Clutch pedal "over center spring" #423040
07/29/09 03:54 PM
07/29/09 03:54 PM
Elizabethtown, KY
6T9Hemi Offline OP
6T9Hemi  Offline OP
Elizabethtown, KY
What's the best way to get the over-sized spring back on the clutch pedal?
1969 340 4 Speed Swinger R4,
black vinyl, white butt stripe, 3:91
Re: Clutch pedal "over center spring" [Re: 6T9Hemi] #423041
07/29/09 04:27 PM
07/29/09 04:27 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Stretch it with a floorjack and put wedges between the coils.
Re: Clutch pedal "over center spring" [Re: 6T9Hemi] #423042
07/29/09 04:29 PM
07/29/09 04:29 PM
Warren, MI
71TA Offline
71TA  Offline
Warren, MI
Put one end in a vice and pull to the side to put washers between every coil (on both sides). Install it and then dig the washers out. Be sure to leave some of the hole exposed to get a screwdriver in.
It's been a while since I put one in. Trying to think why when after installed that the washers weren't easily removed after depressing the clutch pedal.
I'd be interested to hear other "methods".
www.DetroitMuscleTechnologies.com Mopar body and heater box restoration gaskets
Re: Clutch pedal "over center spring" [Re: 71TA] #423043
07/29/09 06:02 PM
07/29/09 06:02 PM
michigan woods
imfixinmopars426 Offline
michigan woods
what clutch are you using? centerforce dont really need one. i have left many out myself. i thought if you unhook the clutch,and depress the pedal alone,you can pop it on w/ a small prybar?..then pull it up,and rehook the clutch linkage. be careful,and not get your fingers pinched under the pedal,once the spring is attached,w/o the linkage attached,lol..SLAM!! OOOWWWCCCH! F%$$^ D%$#^ S(%^!!
Re: Clutch pedal "over center spring" [Re: imfixinmopars426] #423044
07/29/09 07:03 PM
07/29/09 07:03 PM
Indiana
Crabra Offline
Crabra  Offline
Indiana
I don't mean to hi jack post,But where do I find one for a 1969 roadrunner.Mine is really stretched out.What does this spring do.
Re: Clutch pedal "over center spring" [Re: 6T9Hemi] #423045
07/29/09 07:43 PM
07/29/09 07:43 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Its an "over center" spring, meaning it will pull either way once it goes past "center. So ... when you depress the clutch it goes past center and helps your left foot overcome the pressure plate. When you release the clutch and the pedal comes back up (from the force of the pressure plate) it once again goes past center this time bringing the pedal all the way up.
Its just my thought but leaving this spring out would mean that the pedal would only come up as far as the pressure plate pushes it. This would leave the release bearing in constant contact with the fingers and it would be continuously spinning. This can't be good. The itty-bitty spring on the fork is there to avoid this but it doesn't have the balls to do the job without the over center spring doing its job.
Re: Clutch pedal "over center spring" [Re: Stanton] #423046
07/29/09 07:46 PM
07/29/09 07:46 PM
Eugene, Oregon
minivan Offline
minivan  Offline
Eugene, Oregon
Thanks Stanton for an explanation on this item that I hear so much about on this site.. I always wondered what it exactly did.....
Re: Clutch pedal "over center spring" [Re: minivan] #423047
07/29/09 08:24 PM
07/29/09 08:24 PM
Indiana
Crabra Offline
Crabra  Offline
Indiana
Great explanation.Can anybody tell me where to find one.
Re: Clutch pedal "over center spring" [Re: Crabra] #423048
07/29/09 08:33 PM
07/29/09 08:33 PM
Indiana
Crabra Offline
Crabra  Offline
Indiana
Does anybody have pictures where it goes to and from.Don't even know if mine is in right place.
Re: Clutch pedal "over center spring" [Re: Crabra] #423049
07/29/09 09:00 PM
07/29/09 09:00 PM
Cincinnati, Ohio
superbeedave Offline
Cincinnati, Ohio
okay, I had the same situation about 4 years ago.Took me about 4 days then finally I came up with the spring drum brake tool. Worked like a charm.
Re: Clutch pedal "over center spring" [Re: Stanton] #423050
07/29/09 09:21 PM
07/29/09 09:21 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
Hydraulic Throw out bearings remain in constant contact with the fingers...why can they "take it" but a regular throw out bearing can't?
**Photobucket sucks**
Re: Clutch pedal "over center spring" [Re: 70Cuda383] #423051
07/29/09 11:19 PM
07/29/09 11:19 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Didn't say they can't. But why subject them to that when you don't have to.
Re: Clutch pedal "over center spring" [Re: Stanton] #423052
07/29/09 11:46 PM
07/29/09 11:46 PM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
It has been a while, but I think I took the linkage off and with no carpet under the pedal, pushed it to the floor and the spring went on with a brake spring installer or a pair of vise grips.., then I raised it up and installed the linkage...
Re: Clutch pedal "over center spring" [Re: 70Cuda383] #423053
07/30/09 01:11 AM
07/30/09 01:11 AM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
I duno but my regular TOB died a quick death when the adjusting nut tightened itself up going down the road. No air gap, no workie.
Re: Clutch pedal "over center spring" [Re: Crabra] #423054
07/30/09 12:12 PM
07/30/09 12:12 PM
Ohio
64dodge572 Offline
64dodge572  Offline
Ohio
http://www.brewersperformance.com/proddetail.asp?prod=OCS936
Brewers Performance Inc.
4-speed transmission and parts specialists
PH 937-947-4416 or 937-698-4259
FAX 937-947-4419
Re: Clutch pedal "over center spring" [Re: 64dodge572] #423055
07/30/09 04:21 PM
07/30/09 04:21 PM
Jamey Offline
Jamey  Offline
I just had to do this last night. I tapped some thick washers between the spring coils. I then put it in place and pulled the washers out with a pair of wire cutters.
Re: Clutch pedal "over center spring" [Re: 64dodge572] #423056
07/30/09 05:38 PM
07/30/09 05:38 PM
Indiana
Crabra Offline
Crabra  Offline
Indiana
Thanks I called them (Brewers)early today.
Re: Clutch pedal "over center spring" [Re: Crabra] #423057
07/30/09 10:40 PM
07/30/09 10:40 PM
SomeCarGuy Offline
SomeCarGuy  Offline
You don't run the over center spring if you have a diaphram (CF) clutch
I want my fair share
Re: Clutch pedal "over center spring" [Re: 6T9Hemi] #423058
07/30/09 11:05 PM
07/30/09 11:05 PM
Lenox Iowa
MMiller Offline
MMiller  Offline
Lenox Iowa
So, do I need to find one for my truck then? I just changed out the centerforce, to a dual disk McCloud. The pedal does not come all the way up. Where do I find a creature like this said spring for a 75 dodge truck?
Michael
93 W250 CTD getrag, Bosch 185 injectors, AFE air filter. Trailer puller, daily driver,
90 W250 CTD 727 with smokin 5" stacks. Off road truck
75 Dodge W200 440 4spd 4x4 locked front and rear, twin disc clutch, E85. Pulling truck
