How do you tell a 400 thick main webbing block apart? #41850
06/05/07 09:24 PM
06/05/07 09:24 PM
Zebulon
Stationwagonguy Offline OP
A Closet Buick Man
A Closet Buick Man
Zebulon
Other than the blatantly thick webbing. I had though they had "230" as part of the casting number in them, but someone who I was going to buy a block from insists that they made them from 1972-1974, and if they have a circular water jacket as opposed to an oval one, they're automatically thick blocks. Is this true, or is this guy confused?
And what is a normal 400 block worth these days, anyways?
Re: How do you tell a 400 thick main webbing block apart? [Re: Stationwagonguy] #41851
06/05/07 09:33 PM
06/05/07 09:33 PM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
The 230 "cold weather block" was cast in the last 6 months of 71 for the 72 model so if it has a 71 cast date then should be good to go. I've got up to 450.00 for a nice early block.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: How do you tell a 400 thick main webbing block apar [Re: Stationwagonguy] #41852
06/05/07 09:41 PM
06/05/07 09:41 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
there are 2 230 blocks , those cast BEFORE 10/10/71 AND those cast AFTER , the ones BEFORE are the cold weather blocks with thick main webs , the ones after are NOT .
Re: How do you tell a 400 thick main webbing block apart? [Re: JohnRR] #41853
06/06/07 12:12 AM
06/06/07 12:12 AM
USA IN
E85-408 Offline
E85-408  Offline
USA IN
Check 440 Source for info. Click on everything you need to know about blocks.(great pics too)
Re: How do you tell a 400 thick main webbing block apar [Re: JohnRR] #41854
06/06/07 01:33 AM
06/06/07 01:33 AM
Zebulon
A Closet Buick Man
A Closet Buick Man
Zebulon
there are 2 230 blocks , those cast 10/10/71 AND those cast AFTER , the ones BEFORE are the cold weather blocks with thick main webs , the ones after are NOT .
OK- so only those early 230 blocks have thick mains, the rest are normal blocks like all other 400s? The 440source website doesn't mention that (My eyes could have skipped over it too ).
Is a normal 400 block worth $200, or does that seem kinda pricey?
[image][/image] Bob SWG '68 Chrysler Town & Country, 'Katy Jo' '70 Chrysler 300 2-door '78 Impala 2-door
Re: How do you tell a 400 thick main webbing block apar [Re: Stationwagonguy] #41855
06/06/07 02:53 AM
06/06/07 02:53 AM
They're all good!
http://www.440source.com/blockinfo.htm
Shown above is the #2 saddle on a late model (76-78) 400 block, casting #4006530-400. The "B" measurement remains the same as the early 400 block at about .525 -.575, while the "A" goes down to roughly 3.300, making the support only less than half an inch narrower then the early 400 (still almost 90% of the width), and still over 1 1/4 inches wider then 383's and early 440's.
Re: How do you tell a 400 thick main webbing block apar #41856
06/06/07 03:00 AM
06/06/07 03:00 AM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
440 source could really use some more info about the cold weather blocks as what they have there is lacking. Try this thread. has casting date periods and some other stuff:
https://board.moparts.org/ubbthreads/show...rue#Post3510159
Re: How do you tell a 400 thick main webbing block apar [Re: RobX4406] #41857
06/06/07 03:37 AM
06/06/07 03:37 AM
Zebulon
A Closet Buick Man
A Closet Buick Man
Zebulon
Good info. Thanks!
But seriously- is $200 about the going rate for a normal 400 block, or is that too much?
Re: How do you tell a 400 thick main webbing block apar [Re: Stationwagonguy] #41858
06/06/07 06:45 AM
06/06/07 06:45 AM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
Reguardless if you get the early thick web block or not. SONIC TEST THEM ALL! I've got a thick web block that's never been bored,(7-31-71) it looks beautiful. 4 cylinders are thin and need sleeves if it were to be used. One cylinder is .083 thick at standard bore. It's a nice looking doorstop. Dave
Re: How do you tell a 400 thick main webbing block apar [Re: Stationwagonguy] #41859
06/06/07 08:58 AM
06/06/07 08:58 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Good info. Thanks!
you need to make that decision , i edited my original reply and added BEFORE 10/10 , i have to look at the linked thread , it might be 10/17 ??? i get confused .
anywho , is it JUST a GREASY disassembled block ? as quikd100 states without a SONIC CHECK its a crap shoot . i have a 230 thick web block , it was locked up when i got it . it's still std bore and between rust pits AND CORE SHIFT it NEEDS 5 sleeves , good thing i got it cheap if the rumor is true about low deck megablocks coming down the pike cold weather blocks will be relegated to what the rest of the stock factory blocks are ... worth their weight in SCRAP without magnaflux AND sonic check ...
i am also dealing with a 69 440 HP block right now that has questionable integrity for anything over a STOCK rebuild .
Re: How do you tell a 400 thick main webbing block apart? [Re: Stationwagonguy] #41860
12/05/08 06:04 PM
12/05/08 06:04 PM
On The Boat, On The Lake, Wa. ...
amxautox Offline
Still Retired. Still Posting on Moparts. A Lot.
amxautox  Offline
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
