3/8 FUEL TANK UNIT CORRECT FOR 68 CORONET R/T 440? #420348
07/27/09 12:47 PM
07/27/09 12:47 PM
BAREFOOT BEACH SOUTHWEST FL
HEMIBULLITT Offline OP
super street
super street
I have a friend with a 68 Coronet R/T Convert 440 auto that I am helping him replace his fuel tank and it currently has a 5/16 sending unit in it. I thought all 440 magnums came with the 3/8 unit? The tanks is not original but he says the sender was transfered to the new tank 20 some years ago???? Anybody know for sure? THANKS!
Steve
Re: 3/8 FUEL TANK UNIT CORRECT FOR 68 CORONET R/T 440? [Re: HEMIBULLITT] #420349
07/27/09 02:42 PM
07/27/09 02:42 PM
Ontario, Canada
FJ5_Fish Offline
FJ5_Fish  Offline
Ontario, Canada
The 69 440 B-Bodies all had a 3/8" sending unit with a 5/16" fuel line.....I don't have a 68 to check but I'll check with someone who does.
Re: 3/8 FUEL TANK UNIT CORRECT FOR 68 CORONET R/T 440? [Re: FJ5_Fish] #420350
07/27/09 04:29 PM
07/27/09 04:29 PM
super street
super street
Thanks fish, any help is greatly appreciated! I've had a few 68 B Bodys over the years and am getting too old to remember all the vital stats on em anymore!
Cheers
Steve
Re: 3/8 FUEL TANK UNIT CORRECT FOR 68 CORONET R/T 440? [Re: HEMIBULLITT] #420351
07/27/09 05:06 PM
07/27/09 05:06 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
5/16 is correct but upgrading to 3/8 certainly wouldn't hurt anything...
Re: 3/8 FUEL TANK UNIT CORRECT FOR 68 CORONET R/T 440? [Re: 1_WILD_RT] #420352
07/27/09 06:40 PM
07/27/09 06:40 PM
super street
super street
Thanks Wild R/T I believe the fuel line is 5/16 & also thought it should be 3/8. My Charger has 3/8 line and sender but it is the HEMI I know, just seems like I remember the Magnum 440 Cars having the same 3/8 fuel lines.......hate gettin old.
Steve
Re: 3/8 FUEL TANK UNIT CORRECT FOR 68 CORONET R/T 440? [Re: HEMIBULLITT] #420353
07/27/09 07:07 PM
07/27/09 07:07 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Hemi got 3/8ths.. 440 got 3/8ths later.. For sure in 70, I didn't think 69 got it, I know the A12 440-6 cars only had 5/16 but they were based on converted 383 cars so...
BTW I have a 68 Coronet R/T vert.. 440/727 car...
Re: 3/8 FUEL TANK UNIT CORRECT FOR 68 CORONET R/T 440? [Re: 1_WILD_RT] #420354
07/27/09 07:25 PM
07/27/09 07:25 PM
be prepared for the new sending unit not to work 100%.
it wont go to full, only 3/4 the way full.
im on my 4th sending unit from every retailer who sells them.
unless something im doing wrong, it wont show full.
Re: 3/8 FUEL TANK UNIT CORRECT FOR 68 CORONET R/T 440? #420355
07/27/09 07:36 PM
07/27/09 07:36 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
I've been through that... Next time I think I'm going to try having the original rebuilt...
https://board.moparts.org/ubbthreads/show...rue#Post5360196
Re: 3/8 FUEL TANK UNIT CORRECT FOR 68 CORONET R/T 440? [Re: 1_WILD_RT] #420356
07/27/09 08:44 PM
07/27/09 08:44 PM
i pulled mine out 7 different times and went through at least 14 keystone clamps, i tried everything to get it to work.
what i dont understand, i plugged in the sending unit switch wire to the unit, turned on the ignition switch, flipped up the lever and it read full on the gauge, i go and installed it and all i can get is 3/4 full with a totally full tank.
Re: 3/8 FUEL TANK UNIT CORRECT FOR 68 CORONET R/T 440? #420357
07/27/09 08:50 PM
07/27/09 08:50 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
You need an old fuel tank you can cut a hole in & see how far the arm actually travels... I doubt it hits the upper travel limiter made into the sender...
Re: 3/8 FUEL TANK UNIT CORRECT FOR 68 CORONET R/T 440? #420358
07/27/09 08:56 PM
07/27/09 08:56 PM
Seattle, WA
3
375inStroke Online content
Special needs person
375inStroke  Online Content
3
Seattle, WA
I'd start checking things that can be checked. My replacement worked the first time. This article has some useful information. Mopar Gauges It says "Most problems relate to the fuel gauge sender, which should read 61 to 85 ohms ‘empty’, and 8.6 to 10.6 ohms ‘full’ If the sender is within these specs, the ground at the tank strap is in place (fig. 2), and the wiring, right up to the gauge, is okay, then the gauge itself is shot."
I'd check the resistance when full. After doing something about the gas (I'd drive it almost empty) remove the sender and see if it can move full up. There are tabs that limit max deflection that can be bent for calibration purposes. See if you can get the resistance down to the 9 volt range. If that's good, you can bend the arm down. I don't think this is the problem, but if it is, reading empty when empty is more important than reading full when full.
If the sender reads good, check for low resistance from the back of the sender to the car body.
If everything's good so far, and the other gauges work fine, then it's probably the gauge. There are adjustments inside them for calibration.
Re: 3/8 FUEL TANK UNIT CORRECT FOR 68 CORONET R/T 440? [Re: 375inStroke] #420359
07/28/09 04:01 AM
07/28/09 04:01 AM
Southeast Virginia
68jim Offline
68jim  Offline
Southeast Virginia
I have the exact issue going on with my 68 Road Runner. After buying a second sender and having the tank only read 3/4 when full. I compared the repro with my original and saw that the swing arm sits .75" higher on the repro compared to the original. I'm guessing that the float is hitting the top of the tank before getting full swing. When I get back to the garage I will remove it one more time and bend the arm to match the full swing height of the original. I do not have the numbers in front of me but I seem to recall the original was 7" from the sock sitting level to the top of the swing float and the repro was 7.75". It will be a few weeks yet before I can verify the fix.
Good Luck
68 Hemi Road Runner
Re: 3/8 FUEL TANK UNIT CORRECT FOR 68 CORONET R/T 440? [Re: 68jim] #420360
07/28/09 04:36 AM
07/28/09 04:36 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Yeah but when you bend the arm to only hit 7.0" it will now not read empty when it reaches the bottom of the tank...
Re: 3/8 FUEL TANK UNIT CORRECT FOR 68 CORONET R/T 440? [Re: 1_WILD_RT] #420361
07/28/09 12:10 PM
07/28/09 12:10 PM
Ontario, Canada
FJ5_Fish Offline
FJ5_Fish  Offline
Ontario, Canada
Yup - 70 was the year the 440 got the 3/8" fuel line to go with the 3/8" sender they already had in 69.
Re: 3/8 FUEL TANK UNIT CORRECT FOR 68 CORONET R/T 440? [Re: 1_WILD_RT] #420362
07/28/09 02:07 PM
07/28/09 02:07 PM
Seattle, WA
3
3
Seattle, WA
I don't think you can say this with certainty. I bent mine a bit and get full when full and empty when empty.
Re: 3/8 FUEL TANK UNIT CORRECT FOR 68 CORONET R/T 440? [Re: 1_WILD_RT] #420363
07/29/09 01:05 AM
07/29/09 01:05 AM
super street
super street
Thanks for all the great feedback! Here is a pic before we start the surgery. I ordered a 3/8 sender and will adjust the float level as needed!
Steve
Re: 3/8 FUEL TANK UNIT CORRECT FOR 68 CORONET R/T 440? [Re: HEMIBULLITT] #420364
07/29/09 01:16 AM
07/29/09 01:16 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Very Cool! Someday I hope mine will look that good...Currently it looks alot better than when I brought it home but far from roadworthy... I got it looking like this...
Re: 3/8 FUEL TANK UNIT CORRECT FOR 68 CORONET R/T 440? [Re: HEMIBULLITT] #420365
07/29/09 01:18 AM
07/29/09 01:18 AM
State of retirement
52savoy Offline
52savoy  Offline
State of retirement
Never say never...I've seen 3/8" pick-ups in '68 440 GTXs. I would guess that both were used depending what was available at that moment(or the level of training).
Re: 3/8 FUEL TANK UNIT CORRECT FOR 68 CORONET R/T 440? [Re: 1_WILD_RT] #420366
07/29/09 01:18 AM
07/29/09 01:18 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Currently it looks about like ths..
Re: 3/8 FUEL TANK UNIT CORRECT FOR 68 CORONET R/T 440? [Re: 1_WILD_RT] #420367
07/29/09 01:21 AM
07/29/09 01:21 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Originally it looked & again someday it will look like this...
BTW I don't know who's car this is, Andy440 had the picture & it's my cars twin...
