Pics please of alternators on motor plates #421672
07/28/09 11:56 AM
07/28/09 11:56 AM
NE Oklahoma
V
Von Offline OP
Von  Offline OP
V
NE Oklahoma
Looking for some pics of how you have mounted your alternator on motor plates or elephant ears.
Thanks in advance.
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72. Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: Pics please of alternators on motor plates [Re: Von] #421673
07/28/09 12:56 PM
07/28/09 12:56 PM
USA
Ron Silva Offline
Ron Silva  Offline
USA
I had a small Denso alternator and I frenched it into the motor plate and used a couple CV Products Small Block Chevy alternator brackets for the template and as spacers.
SRT DEMON ONE SEAT
Re: Pics please of alternators on motor plates [Re: Ron Silva] #421674
07/28/09 12:57 PM
07/28/09 12:57 PM
USA
Ron Silva Offline
Ron Silva  Offline
USA
2
SRT DEMON ONE SEAT
Re: Pics please of alternators on motor plates [Re: Ron Silva] #421675
07/28/09 01:05 PM
07/28/09 01:05 PM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
1.39 9.85 - 137 mph
Post deleted by Defbob [Re: Ari440] #421676
07/28/09 01:19 PM
07/28/09 01:19 PM
Re: Pics please of alternators on motor plates #421677
07/28/09 07:50 PM
07/28/09 07:50 PM
Cedar Lake,IN
d330 Offline
d330  Offline
Cedar Lake,IN
I just used this low mount
Is that a lawn tractor belt??
Re: Pics please of alternators on motor plates [Re: Von] #421678
07/28/09 07:59 PM
07/28/09 07:59 PM
ELYRIA,OH
blownzoom440 Offline
ELYRIA,OH
mine is very low budget.GM 1 wire 100 amp off the plate and stock adjuster in the timing cover bottom hole.
Re: Pics please of alternators on motor plates [Re: Von] #421679
07/28/09 08:22 PM
07/28/09 08:22 PM
AndyF Offline
AndyF  Offline
Here is a kit that I make. You can buy this from Mancini Racing or Hughes or other Mopar parts dealers.
Re: Pics please of alternators on motor plates [Re: Von] #421680
07/28/09 08:26 PM
07/28/09 08:26 PM
So. IL. USA
PLUM BAD Offline
PLUM BAD  Offline
So. IL. USA
I got my alt. mount, pulleys, and motor plate from Arch Engineering Integration. PM NHRAMARK He will fix you up and you won't be disappointed.
Re: Pics please of alternators on motor plates [Re: PLUM BAD] #421681
07/28/09 08:34 PM
07/28/09 08:34 PM
In the 8's
FY1TA Offline
FY1TA  Offline
In the 8's
Jegs chebbie kit 35.00 .
Re: Pics please of alternators on motor plates [Re: FY1TA] #421682
07/28/09 09:03 PM
07/28/09 09:03 PM
aftermarket low-mount........
Re: Pics please of alternators on motor plates #421683
07/28/09 09:40 PM
07/28/09 09:40 PM
In The Hills
jughed Offline
jughed  Offline
In The Hills
aftermarket suspension....but it was done the same way with the stock k-frame
Re: Pics please of alternators on motor plates [Re: jughed] #421684
07/29/09 12:19 AM
07/29/09 12:19 AM
Riverside, Ca
G_bob Offline
G_bob  Offline
Riverside, Ca
Not a great pic, but just fabbed a couple of brackets.
Re: Pics please of alternators on motor plates [Re: G_bob] #421685
07/29/09 12:41 AM
07/29/09 12:41 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Well as many already know I march to the beat of a different drummer so here is mine. Look hard but down low it is a GM one wire mounted to the frame rail of the car facing backwards.
I have used the DMI low mount set up as well and it works great. Just not room on the Cuda for one. Here is the Valiant with the DMI stuff
Re: Pics please of alternators on motor plates [Re: Al_Alguire] #421686
07/29/09 05:58 AM
07/29/09 05:58 AM
Whitinsville Ma
superbee500 Offline
superbee500  Offline
Whitinsville Ma
This is what I did
If I did it again I would go with a low mount kit
Kevin
69 superbee 04 ram 3500
Re: Pics please of alternators on motor plates [Re: superbee500] #421687
07/29/09 06:31 AM
07/29/09 06:31 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
piece of ali bar, 5 mins in the lathe, tek screwed an anchor on the chassis, slip a mitsi single wire in the gap and.....
Re: Pics please of alternators on motor plates [Re: rebel] #421688
07/29/09 07:08 AM
07/29/09 07:08 AM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
I see a lot of them are not actually mounted to the engine plate....This one is, here you go.
Re: Pics please of alternators on motor plates [Re: Dragula] #421689
07/29/09 07:09 AM
07/29/09 07:09 AM
Dragula Offline
Dragula  Offline
Nuther.
Re: Pics please of alternators on motor plates [Re: Dragula] #421690
07/29/09 07:10 AM
07/29/09 07:10 AM
Dragula Offline
Dragula  Offline
Last one...
Re: Pics please of alternators on motor plates [Re: Dragula] #421691
07/29/09 07:26 AM
07/29/09 07:26 AM
Sebring, Florida
Mopar Grandpa Offline
Sebring, Florida
My plate was purchased from Mancini and I did not have to cut or modify it in order to install my alternator. I was able to use the stock alternator bracket and spacers that mounts to the water pump area but I had to make an adjusting bracket which bolts to the engine plate bolt as the radius adjusting bracket was too short.
