Info. needed on pulling main capps on Indy Alu. block?? #422763
07/29/09 09:23 AM
07/29/09 09:23 AM
Sweet Home Alabama
MRMOPAR622 Offline OP
Sweet Home Alabama
On the Indy Maxx aluminum block do you need a main cap puller to remove them??? I am thinking last year right after I got my engine some one on here was talking about having to have a special puller to get them off. I have been building and working on Mopar engines for 20+ years even the ford's and chevy's and never had to have one. But this is my first Indy block and I don't want to make any mistakes. If I do need one(hoping I don't) where do I buy it???? Thanks
"To Be The Man'You Have Got To Beat The Man" "T/D and Pro-Bracket Racer"
Re: Info. needed on pulling main capps on Indy Alu. block?? [Re: MRMOPAR622] #422764
07/29/09 09:34 AM
07/29/09 09:34 AM
Wheels up, MO
N
nhramark Offline
nhramark  Offline
N
Wheels up, MO
Not sure about the aluminum block, but my Mega block requires a puller. My buddy made a simple puller from material he had laying around in his shop, works great and cost nothing.
[image]http://s1126.photobucket.com/user/nhramark1/library/Racing[/image] 9.100 @ 150 mph 5.780 @ 120 mph
Post deleted by Defbob [Re: nhramark] #422765
07/29/09 10:47 AM
07/29/09 10:47 AM
Re: Info. needed on pulling main capps on Indy Alu. block?? #422766
07/29/09 10:48 AM
07/29/09 10:48 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
I have made mine out of a slide hammer. Have a couple of changeable heads for various blocks.
Re: Info. needed on pulling main capps on Indy Alu. block?? [Re: Al_Alguire] #422767
07/29/09 11:26 AM
07/29/09 11:26 AM
Sweet Home Alabama
Sweet Home Alabama
Thanks, I have a idea of where to start now.
Will more than likely be back asking more questions later. Thanks again for the help!!
Post deleted by Defbob [Re: MRMOPAR622] #422768
07/29/09 11:34 AM
07/29/09 11:34 AM
Re: Info. needed on pulling main capps on Indy Alu. block?? #422769
07/29/09 12:35 PM
07/29/09 12:35 PM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
slide hammer out and put them in the freezer before they go back in.
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: Info. needed on pulling main capps on Indy Alu. block?? [Re: bigtimeauto] #422770
07/29/09 01:46 PM
07/29/09 01:46 PM
mi usa
O
old yeller Offline
old yeller  Offline
O
mi usa
poor mans way is to put vise gripes on the main cap and spin the crank it will knock the main cap up.(been doing it this way for years)
Re: Info. needed on pulling main capps on Indy Alu. block?? [Re: old yeller] #422771
07/29/09 08:28 PM
07/29/09 08:28 PM
Arizona
Chris'sBarracuda Offline
Arizona
I made my own puller.
As stated before, freeze to get them in.
BigCube has a nice one that he made.
Maybe AndyF can make one that is not too pricey..
When I asked (Russ) Indy @ the MATS, he just shook his head and said "yes there is a special tool for this...It's called a slide hammer"
What a PUTZ..
Chris..
Re: Info. needed on pulling main capps on Indy Alu. block?? [Re: Chris'sBarracuda] #422772
07/30/09 01:09 AM
07/30/09 01:09 AM
Finalnd, Perkele
jyrki Offline
jyrki  Offline
Finalnd, Perkele
Newer thought about cooling the caps for assembly. So far just hit them in to the place with the bearing attached with a tie strap until I can get the nuts on the studs. What a pain.
Plynouth VIP '67 TT IC EFI
Re: Info. needed on pulling main capps on Indy Alu. block?? [Re: jyrki] #422773
07/30/09 01:38 AM
07/30/09 01:38 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
on the brighter side they become easier to refit after a few seasons use. i can press mine down almost to the threads now but in the early days it was freezer caps & heated block with fuse wire holding the bearings in while tapping down with the rubber hammer. luckily my slide hammer for pulling my floater axles has the same thread.
Re: Info. needed on pulling main capps on Indy Alu. block?? [Re: rebel] #422774
07/30/09 02:32 AM
07/30/09 02:32 AM
Finalnd, Perkele
jyrki Offline
jyrki  Offline
Finalnd, Perkele
Mine is already ten years old, and the situation hasn't changed.
