Hole for 4 speed under hump. Need pics size #41834
05/27/07 05:26 AM
05/27/07 05:26 AM
NORTHERN CA
HUSTLESTUFF Offline OP
NORTHERN CA
I need to install my 4 speed hump in the 69 Charger I am working on. Does anyone have a pic of the hole that is cut out of the floorpan for the shifter? Thanks in advanced. Mike
"Were in it to win it. Anything less will end up being..... A whole lot of fun doing!!" UNLAWFL
RIP UN
Re: Hole for 4 speed under hump. Need pics size [Re: HUSTLESTUFF] #41835
05/27/07 06:51 AM
05/27/07 06:51 AM
Speaking from personal experience. Make an outline of the hump on the floor before you weld it in and just cut out that whole area leaving enough to weld to. You will need the area for clearance and if you leave an overhang it is just somewhere for junk (leaves,dirt,etc;) to sit and and cause corrosion.
Re: Hole for 4 speed under hump. Need pics size [Re: HUSTLESTUFF] #41836
05/27/07 08:13 PM
05/27/07 08:13 PM
Kansas 67208
8
8_Barrel Offline
super gas
8_Barrel  Offline
super gas
8
Kansas 67208
This question comes up 'bout once every 60 days......maybe this pic ought'a be archived.......removed from a July 15th built 68 Road Runner but should be the same for all 66 - 70 B bodies.
If you "Ain't Skeered" or have "No Fear", it's 'cause you ain't goin' FAST enough!!
Re: Hole for 4 speed under hump. Need pics size [Re: 8_Barrel] #41837
05/27/07 09:33 PM
05/27/07 09:33 PM
Yes, that is what it looks like. This is a 70 RR original. As i said, the entire area is opened up.
Re: Hole for 4 speed under hump. Need pics size #41838
05/27/07 11:24 PM
05/27/07 11:24 PM
NORTHERN CA
NORTHERN CA
I hit the mod notify, maybe in tech archives under trans. Thanks guys Mike
RIP UN
