Re: How do you tell a 400 thick main webbing block apart?
[Re: Stationwagonguy]
#41851
06/05/07 09:33 PM
06/05/07 09:33 PM
Posts: 12,494 Western Colorado High Desert
moparmarks
The 230 "cold weather block" was cast in the last 6 months of 71 for the 72 model so if it has a 71 cast date then should be good to go. I've got up to 450.00 for a nice early block.
72 Satellite Sebring Plus 440, 72 Dart 5.9 4-spd, 68 Valiant, 73 W200, 78 D100 sb, 78 D200, 98 DAKOTA, . Moparmarks Parts & Restorations Desert Mopar Metal Grand Jct. CO 970-261-7039 http://moparmark.com/motormangj@gmail.com
#41852
06/05/07 09:41 PM
06/05/07 09:41 PM
Posts: 75,066 U.S.S.A.
JohnRR
U.S.S.A.
Other than the blatantly thick webbing. I had though they had "230" as part of the casting number in them, but someone who I was going to buy a block from insists that they made them from 1972-1974, and if they have a circular water jacket as opposed to an oval one, they're automatically thick blocks. Is this true, or is this guy confused?
And what is a normal 400 block worth these days, anyways?
there are 2 230 blocks , those cast BEFORE 10/10/71 AND those cast AFTER , the ones BEFORE are the cold weather blocks with thick main webs , the ones after are NOT .
[Re: JohnRR]
#41854
06/06/07 01:33 AM
06/06/07 01:33 AM
Posts: 803 Zebulon
Stationwagonguy
A Closet Buick Man
A Closet Buick Man
Zebulon
there are 2 230 blocks , those cast 10/10/71 AND those cast AFTER , the ones BEFORE are the cold weather blocks with thick main webs , the ones after are NOT .
OK- so only those early 230 blocks have thick mains, the rest are normal blocks like all other 400s? The 440source website doesn't mention that (My eyes could have skipped over it too ).
Is a normal 400 block worth $200, or does that seem kinda pricey?
[image][/image]
Bob
SWG
'68 Chrysler Town & Country, 'Katy Jo'
'70 Chrysler 300 2-door
'78 Impala 2-door
#41855
06/06/07 02:53 AM
06/06/07 02:53 AM
They're all good! http://www.440source.com/blockinfo.htmShown above is the #2 saddle on a late model (76-78) 400 block, casting #4006530-400. The "B" measurement remains the same as the early 400 block at about .525 -.575, while the "A" goes down to roughly 3.300, making the support only less than half an inch narrower then the early 400 (still almost 90% of the width), and still over 1 1/4 inches wider then 383's and early 440's.
#41859
06/06/07 08:58 AM
06/06/07 08:58 AM
JohnRR
U.S.S.A.
Good info. Thanks!
But seriously- is $200 about the going rate for a normal 400 block, or is that too much?
you need to make that decision , i edited my original reply and added BEFORE 10/10 , i have to look at the linked thread , it might be 10/17 ??? i get confused .
anywho , is it JUST a GREASY disassembled block ? as quikd100 states without a SONIC CHECK its a crap shoot . i have a 230 thick web block , it was locked up when i got it . it's still std bore and between rust pits AND CORE SHIFT it NEEDS 5 sleeves , good thing i got it cheap if the rumor is true about low deck megablocks coming down the pike cold weather blocks will be relegated to what the rest of the stock factory blocks are ... worth their weight in SCRAP without magnaflux AND sonic check ...
i am also dealing with a 69 440 HP block right now that has questionable integrity for anything over a STOCK rebuild .
