63 Indy Maxx Motor PICS. #387284
07/26/09 10:10 PM
07/26/09 10:10 PM
Lake Charles,Louisiana
BILLYJAY Offline OP
BILLYJAY  Offline OP
Well we spent the last 2 days finishing up on my 572ci Indy Maxx motor for the 63 Dart.. have some small items to finish..installing the Motor on wednesday and headed to the fab shop for headers.. Oh. as a side note..WISH INDY was there so slap a few of those guys and their shabby work.. missing 2 rocker studs,1 rocker stud nut has no threads, missing 1 valve cover nut and stud, pushrod clearancing Sucked,One headstud was so tight you couldnt get the nut on it,and it was so tight you needed a 12point nut not 6point,Rocker shaft plugs were shoved so far in, you couldnt get the end stud through the hole..Lifter clearancing was also way off on the #1 & 2 in the lifter valley..Open the box with the finished pushrods and found all kinds of item sent to me that i didnt order..would have gladly traded all the 200.00 worth of parts for a complete set of items for the heads and some QC work on these heads..you would think that for 5400.00 the quality would be superior to anything going.. or at least check the clearanes once in a while...
Re: 63 Indy Maxx Motor PICS. [Re: BILLYJAY] #387285
07/26/09 10:11 PM
07/26/09 10:11 PM
BILLYJAY Offline OP
BILLYJAY  Offline OP
2
Re: 63 Indy Maxx Motor PICS. [Re: BILLYJAY] #387286
07/26/09 10:11 PM
07/26/09 10:11 PM
BILLYJAY Offline OP
BILLYJAY  Offline OP
Me and Tony
Re: 63 Indy Maxx Motor PICS. [Re: BILLYJAY] #387287
07/26/09 10:12 PM
07/26/09 10:12 PM
BILLYJAY Offline OP
BILLYJAY  Offline OP
3
Re: 63 Indy Maxx Motor PICS. [Re: BILLYJAY] #387288
07/26/09 10:13 PM
07/26/09 10:13 PM
BILLYJAY Offline OP
BILLYJAY  Offline OP
Re: 63 Indy Maxx Motor PICS. [Re: BILLYJAY] #387289
07/26/09 10:14 PM
07/26/09 10:14 PM
BILLYJAY Offline OP
BILLYJAY  Offline OP
Tony's 91 LeBaron tube car
Re: 63 Indy Maxx Motor PICS. [Re: BILLYJAY] #387290
07/26/09 10:15 PM
07/26/09 10:15 PM
BILLYJAY Offline OP
BILLYJAY  Offline OP
Front view
Re: 63 Indy Maxx Motor PICS. [Re: BILLYJAY] #387291
07/26/09 10:16 PM
07/26/09 10:16 PM
BILLYJAY Offline OP
BILLYJAY  Offline OP
557ci Indy Maxx motor
Re: 63 Indy Maxx Motor PICS. [Re: BILLYJAY] #387292
07/26/09 10:16 PM
07/26/09 10:16 PM
Minnesota
Barnstorm Offline
Barnstorm  Offline
Minnesota
Just back that truck up and deliver to 55305. I have a test mule!
The little old lady from Pasadena is back!
Re: 63 Indy Maxx Motor PICS. [Re: Barnstorm] #387293
07/26/09 10:29 PM
07/26/09 10:29 PM
BILLYJAY Offline OP
BILLYJAY  Offline OP
YEA, Me TOO !!!
Re: 63 Indy Maxx Motor PICS. [Re: BILLYJAY] #387294
07/26/09 10:39 PM
07/26/09 10:39 PM
In the 8's
FY1TA Offline
FY1TA  Offline
In the 8's
Very nice . What kind of HP are you expecting ?
Re: 63 Indy Maxx Motor PICS. [Re: BILLYJAY] #387295
07/26/09 10:40 PM
07/26/09 10:40 PM
Hemiroid Offline
Hemiroid  Offline
Looking good man!
I'd watch out for those attack dogs though
Re: 63 Indy Maxx Motor PICS. [Re: Hemiroid] #387296
07/26/09 11:04 PM
07/26/09 11:04 PM
BILLYJAY Offline OP
BILLYJAY  Offline OP
well im hoping for around 875-900hp and 750-800Ft Torque in my little car which should weigh about 2900-3000lbs..
Re: 63 Indy Maxx Motor PICS. [Re: BILLYJAY] #387297
07/27/09 08:26 AM
07/27/09 08:26 AM
Shelton, Ct.
572_HEMI_Cuda Offline
Shelton, Ct.
sweet car.....super clean look to it.
Re: 63 Indy Maxx Motor PICS. [Re: BILLYJAY] #387298
07/27/09 06:30 PM
07/27/09 06:30 PM
if your engine builder did his homework, you should expect around 935 hp.
looks very nice. goodluck.
Re: 63 Indy Maxx Motor PICS. #387299
07/27/09 08:54 PM
07/27/09 08:54 PM
BILLYJAY Offline OP
BILLYJAY  Offline OP
Yea, SuperStock..we were thinking the same thing but not wanting to throw bigger number til the car has been proven..we have done all figures based on the car being 3000lb and the motor making 850hp..should be in the 8.80-8.90's..but think it will be closer to 2875-2925lbs with alittle over 900hp..so if the car will hook up, it should be even faster..maybe a 8.60..either way, i am ready to get this thing finished..
Re: 63 Indy Maxx Motor PICS. [Re: BILLYJAY] #387300
07/27/09 11:58 PM
07/27/09 11:58 PM
BILLYJAY Offline OP
BILLYJAY  Offline OP
Almost ready..
Re: 63 Indy Maxx Motor PICS. [Re: BILLYJAY] #387301
07/27/09 11:59 PM
07/27/09 11:59 PM
BILLYJAY Offline OP
BILLYJAY  Offline OP
Driverside
Re: 63 Indy Maxx Motor PICS. [Re: BILLYJAY] #387302
07/28/09 12:00 AM
07/28/09 12:00 AM
BILLYJAY Offline OP
BILLYJAY  Offline OP
Rear panels...
