Clutch pedal "over center spring"
#423040
07/29/09 03:54 PM
07/29/09 03:54 PM
Posts: 935 Elizabethtown, KY
6T9Hemi
Elizabethtown, KY
What's the best way to get the over-sized spring back on the clutch pedal?
1969 340 4 Speed Swinger R4, black vinyl, white butt stripe, 3:91
Re: Clutch pedal "over center spring"
[Re: 70Cuda383]
#423051
07/29/09 11:19 PM
07/29/09 11:19 PM
Posts: 8,862 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
Hydraulic Throw out bearings remain in constant contact with the fingers...why can they "take it" but a regular throw out bearing can't?
Didn't say they can't. But why subject them to that when you don't have to.
[Re: 70Cuda383]
#423053
07/30/09 01:11 AM
07/30/09 01:11 AM
Posts: 10,200 Someplace you aren't
SomeCarGuy
Its just my thought but leaving this spring out would mean that the pedal would only come up as far as the pressure plate pushes it. This would leave the release bearing in constant contact with the fingers and it would be continuously spinning. This can't be good.
I duno but my regular TOB died a quick death when the adjusting nut tightened itself up going down the road. No air gap, no workie.
[Re: 6T9Hemi]
#423058
07/30/09 11:05 PM
07/30/09 11:05 PM
Posts: 522 Lenox Iowa
MMiller
Lenox Iowa
So, do I need to find one for my truck then? I just changed out the centerforce, to a dual disk McCloud. The pedal does not come all the way up. Where do I find a creature like this said spring for a 75 dodge truck?
Michael
93 W250 CTD getrag, Bosch 185 injectors, AFE air filter. Trailer puller, daily driver, 90 W250 CTD 727 with smokin 5" stacks. Off road truck
75 Dodge W200 440 4spd 4x4 locked front and rear, twin disc clutch, E85. Pulling truck
