for the sockets and wrenches you are describing are 12 point or 6 point. The fact that you don't know this tells me you are in over your head and you should find some local help. If you are determined to do this yourself, get some 6 point sockets. If you wanna round off (strip) a fastener (bolt or nut), use a cheap 12 point socket. Garranteed to strip it every time. A good quality 6 point tool will get the job done. If it's really tight, you may need to add some additional leverage, but use caution. Using two tools together for added leverage can lead to busted knuckles.
Re: LOKAR again. [Re: dodgeram440] #423117
07/29/09 06:36 PM
07/29/09 06:36 PM
duals Offline OP
duals  Offline OP
Man wish I was as smart as you as far as the correct name for the sockets, don"t need your help anymore, don't bother.I thought on this site it was a simple question, brings out simple people.
Re: LOKAR again. [Re: duals] #423118
07/29/09 09:00 PM
07/29/09 09:00 PM
scratchnfotraction Offline
man,some people
never had a dad,but had uncles,wish I was close I would do it for ya pops
the socket with many dents will work,just got to be carfull,being a little strong and younger dont hurt..never had a problem using the wrong terms but know how to use tools,12 points is just as good,as a 6 point,yes 6 points grabs better..must be nice to not do it the hard way
we are all one tool away from greatness
is it a tail shaft housing bolt?
try a little cheater bar,maybe,going to a 1/2" drive might help you leverage it better
got an air gun?I use a 3/8 drive one to take stuff loose,if that dont work I jump on it with the 1/2"drive gun
if all else fails..like usally does..I use leverage
OH!,"again"..would be the skoolin on correct terminology...its a throttle control cable ya workin on..
and Bouchillon works better was the
Re: LOKAR again. [Re: duals] #423119
07/29/09 10:24 PM
07/29/09 10:24 PM
Piqua, Ohio
dodgeram440 Offline
dodgeram440  Offline
Piqua, Ohio
My apologies for insulting your intelligence. That was stupid of me.
You really answered your own question in your first post-you need a socket with "fewer indents", which I tried to explain in my previous post. While 12 point sockets will work fine in many circumstances, when working with stuborn bolts, a 6 point socket provides superior grip to get the bolt loose. And like I said before, leverage is key. I know it's difficult laying on your back underneath a car, but that is where creativity comes in. Been there, done that. You just gotta look at the situation and figure out what you need to do to get the job done. Unfortuantely for you, there is nothing that we can do online that will get that bolt out for you.
Good luck.
Re: LOKAR again. [Re: duals] #423120
07/29/09 10:30 PM
07/29/09 10:30 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Did you use the multi grooved socket or not. [/quote
Sorry Duals, I am older than you and an amputee with four fused vertabrea. I used a 6 point socket.
Re: LOKAR again. [Re: stumpy] #423121
07/30/09 09:37 AM
07/30/09 09:37 AM
duals Offline OP
duals  Offline OP
Thank you to everyone for the return remarks, I had to use a 6 point socket and a breaker bar to get the housing bolt loose. Again thank you for the help. Feeling better about Moparts again
Re: LOKAR again. [Re: duals] #423122
07/30/09 09:46 AM
07/30/09 09:46 AM
CHRGR69 Offline
CHRGR69  Offline
God forbid you use the wrong terminology on this website! They will fry you !
Grandma always said I had "hands of gold"!
Re: LOKAR again. [Re: duals] #423123
07/30/09 09:49 AM
07/30/09 09:49 AM
Piqua, Ohio
dodgeram440 Offline
dodgeram440  Offline
Piqua, Ohio
With the right tools and some effort, you can get anything done.
Re: LOKAR again. [Re: CHRGR69] #423124
07/30/09 10:14 AM
07/30/09 10:14 AM
ruff crowd sometimes no doubt
